Config Help!
9 Posts 5 Posters 8.8k Views 3 Watching
  • I Offline
    IArentBen
    Morning everyone!
    I’ve been trying to get my mirror running for the past few days but I am stumped! I cant get my config file to work the Magic Mirror screen pops up and says if you have a config file to lint it and I have. I rant the pm2 log and i says “mm-0 (err): WARNING! Could not find config. Please create one.”
    Would you please take a peek at my config file for me? If i missed an obvious step please let me know!
    var config = {
    	port : 8080,
    	language : 'en',
    	timeFormat : 24,
    	units : 'metric',
    	modules : [{
    			module : 'clock',
    			position : 'top_left'
    			config : {
    				timeFormat : 24,
    				displaySeconds : false,
    				showPeriod : false,
    				showPeriodUpper : false
    			module : 'calendar',
    			header : 'Calendar',
    			position : 'top_left',
    			config : {
    				calendars : [{
    						symbol : 'calendar-check-o',
    						url : 'webcal://www.calendarlabs.com/templates/ical/Canada-Holidays.ics'
    				maximumEntries : 10,
    				maximumNumberOfDays : 365,
    				displaySymbol : true,
    				defaultSymbol : calendar,
    				maxTitleLength : 25,
    				fetchInterval : 900000,
    				animationSpeed : 2000,
    				fade : true,
    				fadePoint : 0.25,
    				loadingText : 'Loading...',
    				emptyCalendarText : 'No Text to Display...',
    				todayText : 'Today',
    				tomorrowText : 'Tomorrow',
    				runningText : 'coming up'
    			module : 'currentweather',
    			position : 'top_right',
    			config : [{
    					appid : '6160806',
    					units : metric,
    					updateInterval : 900000,
    					timeFormat : 24,
    					showPeriod : false,
    					showPeriodUpper : false,
    					lang : en,
    					initialLoadDelay : 0,
    					retryDelay : 2500,
    					apiVersion : 2.5,
    					apiBase : 'http://api.openweathermap.org/data/',
    					weatherEndpoint : 'weather',
    					iconTable : {
    						'01d' : 'wi-day-sunny',
    						'02d' : 'wi-day-cloudy',
    						'03d' : 'wi-cloudy',
    						'04d' : 'wi-cloudy-windy',
    						'09d' : 'wi-showers',
    						'10d' : 'wi-rain',
    						'11d' : 'wi-thunderstorm',
    						'13d' : 'wi-snow',
    						'50d' : 'wi-fog',
    						'01n' : 'wi-night-clear',
    						'02n' : 'wi-night-cloudy',
    						'03n' : 'wi-night-cloudy',
    						'04n' : 'wi-night-cloudy',
    						'09n' : 'wi-night-showers',
    						'10n' : 'wi-night-rain',
    						'11n' : 'wi-night-thunderstorm',
    						'13n' : 'wi-night-snow',
    						'50n' : 'wi-night-alt-cloudy-windy'
    			module : 'newsfeed',
    			position : 'bottom_bar',
    			config : {
    				feeds : [{
    						title : "CBC Top Stories",
    						url : "http://rss.cbc.ca/lineup/topstories.xml",
    						title : "CBC Calgary",
    						url : "http://rss.cbc.ca/lineup/canada-calgary.xml",
    						title : "CBC World Stories",
    						url : "http://rss.cbc.ca/lineup/World.xml",
    				showSourceTitle : true,
    				showPublishDate : true,
    				showDescription : true,
    				reloadInterval : 900000,
    				updateInterval : 300000,
    if (typeof module !== 'undefined') {
    	module.exports = config;
    Note from admin: Please use Markdown on code snippets so it is easier to read!
    • F Offline
      feuerball
      did you rename your config.js.sample to config.js?
      I 1 Reply Last reply May 17, 2016, 7:13 PM Reply Quote 1
        PtrBld Module Developer
        There is a , missing After Position: line 8
        I 1 Reply Last reply May 17, 2016, 7:16 PM Reply Quote 0
        • I Offline
          IArentBen @feuerball
          @feuerball sure did!
          • I Offline
            IArentBen @PtrBld
            @PtrBld thanks but that didn’t do it either
            • K Offline
              KirAsh4 Moderator
              You’re missing commas between your feed definitions.
              feeds: [
                              title: "..."
                              url: "..."
                      },      //  <--- you're missing commas there
                              title: "..."
                              url: "..."
              • K Offline
                KirAsh4 Moderator
                Also, you are not required to enter all of those weather parameters unless you are actually changing them. Bare minimum all you need is your location and your API ID. The iconTable, apiBase, Version, all of those things are already defined for you. Only if you want to change the defaults do you have to define them.
                  MichMich Admin
                  Best way to check your config.js is to check it using jshint.com or jslint.com - they will show you the errors if there are any.
                  I 1 Reply Last reply May 18, 2016, 11:52 AM Reply Quote 0
                  • I Offline
                    IArentBen @MichMich
                    @MichMich I tried the jshint and jslint but, was not successful because of my lack of knowledge in this language. I fixed it but basically scrapping the whole file and doing one section at a time. I learnt a whole lot in two hours though haha
