    MMM-Spotify
    249 Posts 51 Posters 365.2k Views 54 Watching
      A Former User
      I make a developer tools module for displaying notification and payload Read there :)
      I think it can help you
      M 1 Reply Last reply
        mmmmh Project Sponsor @Guest
        @Bugsounet Very interesting. This also looks promising. I’ll comment in the other topic.
          @Bugsounet I noticed in my pihole logs that there were at least 10 DNS queries for Spotify per second, something is not right. The actual refresh rate for the module is set to 3000 ms. I had to disable the module.
            A Former User
            i correct it with last update :)
            1.3.2 (2020-05-15)
            Modified: onStart script (Now launched if Spotify initialized)
            Added: "Cast" Icons
            1.3.1 (2020-05-14)
            Modified: 'progress bar'
            Fixed: number of request on idle (depend now of updateInterval config)
              A Former User
              @mmmmh :
              sorry, I take over the project … and its bugs!
              I correct little by little :)
              note: after … I understand why my mirror crashed with this module!
              now it’s better :)
              thinking to @eouia who love when I fixed bugs
              Reply Quote 2
                @Bugsounet, thanks for fixing it. From the changelog, should I expect that many requests again when not on idle?
                  A Former User
                  I will try to improve it…
                  actually i’m working arround another bug …
                  multi account and connected / disconnected notification …
                  with one account it’s works correctly but not with multi :(
                  bouah !
                  it’s horrible, in multi-account mode, MMM-Spotify tries to connect to all accounts to send news live
                  I really wonder if the multi-account mode is really a good feature
                  and of course … wow it spam like it can not connect to the account that we do not use
                  humm, how to manage this mess !?
                  i will impect …
                  Note:
                  • with multi account, I think It can crash the RPI … (so so so so … more loop)
                  • in my dev platform (desktop with debian linux):
                    • in idle: CPU 3%
                    • with buggy playing multi-account : CPU 36%
                  It’s very very high !!!
                    A Former User
                    So…
                    I propose this (and i have already coded a part of it in other dev) :
                    • a single account checking and displaying (default account in config)
                    • Changing account is by vocal (like Jarvis ... Spotify account name)
                    name is the USERNAME defined in the spotify.config.json file
                    Of course, i will add this function in AMk2 Spotify recipe
                    Result:
                    Less CPU time, Less DNS request, Less Loop for Checking … More Free Memory and RPI will be better
                    what do you think about this ?
                    Z 1 Reply Last reply
                      A Former User
                      v1.4.0 (2020-05-16)
                      • Added & Modified: Multi-account management by notification SPOTIFY_ACCOUNT
                      • Fixed: Loop CONNECTED/DISCONNECTED on multi-account
                      • Fixed: Less CPU time, Less DNS request
                      • Fixed: Maybe RPI crashed when using multi-account (memory leaks)
                        Regrettably, DNS requests are still too many. I see 1000 in 10 minutes (purple is a fresh install of MagicMirror with just the clock and the Spotify module):
                          A Former User
                          I think the best solution is Don’t use it
                          (like my other modules)
                          ? 1 Reply Last reply
                            A Former User @Guest
                            Sorry for bothering you guys with my kinky ex-module.
                            The problem is; There is no server-pushed way to get current playback in RPI with spotify api.
                            So to get current playing data, frequent api callings are needed.
                            Possible solution under current condition is; removing some features - like progress bar, displaying playtime… So then too many requests are not needed.
                            In other platforms like desktop PC, Google Chrome has widevine/DRM so we can use “web playback api”, it can make direct playing spotify on browser level, and get playback data directly. But not possible in rpi natively.
                            Some hacks for widevine exist for RPI chromium, but our MM’s electron still miss that feature.
                            But! I’ve heard newest Electron(9.0) has a new Chromium(80? 83?) and it might have widevine supported (I haven’t tested yet, or never…)
                            I’m not sure it would be supported in rpi or not but if who has interest, worthy to try. If supported, you can build a new module which can play spotify directly without raspotify instead this poor module.
                            M 2 Replies Last reply
                              @Sean Thank you for chiming in and for providing a more elaborate response. I thought that the constant polling might be the reason. If I may comment, for other users it may be helpful to put it in the documentation that using the module leads to increased network traffic.
                              I for one would be happy with a display of the static per-title information and the controls, I will observe what happens when I crank the refresh rate up to 30000 milliseconds.
                                @Sean I hacked together a simple bash script (dnssaver.sh) that fetches IPs and stores them in the hosts file. If I call it with ‘api.spotify.com’ as argument and put it in my crontab it should take a load of the dns server. I’ll keep an eye on it.
                                • Cr4z33C
                                  Cr4z33
                                  @Bugsounet either I am doing something wrong or there’s a bug.
                                  I added onStart: null, in the module config, but the big Spotify logo keeps displaying all the time.
                                    A Former User
                                    if Soptify logo not hidden after start, it’s means :
                                    token missing or token error
                                    you should have in console something like that :
                                    [SPOTIFY:ERROR] USERNAME: [your username]
                                    [SPOTIFY:ERROR] Token Error ! ./[token name].json
                                    if you have set a token … verify the exact name
                                    and report it to your account username specified in spotify.config.json -> “TOKEN” field
                                      A Former User
                                      when ok It display :
                                      • default style
                                      • mini style
                                      • when bottom_bar position is set
                                        A Former User
                                        @mmmmh :
                                        now idleInterval is set to 30000 (scan is Spotify is playing every 30 sec)
                                        if playing : updateInterval is set by default to 1000 (1sec)
                                        Attention it’s means that with idleInterval : when Spotify is playing to take 30 sec to display it in mirror !by default !
                                          @Bugsounet Thanks. Do I understand this correctly. As long as the module is idle it will only check for updates every 30 seconds and when it is active (music is being played) it updates every second?
                                            A Former User
                                            Right,
                                            I hope this suits you, because it starts to take head ;)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
