    PM2 logs
    8 Posts 3 Posters 10.3k Views 2 Watching
    • O Offline
      ostfilinchen
      Hi all,
      when i call pm2 logs mm i get these Errors:
      (node:24612) DeprecationWarning: sys is deprecated. Use util instead.
      { Error: listen EADDRINUSE :::8080
      at Object.exports._errnoException (util.js:1008:11)
      at exports._exceptionWithHostPort (util.js:1031:20)
      at Server._listen2 (net.js:1253:14)
      at listen (net.js:1289:10)
      at Server.listen (net.js:1385:5)
      at new Server (/home/pi/MagicMirror/js/server.js:17:9)
      at /home/pi/MagicMirror/js/app.js:129:17
      at loadConfig (/home/pi/MagicMirror/js/app.js:42:4)
      at App.start (/home/pi/MagicMirror/js/app.js:115:3)
      at Object. (/home/pi/MagicMirror/js/electron.js:81:6)
      code: ‘EADDRINUSE’,
      errno: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘::’,
      port: 8080 }
      (node:28564) DeprecationWarning: sys is deprecated. Use util instead.
      code: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘::’,
      port: 8080 }
      (node:1309) DeprecationWarning: sys is deprecated. Use util instead.
      (node:18091) DeprecationWarning: sys is deprecated. Use util instead.
      (node:18949) DeprecationWarning: sys is deprecated. Use util instead.
      (node:1319) DeprecationWarning: sys is deprecated. Use util instead.
      (node:2450) DeprecationWarning: sys is deprecated. Use util instead.
      (node:20215) DeprecationWarning: sys is deprecated. Use util instead.
      (node:26201) DeprecationWarning: sys is deprecated. Use util instead.
      (node:23501) DeprecationWarning: sys is deprecated. Use util instead.
      (node:23793) DeprecationWarning: sys is deprecated. Use util instead.
      (node:24045) DeprecationWarning: sys is deprecated. Use util instead.
      (node:29144) DeprecationWarning: sys is deprecated. Use util instead.
      (node:27949) DeprecationWarning: sys is deprecated. Use util instead.
      (node:31805) DeprecationWarning: sys is deprecated. Use util instead.
      (node:1372) DeprecationWarning: sys is deprecated. Use util instead.
      (node:1331) DeprecationWarning: sys is deprecated. Use util instead.
      Is this an error on the pm2 or the MM himself?
      Thanks for help
      Daniel
      • K Offline
        KirAsh4 Moderator @ostfilinchen
        @ostfilinchen said in PM2 logs:
        … snip …
        code: ‘EADDRINUSE’,
        syscall: ‘listen’,
        address: ‘::’,
        port: 8080 }
        You’re telling Mm to use a port that’s already being used for something else. If you actually have something that’s using port 8080, change Mm to use something else. It’s in the config.js file. For example, set it to 8585 …
        If you don’t have or know what’s on port 8080, you have a bigger problem than either pm2 or MM.
        • O Offline
          ostfilinchen @KirAsh4
          @KirAsh4 i only have the mm on Port 8080. How can i check, what Use the Port 8080? If i open the address http://raspberrypi:8080 i only See the MagicMirror…
          • K Offline
            KirAsh4 Moderator
            Did you try to launch it multiple times? That’s what pm2 is recording.
            • O Offline
              ostfilinchen
              U mean to open the mm-webpage?
              I restart the pi and then i call pm2 logs mm and it shows me this log. The mirror by the way starts.
              • K Offline
                KirAsh4 Moderator
                Flush the logs:
                ‘pm2 flush’
                Restart the pi:
                ‘sudo reboot’
                Check the pm2 logs again:
                ‘pm2 logs’
                • O Offline
                  ostfilinchen
                  Hi @KirAsh4,
                  i have done it and there are no Errors. But is it normal that the mirror stop working, if any module get an error. The module MMM-Soccer produces an error and then the module MMM-WurnderGround stop working.
                  @RedNax: is it possible to debug the module?
                    RedNax Module Developer @ostfilinchen
                    @ostfilinchen Working on it, testing as we speak :D
