    Help creating a shutdown button?
    troubleshoothelpbuttonswitchshutdown
    7 Posts 3 Posters 6.1k Views 3 Watching
      bez252
      Hi, I am trying to add a button/switch to my mirror for safe shutdown. I am using RPi3 model B.
      I have this: https://www.amazon.com/gp/product/B0170B75EU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
      The problem I am having is with adding the code to make it function as a shutdown button.
      Full disclosure: I know absolutely nothing about how to use python.
      Any help you can provide would be appreciated.
        Jopyth Moderator @bez252
        @bez252 I made a module (acutally two) for this, however they are not (very well) documented and I just made them for myself. But if you want, I could upload them.
        I have four buttons conncted to the RPi, and one of them shuts down the system on a long press (>3 seconds).
        There is also this module, which you can adapt by adding a shutdown command.
          bez252 @Jopyth
          @Jopyth
          That would be awesome, thanks.
            pugsly
            I got one of these for my mirror, still havn’t built or assembled it yet.
            https://www.pi-supply.com/product/pi-supply-raspberry-pi-power-switch/
              bez252 @Jopyth
              @Jopyth So, with the module you linked, would these default settings mean that it activates when pin 5 is grounded? I apologize for all these dumb questions. Iḿ really new to this entire scene. Also, what would I need to change to make it shutdown?
              ´/* global Module */
              /* Magic Mirror
              • Module: MMM-Button
              • MIT Licensed.
              Module.register(‘MMM-Button’,{
              defaults: {
              buttonPIN: 5,
              //time in miliseconds before another button click is recognized
              clickDelay: 500,
              // Override socket notification handler.
              if (notification === “BUTTON_PRESSED”){
              this.sendNotification(notification, payload)
              start: function() {
              this.sendSocketNotification(‘BUTTON_CONFIG’, this.config);
              Log.info('Starting module: ’ + this.name);
                bez252
                Also, would these instructions work with the button I have?: http://www.mausberrycircuits.com/pages/setup
                Or would they only work with the mausberry circuits buttons that attach to the power cord?
                  @bez252 Actually what they describe might also work for you, based on a quick glance through the setup code.
                  To shutdown from the node_helper you need to change some code in the file(will be in MMM-Button/node_helper.js in your file system).
                  Here is an example from my module to shut down the RPi, you can replace the self.sendSocketNotification(...) in the node_helper with a similar command:
                  exec('sudo shutdown -h now', null);
                  Also, at the beginning of the file you need to include the exec function, like here:
                  const exec = require('child_process').exec;
