    mmm assistant mk2
    112 Posts 12 Posters 76.4k Views 11 Watching
      sdetweil @Guest
      @Bugsounet u can also run the fixsandbox script from my repo
      if they use my installer I fix it… otherwise they either need the --nosandbox or run my script
        A Former User
        sam, i suspect a bug in electron
        chown root and chmod 4755 ?
          sdetweil @Guest
          @Bugsounet yes, what my script does…
          not a bug, new feature
            A Former User
            yes but i don’t understand why … with pulseaudio there is no sound but with root it’s works …
            There is a permission missing somewhere
              sdetweil @Guest
              @Bugsounet sorry, got no idea what the side effects are…
              they wanted some additional security
              are u launching a player as a background task, or playing direct to the device? if the latter then u get all the security crap
                A Former User
                sam:
                in RPI4: it’s works
                pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ls -la
                total 107516
                drwxr-xr-x 4 pi   pi     4096 mai   20 15:23 .
                drwxr-xr-x 3 pi   pi     4096 juin   1 13:37 ..
                -rw-r--r-- 1 pi   pi   145945 mai   20 15:23 chrome_100_percent.pak
                -rw-r--r-- 1 pi   pi   209147 mai   20 15:23 chrome_200_percent.pak
                -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
                i have no idea if @dvbit it’s the same
                Note: this Issue take me head since 6 month
                S ? 2 Replies Last reply Reply Quote 0
                  sdetweil @Guest
                  @Bugsounet yes, added in V6 of electron (and chrome 45 I think?) we are running 6.1.7
                    A Former User
                    pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ./electron -v
                    v6.1.12
                      sdetweil @Guest
                      @Bugsounet weird we call for 6.1.7 or above
                      "electron": "^6.1.7"
                      • ChrisC
                        Chris @Guest
                        @Bugsounet
                        Indeed, I did not understand well in WIKI.
                        If it can be used for others, you must create a token.js file and insert the code:
                        ACCESSTOKEN=ya29.a0AfH6SMABBPj590X_itMQG616F8QpxddhPVuSXCE4qvZs6znHKbG2n5RggszFMdl0V5HP0lf956H9O7VHlbuGuMxSzkU3pMkdbpFxs485NwfXYl9T7hfLzB0EOPlRTwcifZW-8rIUlZlWXXXXXXXXXXXXXXXXXXX
                        Now it works perfectly,
                        Thank you so much,
                        Regards,
                          A Former User @sdetweil
                          but only in 6.x.x branch
                          actually electron is releasing with v9 ;)
                            dvbit @dvbit
                            @dvbit said in mmm assistant mk2:
                            Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
                            Still the same issue of assistant hanging after query:
                            I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
                            After refreshing the screen goes again in “steady state”
                            Now I am sure I have a sound output issue.
                            Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
                            I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
                            What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
                            Will continue checking
                            could it be this: https://github.com/raspberrypi/firmware/issues/1243
                            Edit: Nope - vlc outputs sound
                            IMPORTANT:
                            The Install script for the audio output was succesfull just the first time.
                            on second install I skipped the output part as I could not get through indeed.
                            However the input was working just fine. recorded my voice and could hear it.
                            Posting here my asoundrc file
                            pcm.!default {
                              type asym
                              playback.pcm {
                                type plug
                                slave.pcm "output"
                              capture.pcm {
                                type plug
                                slave.pcm "input"
                            pcm.output {
                              type hw
                              card 0
                            ctl.!default {
                              type hw
                              card 0
                            Input is : kinect microphones
                            Output : TV speakers (directly through TV speakers)
                              sdetweil @Guest
                              @Bugsounet it also has sandbox…
                              we just moved up to V6 from V3 on 2.10, some things newer don’t work on pi…
                                A Former User @Guest
                                @Bugsounet said in mmm assistant mk2:
                                total 107516
                                @dvbit: can you give me your result please ?
                                  dvbit @Guest
                                  pi@MagicMirror:~/MagicMirror $ ~/MagicMirror/node_modules/electron/dist $ ls -la
                                  bash: /home/pi/MagicMirror/node_modules/electron/dist: Is a directory
                                  pi@MagicMirror:~/MagicMirror $ cd ~/MagicMirror/node_modules/electron/dist
                                  pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
                                  total 107496
                                  drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
                                  drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
                                  -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
                                  -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
                                  -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
                                  -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
                                  -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
                                  -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
                                  -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
                                  -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
                                  -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
                                  -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
                                  drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
                                  -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
                                  drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
                                  -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
                                  -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
                                  -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
                                  -rw-r--r-- 1 pi pi        5 May 30 12:38 version
                                  Please look also post above: I realize my asoundrc file may be screwed since I did not complete on second install the sound output wizard successfully
                                    sdetweil @dvbit
                                    @dvbit run
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                                      A Former User
                                      sam : you have right
                                      permission is not set
                                      After 6 month … maybe it will be solved !
                                        dvbit @sdetweil
                                        done
                                        here the output
                                        pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ bash -c $(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)
                                        total 107496
                                        I mean I did run the bash
                                        No output. here is the detail listing of the folder.
                                        I do not see any timestamps changed…
                                          sdetweil @Guest
                                          @Bugsounet don’t count on it!!
                                            A Former User
                                            not fixed
                                            • 3 / 6
