    MMM-MyCommute not showing up today.
    15 Posts 2 Posters 4.3k Views 2 Watching
      sdetweil @gwiz
      @gwiz i have no idea… if you open the developers window (ctrl-shift-i or F12 on the keyboard),
      and select the console tab, and put commu in the filter field, do you see any errors?
      • G Offline
        gwiz
        It says suspended but I’m not sure why, how can I check the reason?
          sdetweil @gwiz
          @gwiz do you use pages, or some activity monitor? pir, or somesuch
          sadly there is no notification for the call to suspend on WHO, but now that you found that line,
          you can re-enable other messages (remove filter) and then find the suspend again (search works)
          and find if some module said something just before
          • G Offline
            gwiz
            Here is what it shows me:
            Not sure if what you asked, but I do use VNC Viewer to connect and edit the mirror without taking the frame off. Could that have something to do with it?
            Thanks for your help
              sdetweil @gwiz
              @gwiz said in MMM-MyCommute not showing up today.:
              shouldn’t have anything to do with it… I edit thru an ssh connection all the time. never touch the mirror itself
              looking at the code it hides itself if its outside the configured times or there are no destinations…
              there are 4 different ones, which are u using?
              git remote -v in the module folder will tell you
              • G Offline
                gwiz
                Sorry I’m not sure what you mean, I ran the command and this is what it gave me:
                  sdetweil @gwiz
                  @gwiz in the module folder, MMM-MyCommute
                  • G Offline
                    gwiz
                    Okay here it is
                      still looks like it hides itself is there are no destinations or not in the time window to need to show results.
                      (commute set for 9am -10am, and its now 2 pm…
                      also hides itself immediately after startup.
                      • G Offline
                        gwiz
                        Hi @sdetweil
                        I don’t have any time parameters set up on the module. Weird… It fixed itself later in the day without me doing anything. Do you think there’s anything I can do to prevent that in the future?
                        Thanks for the help!
