    Euromillions display on MagicMirror
    24 Posts 7 Posters 8.7k Views 8 Watching
    • thymonT Offline
      thymon
      Hi all,
      First, sorry for my english.
      I would like to do appear the last Euromillions’ numbers.
      Is it possible ?
      I found one flux RSS. But this RSS is for the last 15.
      I need juste the last.
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @thymon
        @thymon I almost deleted your post as it didn’t appear to be about MM. but I saw you have posted a few times and recently about the fonts…
        so I edited the title of your post…
        thymonT 1 Reply Last reply Reply Quote 0
        • thymonT Offline
          thymon @sdetweil
          Ok Thank you.
          • lavolp3L Offline
            lavolp3 Module Developer @thymon
            @thymon It is a good very good idea. Not for me but for people who play the lottery.
            There is a free lottery API that supports lots of lotteries, including yours
            magayo.com/lottery-docs/api/content/
            That might be a good start I guess.
            I’m happy to support but not sure if I can find time to write a module.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • thymonT Offline
              thymon
              @lavolp3 thanks for you interest.
              I have some time, but I’m not a developper :P :D
              • lavolp3L Offline
                @thymon I put in some first thoughts on this.
                The problem is for anyone who changes their own numbers, how to implement this.
                This person would need to put the numbers into the config every time.
                But still a great idea, especially for anyone having fixed numbers.
                Already started a project :-)
                • thymonT Offline
                  thymon @lavolp3
                  @lavolp3 How does Gooogle get the info?
                  I found this : https://rapidapi.com/creativesolutions/api/euromillions
                  • lavolp3L Offline
                    @thymon I tried out the magayo api and had the module near completion, and then found out magayo only takes 10 API calls PER MONTH in their free plan.
                    These are exhausted for me so I need to think about using another API or some dummy data.
                    I am quite far on a module, but I would prefer to include more lotteries than just euromillions. So if you could research for an API and provide one that covers more lotteries I’d be grateful.
                    • thymonT Offline
                      thymon @lavolp3
                      @lavolp3
                      I found 10 request/month too :(
                      https://collectapi.com/api/chancegame/lottery-api
                      But there are 2 results per week for the Euro Millions.
                      :P
                      • lavolp3L Offline
                        @thymon 10 requests/month is very difficult to manage.
                        You need to consider that every time the mirror gets restarted for whatever reason it will have forgotten the data and needs to send a new API request.
                        A nightmare for people debugging or developing something.
                        thymonT cowboysdudeC 2 Replies Last reply Reply Quote 1
                        • thymonT Offline
                          thymon @lavolp3
                          @lavolp3
                          Yes, I understand…
                          • thgmirrorT Offline
                            thgmirror
                            Why don’t you create a local html-page on the RPI and display it with MMM-SmartWebDisplay?
                            • Look for a website with the requested information (for example lottoland)
                            • in your local web-page, call this site and crop it to the part you need using iFrame
                            • use MMM-SmartWebDisplay and link to the local html…in the config write url: [“/modules/millions.html”] if you place your local html in the modules folder
                            no api, no problem, works with nearly every webpage
                            • lavolp3L Offline
                              lavolp3 Module Developer @thgmirror
                              @thgmirror
                              Of course that’s a solution. From my point of view however not a nice one. Styling is a mess and it also creates some work. And everyone wanting to use it would have the work.
                              With a proper module the community has less work and it can be integrated and styled much better.
                              For @thymon s purpose it works of course.
                                chassain 0 @thymon
                                @thymon
                                i 'm using the module MMM-smartwebdisplay to display some web url on my magicmirror, like sncf, magicmirror,…
                                You can use this for the moment with this configuration
                                			module: 'MMM-SmartWebDisplay',//
                                			disabled: false,
                                			position: 'right',	// This can be any of the regions.
                                				logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                                				height:"550", //hauteur du cadre en pixel ou %
                                				width:"500", //largeur
                                               				updateInterval: 10, //in min. Set it to 0 for no refresh (for videos)
                                                				NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                                				displayLastUpdate: false, //to display the last update of the URL
                                				displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                                                				url: ["https://tirage-gagnant.com/euromillions/resultats-euromillions/"], //source of the URL to be displayed
                                                				scrolling: "no" // allow scrolling or not. html 4 only
                                change options like you want…It’s just an idea for you…Have fun !
                                lavolp3L thymonT 2 Replies Last reply Reply Quote 1
                                • lavolp3L Offline
                                  lavolp3 Module Developer @chassain 0
                                  @chassain-0 That looks really good.
                                  @thymon I have pushed my initial work to
                                  https://github.com/lavolp3/MMM-Lotteries
                                  But as said, the API usage is not acceptable yet.
                                  Working with dummy data. it looks like this for now.
                                  S thymonT 2 Replies Last reply Reply Quote 0
                                    sdetweil @lavolp3
                                    @lavolp3 when would it change? in node_helper only download then and use the file as the data source
                                    • lavolp3L Offline
                                      It is possible, and I thought about the same, but it’s dirty and you somehow have to determine and hard-code a proper request time for every lottery.
                                      Thinking about developing it to the end but I’d prefer another API.
                                        [[global:former-user]] @lavolp3
                                        @lavolp3
                                        Just Idea. store recent lottery values from API with the date as JSON file, Then when you need new values (on restart or on every Sunday), Check the JSON file first then request API when the stored data is out-of-dated.
                                        PS Ah, you’ve already approached. :) Don’t mind.
                                        • lavolp3L Offline
                                          lavolp3 Module Developer @Guest
                                          @Sean it is a good idea but you want to meet the perfect time to fetch the data (close to the drawing) and you only have one try…
                                          And also a second lottery would already blow the quota.
                                          But still, thanks for the good ideas
                                          • thymonT Offline
                                            thymon @lavolp3
                                            @lavolp3 You are my man ! :D
