    Cronjob doesn't work with my MM
    16 Posts 7 Posters 2.8k Views 7 Watching
      MisterT
      Hi everybody
      I have a problem with crontab and cronjob. My magicmirror doesn’t stop or refresh or restart or start with a cronjob.
      I search a solution on the forum but i still have the problem
      I use crontab -e without sudo and pm2 launch my magicmirror in /home/pi/MagicMirror
      my crontab seems like:
      # m h  dom mon dow   command
      01 00 * * *   pi     /home/pi/pm2 stop MagicMirror
      03 00 * * *   pi     /home/pi/pm2 reload MagicMirror
      00 08 * * *   pi     /home/pi/pm2 stop MagicMirror
      03 08 * * *   pi     /home/pi/pm2 reload MagicMirror
      52 14 * * *   pi     pm2 stop MagicMirror >/dev/null 2>&1
      18 20 * * *   pi     /home/pi/MagicMirror/pm2 start MagicMirror
      i try different solution but nothing happens.
      Can anybody help me please?
      Thx for next answers
        does anything show in the pm2 logs?
        pm2 logs --lines=100 (or more)
        pm2 is sensitive to the user who created the entries (pm2 start/save), as they are stored in the users home folder in .pm2 (notice the dot in the start of the name)
          MisterT
          ok so with this crontab
          51 15 * * * pi pm2 stop MagicMirror >/dev/null 2>&1
          53 15 * * * pi pm2 start MagicMirror
          i have in .pm2/logs
          2020-05-16T14:49:45: PM2 log: App [MagicMirror:0] starting in -fork mode-
          2020-05-16T14:49:45: PM2 log: App [MagicMirror:0] online
          2020-05-16T14:52:43: PM2 log: Stopping app:MagicMirror id:0
          2020-05-16T14:52:44: PM2 log: pid=15018 msg=failed to kill - retrying in 100ms
          2020-05-16T14:52:44: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          2020-05-16T14:52:44: PM2 log: pid=15018 msg=process killed
          2020-05-16T15:39:20: PM2 log: [PM2] This PM2 is not UP TO DATE
          2020-05-16T15:39:20: PM2 log: [PM2] Upgrade to version 4.4.0
          2020-05-16T15:49:50: PM2 log: App [MagicMirror:0] starting in -fork mode-
          2020-05-16T15:49:50: PM2 log: App [MagicMirror:0] online
          2020-05-16T15:55:25: PM2 log: Stopping app:MagicMirror id:0
          2020-05-16T15:55:26: PM2 log: pid=16655 msg=failed to kill - retrying in 100ms
          2020-05-16T15:55:26: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          2020-05-16T15:55:26: PM2 log: pid=16655 msg=process killed
          and cron logs:
          May 16 15:48:21 raspberrypi crontab[16627]: (pi) BEGIN EDIT (pi)
          May 16 15:49:40 raspberrypi crontab[16627]: (pi) REPLACE (pi)
          May 16 15:49:40 raspberrypi crontab[16627]: (pi) END EDIT (pi)
          May 16 15:50:01 raspberrypi cron[410]: (pi) RELOAD (crontabs/pi)
          May 16 15:51:02 raspberrypi CRON[17002]: (pi) CMD (pi     pm2 stop MagicMirror >/dev/null 2>&1)
          May 16 15:53:01 raspberrypi CRON[17032]: (pi) CMD (pi     pm2 start MagicMirror)
          May 16 15:53:01 raspberrypi CRON[17026]: (CRON) info (No MTA installed, discarding output)
          so i don’t understand nothing on pm2 but cronjob seems to work
          Have you an idea?
            sdetweil @MisterT
            @MisterT do a pm2 flush to clear the log, then also show the error log… (its above the log output)
            or look at the files in the ~/./pm2/logs folder
            i looks like it works
              MisterT
              ok so with pm2 flush and this crontab
              52 12 * * *   pi     pm2 stop MagicMirror >/dev/null 2>&1
              54 12 * * *   pi     pm2 start MagicMirror
              the pm2 logs :
              pm2 errors
              [12:51:04.343] [ERROR]  ERROR! Could not find main module js file for MMM-GooglemapsTraffic.original
              ATTENTION: default value of option force_s3tc_enable overridden by environment.
              [12:51:08.418] [ERROR]  ERROR! Could not find main module js file for MagicMirror-Display-Controller
              [12:51:09.801] [ERROR]  ERROR! Could not find main module js file for fabio
              [12:51:21.774] [ERROR]  (node:25245) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
              [12:51:35.140] [ERROR]  Error: status code: 401
                  at /home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/omdb/index.js:211:25
                  at done (/home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/needle/lib/needle.js:432:14)
                  at PassThrough.<anonymous> (/home/pi/MagicMirror/modules/MMM-FreeBox-Monitor/node_modules/needle/lib/needle.js:671:11)
                  at PassThrough.emit (events.js:182:13)
                  at endReadableNT (_stream_readable.js:1090:12)
                  at process._tickCallback (internal/process/next_tick.js:63:19)
              pm2 out
              > magicmirror@2.10.1 start /home/pi/MagicMirror
              > ./run-start.sh
              [12:50:32.600] [LOG]    Starting MagicMirror: v2.10.1
              [12:50:32.632] [LOG]    Loading config ...
              [12:50:32.668] [LOG]    Loading module helpers ...
              [12:50:32.670] [LOG]    No helper found for module: alert.
              [12:50:32.820] [LOG]    Initializing new module helper ...
              [12:50:32.826] [LOG]    Module helper loaded: updatenotification
              [12:50:32.829] [LOG]    No helper found for module: clock.
              [12:50:34.340] [LOG]    Initializing new module helper ...
              [12:50:34.341] [LOG]    Module helper loaded: calendar
              [12:50:34.343] [LOG]    No helper found for module: weatherforecast.
              [12:50:34.471] [LOG]    Initializing new module helper ...
              [12:50:34.472] [LOG]    Module helper loaded: newsfeed
              [12:50:34.483] [LOG]    No helper found for module: MMM-Globe.
              [12:50:35.854] [LOG]    Initializing new module helper ...
              [12:50:35.856] [LOG]    Module helper loaded: MMM-MovieListings
              [12:50:35.862] [LOG]    No helper found for module: MMM-Scrobbler.
              [12:50:37.296] [LOG]    Initializing new module helper ...
              [12:50:37.297] [LOG]    Module helper loaded: MMM-soccer
              [12:50:44.499] [LOG]    Initializing new module helper ...
              [12:50:44.501] [LOG]    Module helper loaded: MMM-News
              [12:50:44.521] [LOG]    Initializing new module helper ...
              [12:50:44.528] [LOG]    Module helper loaded: WallberryTheme
              [12:50:44.532] [LOG]    No helper found for module: WB-clock.
              [12:50:44.541] [LOG]    Initializing new module helper ...
              [12:50:44.543] [LOG]    Module helper loaded: WB-weather
              [12:50:44.578] [LOG]    Initializing new module helper ...
              [12:50:44.580] [LOG]    Module helper loaded: MMM-GroveGestures
              [12:50:45.966] [LOG]    Initializing new module helper ...
              [12:50:45.967] [LOG]    Module helper loaded: MMM-AQI
              [12:50:48.096] [LOG]    Initializing new module helper ...
              [12:50:48.099] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.10.1
              [12:50:48.101] [LOG]    Version is ok!
              [12:50:48.102] [LOG]    Module helper loaded: MMM-Strava
              [12:50:48.834] [LOG]    Initializing new module helper ...
              [12:50:48.836] [LOG]    Module helper loaded: MMM-GooglePhotos
              [12:50:51.424] [LOG]    Initializing new module helper ...
              [12:50:51.426] [LOG]    Module helper loaded: MMM-FreeBox-Monitor
              [12:50:51.428] [LOG]    No helper found for module: currentweather.
              [12:50:51.434] [LOG]    No helper found for module: domoticz.
              [12:50:51.692] [LOG]    Initializing new module helper ...
              [12:50:51.694] [LOG]    Module helper loaded: MMM-ModuleScheduler
              [12:50:51.935] [LOG]    Initializing new module helper ...
              [12:50:51.936] [LOG]    Module helper loaded: MMM-Remote-Control
              [12:50:53.520] [LOG]    Initializing new module helper ...
              [12:50:53.522] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
              [12:50:54.681] [LOG]    Initializing new module helper ...
              [12:50:54.687] [LOG]    Module helper loaded: MMM-COVID19-SPARKLINE
              [12:50:55.499] [LOG]    Initializing new module helper ...
              [12:50:55.500] [LOG]    Module helper loaded: MMM-Hotword
              [12:51:01.172] [LOG]    Initializing new module helper ...
              [12:51:01.173] [LOG]    Module helper loaded: MMM-AssistantMk2
              [12:51:01.176] [LOG]    No helper found for module: MMM-pages.
              [12:51:01.180] [LOG]    No helper found for module: MMM-page-indicator.
              [12:51:01.182] [LOG]    All module helpers loaded.
              [12:51:01.187] [LOG]    Starting server on port 8080 ...
              [12:51:01.197] [INFO]   You're using a full whitelist configuration to allow for all IPs
              [12:51:01.210] [LOG]    Server started ...
              [12:51:01.215] [LOG]    Connecting socket for: updatenotification
              [12:51:01.219] [LOG]    Connecting socket for: calendar
              [12:51:01.222] [LOG]    Starting node helper for: calendar
              [12:51:01.225] [LOG]    Connecting socket for: newsfeed
              [12:51:01.228] [LOG]    Starting module: newsfeed
              [12:51:01.230] [LOG]    Connecting socket for: MMM-MovieListings
              [12:51:01.231] [LOG]    MMM-MovieListing helper started...
              [12:51:01.233] [LOG]    Connecting socket for: MMM-soccer
              [12:51:01.234] [LOG]    Starting module: MMM-soccer
              [12:51:01.235] [LOG]    Connecting socket for: MMM-News
              [12:51:01.237] [LOG]    Connecting socket for: WallberryTheme
              [12:51:01.238] [LOG]    Starting module helper: WallberryTheme
              [12:51:01.239] [LOG]    Connecting socket for: WB-weather
              [12:51:01.242] [LOG]    Connecting socket for: MMM-GroveGestures
              [12:51:01.245] [LOG]    Connecting socket for: MMM-AQI
              [12:51:01.247] [LOG]    MMM-AQI helper started ...
              [12:51:01.250] [LOG]    Connecting socket for: MMM-Strava
              [12:51:01.253] [LOG]    Starting module helper: MMM-Strava
              [12:51:01.258] [LOG]    Connecting socket for: MMM-GooglePhotos
              [12:51:01.261] [LOG]    Connecting socket for: MMM-FreeBox-Monitor
              [12:51:01.265] [LOG]    Starting module: MMM-FreeBox-Monitor
              [12:51:01.266] [LOG]    Connecting socket for: MMM-ModuleScheduler
              [12:51:01.267] [LOG]    Starting node helper for: MMM-ModuleScheduler
              [12:51:01.269] [LOG]    Connecting socket for: MMM-Remote-Control
              [12:51:01.270] [LOG]    Starting node helper for: MMM-Remote-Control
              [12:51:01.293] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
              [12:51:01.296] [LOG]    Connecting socket for: MMM-COVID19-SPARKLINE
              [12:51:01.297] [LOG]    Starting node helper for: MMM-COVID19-SPARKLINE
              [12:51:01.298] [LOG]    Connecting socket for: MMM-Hotword
              [12:51:01.299] [LOG]    [HOTWORD] MMM-Hotword starts
              [12:51:01.301] [LOG]    Connecting socket for: MMM-AssistantMk2
              [12:51:01.302] [LOG]    Sockets connected & modules started ...
              [12:51:02.126] [LOG]    Launching application.
              [12:51:20.629] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/lxxxxxxx/basic.ics - Interval: 300000
              [12:51:20.672] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxxxx/basic.ics - Interval: 300000
              [12:51:20.866] [LOG]    Create new news fetcher for url: https://www.francetvinfo.fr/titres.rss - Interval: 300000
              [12:51:21.153] [LOG]    Get league table for url http://api.football-data.org/v2/competitions/FL1/standings
              [12:51:21.209] [LOG]    [NEWS] Initialized.
              [12:51:21.298] [LOG]    FREEBOX: "CONNECT" [object Object]
              [12:51:21.308] [LOG]    { track_id: 0,
                app_token:
                 'rxxxxxxx,
                appId: 'fr.freebox',
                challenge: 'xxxxxxxxxxx',
                session_token:
                 'xa5r1W+kxfU+tnnR9U/10YzBJ1/xxxxxxxx }
              [12:51:21.355] [LOG]    MMM-ModuleScheduler is removing all scheduled jobs
              [12:51:21.356] [LOG]    MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
              [12:51:21.360] [LOG]    MMM-ModuleScheduler is scheduling SHOW_ALERT using "35 11 * * *
              [12:51:21.445] [LOG]    MMM-ModuleScheduler has scheduled SHOW_ALERT
              [12:51:21.461] [LOG]    MMM-ModuleScheduler will next send SHOW_ALERT at Mon May 18 2020 11:35:00 GMT+0200 (CEST)
              [12:51:21.463] [LOG]    MMM-ModuleScheduler is scheduling SHOW_ALERT using "13 15 * * *
              [12:51:21.477] [LOG]    MMM-ModuleScheduler has scheduled SHOW_ALERT
              [12:51:21.485] [LOG]    MMM-ModuleScheduler will next send SHOW_ALERT at Sun May 17 2020 15:13:00 GMT+0200 (CEST)
              [12:51:21.486] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "55 11 * * *
              [12:51:21.502] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
              [12:51:21.540] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Mon May 18 2020 11:55:00 GMT+0200 (CEST)
              [12:51:21.544] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "00 08 * * *
              [12:51:21.556] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
              [12:51:21.570] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Mon May 18 2020 08:00:00 GMT+0200 (CEST)
              [12:51:21.573] [LOG]    MMM-ModuleScheduler is scheduling REMOTE_ACTION using "00 19 * * *
              [12:51:21.583] [LOG]    MMM-ModuleScheduler has scheduled REMOTE_ACTION
              [12:51:21.587] [LOG]    MMM-ModuleScheduler will next send REMOTE_ACTION at Sun May 17 2020 19:00:00 GMT+0200 (CEST)
              [12:51:21.642] [LOG]    [COVID:CORE] Scan starts.
              [12:51:21.739] [LOG]    [HOTWORD] Recipe is loaded: with-AMk2v3_Jarvis.js
              [12:51:22.200] [LOG]    CallbackGetChallenge -> [object Object]
              [12:51:22.722] [LOG]    Electron's cache successfully cleared.
              [12:51:23.375] [LOG]    Refreshed access token because it has expired. Expired at: 12:51:21 now is: 12:51:23
              [12:51:25.260] [LOG]    [NEWS] Articles are aggregated :  45
              [12:51:25.784] [LOG]    [HOTWORD] begins.
              [12:51:25.788] [LOG]    [HOTWORD] Detector starts listening.
              [12:51:26.050] [LOG]    [COVID:CORE] Access to data source.
              [12:51:27.283] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_deaths_global.csv
              [12:51:27.963] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_recovered_global.csv
              [12:51:30.338] [LOG]    [COVID:CORE] Resolving: csse_covid_19_data/csse_covid_19_time_series/time_series_covid19_confirmed_global.csv
              [12:51:30.422] [LOG]    can't find property recovered Canada:
              [12:51:30.423] [LOG]    adding...
              [12:51:30.677] [LOG]    [COVID:CORE] Calculating Wordlwide total.
              [12:51:30.888] [LOG]    [COVID:CORE] Scan Completed.
              [12:51:33.466] [LOG]    [AMK2] MMM-AssistantMk2 Version: 3.3.0
              [12:51:33.478] [LOG]    [AMK2] Response delay is set to 0.5 second
              [12:51:33.481] [LOG]    [AMK2] Use HTML5 for audio response
              [12:51:33.496] [LOG]    [AMK2] RECIPE_LOADED: with-MMM-Hotword.js
              [12:51:33.498] [LOG]    [AMK2] NO_ACTION_TO_MANAGE
              [12:51:33.521] [LOG]    [AMK2] ASSISTANT_WEB Started
              [12:51:33.538] [LOG]    [AMK2] AssistantMk2 is initialized.
              [12:51:33.906] [LOG]    FREEBOX: "GET_CALLS" [object Object]
              [12:51:33.960] [LOG]    FREEBOX: "GET_DOWNLOADS" [object Object]
              [12:51:34.090] [LOG]    FREEBOX: "GET_CONNECTIONSTATUS" [object Object]
              [12:55:40.854] [LOG]    Shutting down server...
              [12:55:40.865] [LOG]    Stopping module helper: updatenotification
              [12:55:40.876] [LOG]    Stopping module helper: calendar
              [12:55:40.882] [LOG]    Stopping module helper: newsfeed
              [12:55:40.884] [LOG]    Stopping module helper: MMM-MovieListings
              [12:55:40.886] [LOG]    Stopping module helper: MMM-soccer
              [12:55:40.891] [LOG]    Stopping module helper: MMM-News
              [12:55:40.897] [LOG]    Stopping module helper: WallberryTheme
              [12:55:40.903] [LOG]    Stopping module helper: WB-weather
              [12:55:40.914] [LOG]    Stopping module helper: MMM-AQI
              [12:55:40.916] [LOG]    Stopping module helper: MMM-Strava
              [12:55:40.918] [LOG]    Stopping module helper: MMM-GooglePhotos
              [12:55:40.920] [LOG]    Stopping module helper: MMM-FreeBox-Monitor
              [12:55:40.921] [LOG]    Stopping module helper: MMM-ModuleScheduler
              [12:55:40.932] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
              [12:55:40.936] [LOG]    Stopping module helper: MMM-COVID19-SPARKLINE
              [12:55:40.941] [LOG]    Stopping module helper: MMM-Hotword
              [12:55:40.946] [LOG]    Stopping module helper: MMM-AssistantMk2
              and cron log
              May 17 12:49:33 raspberrypi crontab[25141]: (pi) BEGIN EDIT (pi)
              May 17 12:50:12 raspberrypi crontab[25141]: (pi) REPLACE (pi)
              May 17 12:50:12 raspberrypi crontab[25141]: (pi) END EDIT (pi)
              May 17 12:51:01 raspberrypi cron[410]: (pi) RELOAD (crontabs/pi)
              May 17 12:52:01 raspberrypi CRON[25574]: (pi) CMD (pi     pm2 stop MagicMirror >/dev/null 2>&1)
              May 17 12:54:01 raspberrypi CRON[25592]: (pi) CMD (pi     pm2 start MagicMirror)
              May 17 12:54:01 raspberrypi CRON[25582]: (CRON) info (No MTA installed, discarding output)
              Do you see something wrong ?
                @MisterT said in Cronjob doesn't work with my MM:
                you should add
                disabled: true,
                to those three modules in you config.js
                right after the module name
                the times don’t line up on the reports…
                cron log
                pm2 log
                take this off the shutdown command
                add a couple commands to the cron right in front of the shutdown
                pm2 info 0
                pm2 status 0
                these should output to the cron log
                  chassain 0 @MisterT
                  @MisterT
                  PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
                  SHELL=/bin/bash
                  0 20 * * * pm2 stop mm
                  0 6 * * 1-5 pm2 start mm
                    MisterT
                    @chassain-0 i tried your solution but still not work, same with pm2 stop/start MagicMirror
                    @sdetweil with this cron
                    44 18 * * * pi pm2 start MagicMirror > pm2 status 0
                    or
                    46 18 * * * pi pm2 start MagicMirror > pm2 info 0
                    i had a log in pi folder at the same time but a blank log
                    I tested my cron with a simple Hello word .py and cronjob works.
                    have you an other solution ?
                      sdetweil @MisterT
                      @MisterT pm2 is a big node application, so if needs to be in the right folder and process
                      • T Offline
                        Tribun
                        Hello MisterT
                        I’m not an expert, I’m more of a beginner, but I tried to use a cronjob to stop and start the mirror on my mirror.
                        10 23 * * * pm2 stop mm> / dev / null 2> & 1
                        15 23 * * * pm2 start mm> / dev / null 2> & 1
                        it worked for me.
                        I use the MagicMirror² v2.11.0 and NAME = “Raspbian GNU / Linux”
                        VERSION_ID = “10”
                        VERSION = “10 (buster)”
                        VERSION_CODENAME = buster.
                        With older versions of the software I always had problems starting MagicMirror because of access violations with pm2 after a reboot.
                        Maybe this will help you solve your problem.
