npm ERR! missing script: start
as the heading says, i have a problem starting my module. npm start causes the following error:
here is my package.json file:{ "name": "emetalcharts", "version": "1.0.0", "description": "charting commodity prices", "main": "emetalcharts.js", "private": "true", "scripts": { "test": "echo \"Error: no test specified\" && exit 1" }, "repository": { "type": "git", "url": "git+https://github.com/sdetweil/SampleModule.git" }, "author": "", "license": "MIT", "bugs": { "url": "https://github.com/sdetweil/SampleModule/issues" }, "homepage": "https://github.com/sdetweil/SampleModule#readme", "dependencies": { "chart.js": "^2.5.0", "sqlite3": "^4.2.0" } }the following is recommended on many websites:
"scripts": { "test": "echo \"Error: no test specified\" && exit 1", "start" : "node ." },this then causes the following error message :
Module.register("emetalcharts", { ^ ReferenceError: Module is not definedI’m done. Who can help me ?
could it also be a version conflict?
my versions:$ node --version v10.20.1 $ npm --version 6.14.5Thanks in advance
so long -
@Perlchamp - Did you run
npm installinside the module folder? -
yes, of course. thank you
this did install the node_module folder in my module folder -
@Perlchamp Are you running
npm startinside the module folder?
I’m not an expert on this, but I think Module is a class that belongs to the MagicMirror environment. Your module as a standalone does not know what to do with it.
If you runnpm startin the MagicMirror folder, it would recognize the code. -
yes, of course. thank you.
