    Fitbit
    129 Posts 42 Posters 219.9k Views 37 Watching
      MMMveasy
      hi everyone
      i found a workaround
      1. cd MagicMirror
      2. mkdir Test
      3. cd Test
      4. npm install python-shell@0.5.0
      5. copy python-shell from Test/node_modules folder to MagicMirror/node_modules
      6. also copy package.json to node_modules folder of MM
      • O Offline
        OttToyBoy @K-Pental
        @k-pental said in Fitbit:
        @deepthought said in Fitbit:
        When starting Magic Mirror, the Fitbit module displays no info and the cmd prompt states ‘TypeError: PythonShell.run is not a function’ and ‘TypeError: PythonShell is not a constructor’.
        Does anyone know how to resolve this issue with python-shell? I’ve tried different versions and installing through different directories without any success. I’ve also tried clean installs of Magic Mirror but that doesn’t help either.
        After some faffing with the config to get the MM to load I am also getting this same error message when MM now loads.
        From what I can see it is pulling the auth tokens correctly and is also able to run the getData.ph as running this on its own returns my total lack of steps etc. But the figures are not updating on MM, I’m assuming this is because of the above error messages.
        I was able to get past PythonShell.run is not a function by altering line 9 in the node_helper.js to be:
        let {PythonShell} = require(‘python-shell’)
        However doing this then gave other error messages relating to code in other files, kind of making me think that this was the wrong thing to do. I’m assuming I am missing something obvious.
        Does anyone have any suggestions?
        I’ve been struggling with this as well with no resolution. Pinging to see if anyone can provide some guidance.
        Notes:
        • brand new Raspian installation on pi 3, B+
        • manual installation of Magic Mirror meticulously following instructions (note: the auto-install did not work due to issues with missing npm)
        • installed MMM-Fitbit per instructions and have successfully executed getData.py and seen my correct fitbit data (i.e. all the registration and tokens have worked)
        • trying to “npm install python-shell” from within the MMM-Fitbit directory has errors as previously described by other users
        • doing “npm install python-shell” from the MagicMirror directory will succeed but I’ve no idea if this is where it should be done instead. After install, the following has been created: ~/MagicMirror/node_modules/python-shell
        I’ve tried re-installing from scratch several times to make sure I’m following instructions closely but no luck. Any guru guidance would be appreciated!
        Thanks, Peter.
          sameer-t @MMMveasy
          @MMMveasy said in Fitbit:
          hi everyone
          1. cd MagicMirror
          2. mkdir Test
          3. cd Test
          This worked for me! Thank you!!
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor
            Hi is the module still working ?.???.
            • V Offline
              voodew @bhepler
              @bhepler
              This post helped me the most.
              • Example config file on the module GitHub page contains errors. The character after config: should be {, not [
              • The secret key and appID field values need to be surrounded by single quotes, something not explained in the readme file.
              Thank you.
              • Arno-StrasbourgA Offline
                Arno-Strasbourg
                Hi guys,
                I don’t know if the module is still maintained. But I have just implemented it. I have got the credentiels. I have put the code in the config.js file. It works fine but I have no datas refresh and an error in the log :
                0|mm | [2020-05-10 13:41:56.342] [ERROR] TypeError: PythonShell.run is not a function
                0|mm | at Class.setCreds (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:32:15)
                0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:18:9)
                0|mm | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
                0|mm | at Socket.emit (events.js:200:13)
                0|mm | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                0|mm | at processTicksAndRejections (internal/process/task_queues.js:82:9)
                0|mm | [2020-05-10 13:41:56.380] [ERROR] TypeError: PythonShell is not a constructor
                0|mm | at Class.getData (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:43:25)
                0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:22:9)
                0|mm | [2020-05-10 13:43:43.317] [LOG]
                0|mm | Set credential request recieved.
                0|mm | [2020-05-10 13:43:43.318] [LOG]
                0|mm | {
                0|mm | client_id: '22BR8T',
                0|mm | client_secret: '51313d185cxxxxxxxxxxxxxxxxd141c99'
                0|mm | }
                0|mm | [2020-05-10 13:43:43.329] [LOG]
                0|mm | Whoops! There was an uncaught exception...
                0|mm | [2020-05-10 13:43:43.330] [ERROR] TypeError: PythonShell.run is not a function
                0|mm | [2020-05-10 13:43:43.334] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm | [2020-05-10 13:43:43.335] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm | [2020-05-10 13:43:43.336] [LOG] Initial run request recieved.
                0|mm | [2020-05-10 13:43:43.338] [LOG] Running getData.py
                0|mm | [2020-05-10 13:43:43.339] [LOG] Whoops! There was an uncaught exception...
                0|mm | [2020-05-10 13:43:43.342] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|mm | [2020-05-10 13:43:43.342] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|mm | [2020-05-10 13:43:43.344] [LOG] [NewPIR] Initialize...
                0|mm | [2020-05-10 13:43:43.340] [ERROR] TypeError: PythonShell is not a constructor
                Do someone has any idea of that error ?
                  Stoffbeuteluwe Project Sponsor @Arno-Strasbourg
                  @Arno-Strasbourg Hey, please install MMM-Fitbit2 that works perfect.:thumbs_up_medium-light_skin_tone:
                    Arno-Strasbourg
                    Oh ! There is an other app !! Where can I found it ? It isn’t on the gitub third party modules ?
                    Edit : Got it ! Thank you @Stoffbeuteluwe
                      @Arno-Strasbourg https://github.com/m-roberts/MMM-Fitbit2
                        Arno-Strasbourg
                        Yes I confirm, it works very well !! Thank you very much !!
                        Just a small question, I put it on the bottom_bar, but it appear on the bottom left.
                        How can i center it please ? with the MMM-Fitbit2.css or custom.css ? and wich command to add ?
                        That makes 2 questions in fact ! :face_with_hand_over_mouth:
                          @Arno-Strasbourg you can try bottom_center
                          Arno-StrasbourgA 1 Reply Last reply Reply Quote 0
                            Arno-Strasbourg @Stoffbeuteluwe
                            @Stoffbeuteluwe It isn’t exactly the bottom bar. But it’s ok. It will be good for me.
                            Thank you !
                            • 7 / 7
