    mmm assistant mk2
    112 Posts 12 Posters 73.6k Views 11 Watching
      dvbit
      and flawless install!
      Thanks @Bugsounet
        dvbit
        A2D was not working at first launch.
        npm rebuild in the directory did the trick.
        Working now
          dvbit
          Hi
          Curious it has been working for the first calls.
          Now It answers on screen.
          Not via speakers (but that could be for sure a problem with my audio setup)
          The other thing is that the on screen google assistant prompt on top keeps spinning and no further interaction is possible.
          Here is the debug log.
          I can see the call is successfully created files inthe tmp directory and have scped them to my laptop and they are ok.
          What changed in between was the tests are that I installed a2d .
          While I investigate on my audio output to check if it works I post the log in debug mode
          I see a suspicious “null” in volume in the log.
          I tried a vlc lastResponse.mp3 and it was correctly output
          [2020-06-01 12:15:47.539] [LOG]    [ASSISTANT:AS] CONVERSATION:SCREEN object
          [2020-06-01 12:15:47.542] [LOG]    [ASSISTANT:AS] CONVERSATION:ACTION { requestId: '5ed37b16-0000-2f10-85f3-089e0827ce88' }
          [2020-06-01 12:15:47.543] [LOG]    [ASSISTANT:AS] CONVERSATION:RESPONSE
          [2020-06-01 12:15:47.589] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.592] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.593] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.594] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.596] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.597] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 1600
          [2020-06-01 12:15:47.598] [LOG]    [ASSISTANT:AS] CONVERSATION:AUDIO 768
          [2020-06-01 12:15:47.602] [LOG]    [ASSISTANT:AS] CONVERSATION_ALL_RESPONSES_RECEIVED
          [2020-06-01 12:15:47.603] [LOG]    [ASSISTANT:AS] CONVERSATION_END:COMPLETED
          [2020-06-01 12:15:47.603] [LOG]    [ASSISTANT:AS] CONVERSATION_PP:RESPONSE_AUDIO_PROCESSED
          [2020-06-01 12:15:47.604] [LOG]    [MP3] MP3 FILE CREATED 10368 bytes
          [2020-06-01 12:15:47.656] [LOG]    [ASSISTANT:SP] CONVERSATION:SCREENOUTPUT_CREATED
          [2020-06-01 12:15:47.657] [LOG]    [ASSISTANT] ASSISTANT_RESULT { error: null,
            action: { requestId: '5ed37b16-0000-2f10-85f3-089e0827ce88' },
            text: null,
            screen:
             { text:
                'Bracciano RM / Ora locale\n12:15\nlunedì 1 giugno 2020\nOrario (Edited)',
               links: [],
               photos: [],
               path:
                '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastScreenOutput.html',
               uri: 'tmp/lastScreenOutput.html' },
            audio:
             { path:
                '/home/pi/MagicMirror/modules/MMM-GoogleAssistant/tmp/lastResponse.mp3',
               uri: 'tmp/lastResponse.mp3' },
            transcription: { transcription: 'a che ora è', done: true },
            continue: false,
            volume: null,
            lastQuery:
             { type: 'MIC',
               key: null,
               lang: 'it-IT',
               useScreenOutput: true,
               useAudioOutput: true,
               status: 'standby',
               chime: true } }
            dvbit
            Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
            Still the same issue of assistant hanging after query:
            I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
            After refreshing the screen goes again in “steady state”
            Now I am sure I have a sound output issue.
            Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
            I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
            What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
            Will continue checking
            • ChrisC Offline
              Chris @Guest
              @Bugsounet
              First of all, thank you for not stopping your work on this module which is of high quality.
              I tried to install the new assistant. I followed the wiki. However, I have a problem.
              Indeed, when the mirror is launched, I find myself with the following message:
              [2020-06-01 14:04:54.256] [LOG]    [ASSISTANT][ERROR] token.json file not found
              However, I followed the WIKI well and applied the following command:
              (env) pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ ACCESSTOKEN=ya29.a0AfH6SMABBPj590X_itMQG616F8QpxddhPVuSXCE4qvZs6znHKbG2n5RggszFMdl0V5HP0lf956H9O7VHlbuGuMxSzkU3pMkdbpFxs485NwfXYl9T7hfLzB0EOPlRTwcifZW-8rIUlZlWXXXXXXXXXXXXXXXXXXX
              Do you have any idea about this problem?
              Thanking you in advance,
              Regards,
                A Former User
                @dvbit try this:
                launch it in root directly in RPI terminal (not ssh)
                sudo ./node_modules/.bin/electron js/electron.js --no-sandbox
                give me result
                  A Former User
                  @chris: token.json file must be located in ~/MagicMirror/modules/MMM-GoogleAssistant/token.json
                  ChrisC 1 Reply Last reply Reply Quote 0
                    sdetweil @Guest
                    @Bugsounet u can also run the fixsandbox script from my repo
                    if they use my installer I fix it… otherwise they either need the --nosandbox or run my script
                      A Former User
                      sam, i suspect a bug in electron
                      chown root and chmod 4755 ?
                        sdetweil @Guest
                        @Bugsounet yes, what my script does…
                        not a bug, new feature
                          A Former User
                          yes but i don’t understand why … with pulseaudio there is no sound but with root it’s works …
                          There is a permission missing somewhere
                            sdetweil @Guest
                            @Bugsounet sorry, got no idea what the side effects are…
                            they wanted some additional security
                            are u launching a player as a background task, or playing direct to the device? if the latter then u get all the security crap
                              A Former User
                              sam:
                              in RPI4: it’s works
                              pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ls -la
                              total 107516
                              drwxr-xr-x 4 pi   pi     4096 mai   20 15:23 .
                              drwxr-xr-x 3 pi   pi     4096 juin   1 13:37 ..
                              -rw-r--r-- 1 pi   pi   145945 mai   20 15:23 chrome_100_percent.pak
                              -rw-r--r-- 1 pi   pi   209147 mai   20 15:23 chrome_200_percent.pak
                              -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
                              i have no idea if @dvbit it’s the same
                              Note: this Issue take me head since 6 month
                              S ? 2 Replies Last reply Reply Quote 0
                                sdetweil @Guest
                                @Bugsounet yes, added in V6 of electron (and chrome 45 I think?) we are running 6.1.7
                                  A Former User
                                  pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ./electron -v
                                  v6.1.12
                                    sdetweil @Guest
                                    @Bugsounet weird we call for 6.1.7 or above
                                    "electron": "^6.1.7"
                                    • ChrisC Offline
                                      Chris @Guest
                                      @Bugsounet
                                      Indeed, I did not understand well in WIKI.
                                      If it can be used for others, you must create a token.js file and insert the code:
                                      Now it works perfectly,
                                      Thank you so much,
                                      Regards,
                                        A Former User @sdetweil
                                        but only in 6.x.x branch
                                        actually electron is releasing with v9 ;)
                                          dvbit @dvbit
                                          @dvbit said in mmm assistant mk2:
                                          could it be this: https://github.com/raspberrypi/firmware/issues/1243
                                          Edit: Nope - vlc outputs sound
                                          IMPORTANT:
                                          The Install script for the audio output was succesfull just the first time.
                                          on second install I skipped the output part as I could not get through indeed.
                                          However the input was working just fine. recorded my voice and could hear it.
                                          Posting here my asoundrc file
                                          pcm.!default {
                                            type asym
                                            playback.pcm {
                                              type plug
                                              slave.pcm "output"
                                            capture.pcm {
                                              type plug
                                              slave.pcm "input"
                                          pcm.output {
                                            type hw
                                            card 0
                                          ctl.!default {
                                            type hw
                                            card 0
                                          Input is : kinect microphones
                                          Output : TV speakers (directly through TV speakers)
                                            sdetweil @Guest
                                            @Bugsounet it also has sandbox…
                                            we just moved up to V6 from V3 on 2.10, some things newer don’t work on pi…
                                            • 3 / 6
