    mmm assistant mk2
    112 Posts 12 Posters 73.7k Views 11 Watching
      A Former User
      sam:
      in RPI4: it’s works
      pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ls -la
      total 107516
      drwxr-xr-x 4 pi   pi     4096 mai   20 15:23 .
      drwxr-xr-x 3 pi   pi     4096 juin   1 13:37 ..
      -rw-r--r-- 1 pi   pi   145945 mai   20 15:23 chrome_100_percent.pak
      -rw-r--r-- 1 pi   pi   209147 mai   20 15:23 chrome_200_percent.pak
      -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
      i have no idea if @dvbit it’s the same
      Note: this Issue take me head since 6 month
      S ? 2 Replies Last reply Reply Quote 0
        sdetweil @Guest
        @Bugsounet yes, added in V6 of electron (and chrome 45 I think?) we are running 6.1.7
          A Former User
          pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ./electron -v
          v6.1.12
            sdetweil @Guest
            @Bugsounet weird we call for 6.1.7 or above
            "electron": "^6.1.7"
            • ChrisC Offline
              Chris @Guest
              @Bugsounet
              Indeed, I did not understand well in WIKI.
              If it can be used for others, you must create a token.js file and insert the code:
              ACCESSTOKEN=ya29.a0AfH6SMABBPj590X_itMQG616F8QpxddhPVuSXCE4qvZs6znHKbG2n5RggszFMdl0V5HP0lf956H9O7VHlbuGuMxSzkU3pMkdbpFxs485NwfXYl9T7hfLzB0EOPlRTwcifZW-8rIUlZlWXXXXXXXXXXXXXXXXXXX
              Now it works perfectly,
              Thank you so much,
              Regards,
                A Former User @sdetweil
                but only in 6.x.x branch
                actually electron is releasing with v9 ;)
                  dvbit @dvbit
                  @dvbit said in mmm assistant mk2:
                  Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
                  Still the same issue of assistant hanging after query:
                  I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
                  After refreshing the screen goes again in “steady state”
                  Now I am sure I have a sound output issue.
                  Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
                  I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
                  What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
                  Will continue checking
                  could it be this: https://github.com/raspberrypi/firmware/issues/1243
                  Edit: Nope - vlc outputs sound
                  IMPORTANT:
                  The Install script for the audio output was succesfull just the first time.
                  on second install I skipped the output part as I could not get through indeed.
                  However the input was working just fine. recorded my voice and could hear it.
                  Posting here my asoundrc file
                  pcm.!default {
                    type asym
                    playback.pcm {
                      type plug
                      slave.pcm "output"
                    capture.pcm {
                      type plug
                      slave.pcm "input"
                  pcm.output {
                    type hw
                    card 0
                  ctl.!default {
                    type hw
                    card 0
                  Input is : kinect microphones
                  Output : TV speakers (directly through TV speakers)
                    sdetweil @Guest
                    @Bugsounet it also has sandbox…
                    we just moved up to V6 from V3 on 2.10, some things newer don’t work on pi…
                      A Former User @Guest
                      @Bugsounet said in mmm assistant mk2:
                      total 107516
                      @dvbit: can you give me your result please ?
                        dvbit @Guest
                        pi@MagicMirror:~/MagicMirror $ ~/MagicMirror/node_modules/electron/dist $ ls -la
                        bash: /home/pi/MagicMirror/node_modules/electron/dist: Is a directory
                        pi@MagicMirror:~/MagicMirror $ cd ~/MagicMirror/node_modules/electron/dist
                        pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
                        total 107496
                        drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
                        drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
                        -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
                        -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
                        -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
                        -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
                        -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
                        -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
                        -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
                        -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
                        -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
                        -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
                        drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
                        -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
                        drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
                        -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
                        -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
                        -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
                        -rw-r--r-- 1 pi pi        5 May 30 12:38 version
                        Please look also post above: I realize my asoundrc file may be screwed since I did not complete on second install the sound output wizard successfully
                          sdetweil @dvbit
                          @dvbit run
                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                            A Former User
                            sam : you have right
                            permission is not set
                            After 6 month … maybe it will be solved !
                              dvbit @sdetweil
                              done
                              here the output
                              pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ bash -c $(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)
                              total 107496
                              I mean I did run the bash
                              No output. here is the detail listing of the folder.
                              I do not see any timestamps changed…
                                sdetweil @Guest
                                @Bugsounet don’t count on it!!
                                  A Former User
                                  not fixed
                                    sdetweil @dvbit
                                    @dvbit have to do from the MagicMirror folder… sorry, will fix for future
                                      A Former User
                                      sudo chown root node_modules/electron/dist/chrome-sandbox
                                      sudo chmod 4755 node_modules/electron/dist/chrome-sandbox
                                        dvbit @sdetweil
                                        done it from MagicMirror folder.
                                        Can I see any file being changed somewhere?
                                        I did a ls -la in
                                        and there seems to be no change there
                                          A Former User
                                          result must be:
                                          S D 2 Replies Last reply Reply Quote 0
                                            sdetweil @Guest
                                            @Bugsounet maybe he doesn’t have sudo rights…
                                            must do change to root first
                                            • 3 / 6
