    mmm assistant mk2
    112 Posts 12 Posters 72.6k Views 11 Watching
      [[global:former-user]]
      @reddyman : turn on modules. just YouTube by default is turn on
      link / photo is disabled by default
          debug:true,
          // make you config there !
       // not there
        reddyman @Guest
        @Bugsounet said in mmm assistant mk2:
            debug:true,
         // not there
        …I am an idiot. Hahaha, I knew it was something super simple. Smh, thanks for putting up with idiots like me :p
          @reddyman : don’t worry, it’s arrive to me too sometime !
            James Farmer
            First, I say thanks to @Bugsounet , I only started my mirror a few weeks and have had Assistant working. Upgraded to GoogleAssistant and it is much quicker.
            Unfortunately I have a few problems with it now, one is sound, but im 99.99% sure because i have sound config wrong. Nothing to do with module. !
            The only other issue i have is i use pages and when googleAssisatnt comes on screen part of it is still hidden by the modules on screen.
            Just wondering if anyone have this problem. ?
            Ive set it to fullscreen_above in GoogleAssistant so thought this wouldnt be a problem. it worked ok with AssistantMK.
            Thankyou
              hi,
              1. what the problem ?
              2. for pages:
                I don’t know what this developer means …
                edit pages.css
                change it to:
              .fullscreen.above {
                  z-index: 9999
              page should now works correctly
                James Farmer @Guest
                @Bugsounet Thanks that has fixed it, I need to have another go at learning css to try and sort out all the positions.
                Ill get back to trying to sort out sound.
                Thanks again
                  JohnBachini
                  @Bugsounet
                  HI, Amazing work with GoogleAssist, it seems to be more responsive and accurate than AssistantMK2.
                  Have an issue with the display of the googleAssistant banner. My Mirror is full screen, ie in custom.css i have :-
                   body {
                       margin: 0px;
                       position: absolute;
                       height: 100%;
                       width: 100%;
                  Which i hope is correct, im struggling with css side of things !! :-)
                  But when the banner appears i have this issue,
                  As top of banner is missing and width
                  I looked at GoogleAssistant.css, but couldnt work out what needs to change.
                    @JohnBachini :
                      module: "MMM-GoogleAssistant",
                      position: "fullscreen_above",
                    don’t work with this position ?
                    Edit : Ah yes don’t work
                      JohnBachini @Guest
                      @Bugsounet
                      Yes i have it set to fullscreen_above, i confirmed it works fine if i remove the css code i posted above
                        @JohnBachini: I don’t find too :face_with_tears_of_joy: :face_with_tears_of_joy: :face_screaming_in_fear:
                        I got lost in my css code !!!
                          JohnBachini @Guest
                          @Bugsounet :-) So custom.css overides main.css , so does GoogleAssistant.css overide all ?
                            sdetweil @JohnBachini
                            @JohnBachini main, then modules, then custom.css last
                              nop it not override all.
                              Actually I’m working arround a new rending
                              real time Transcription will be in next update in popup (like the response)
                              and it will correct this problem ;)
                              So wait a few days :)
                              results:
                              New animation (response screen)
                              new animation (transcription)
                              More reactive
                                JohnBachini @Guest
                                @Bugsounet Great, Ill wait till then. Thanks
                                  [[global:former-user]] @JohnBachini
                                  @JohnBachini : fixed ;)
                                  wait next release :p
                                    mcretu @dvbit
                                    @dvbit Hi, did you managed to figure it out? I have the same issue. Youtube video audio works fine, I even hear the chime when the assistant is waked up.
                                      @JohnBachini : if you want, we can do some test
                                        dvbit @mcretu
                                        @mcretu Hi . Lost in the Post.
                                        I think you refer to youtube not being displayed.
                                        If that is the case, as @Bugsounet keeps saying (he said it to me about this…), red the wiki. It’s all there.
                                        you need to change the config.js in config as follows:
                                        https://github.com/bugsounet/MMM-Assistant2Display/wiki/Configuration
                                        Assistant2Display need electron special configuration for web link displaying and Youtube functionality
                                        start of the config.js configuration file
                                        var config = {
                                          address: "localhost",
                                          electronOptions: {
                                            webPreferences: {
                                              webviewTag: true
                                          port: 8080,
                                        address should be localhost for playing YouTube video
                                        electronOptions is need if you want to display the link and Cast module
                                        • 6 / 6
