    MMM-remote-control api key
    remote controlapimodule
    7 Posts 3 Posters 2.7k Views 3 Watching
    • L Offline
      lampi
      hi,
      after the latest update of remote control some kind of api key is required. Can anybody tell me where I can get one? I tryed two evenings to solve this issue and didnt get it… pls help me…
        sdetweil @lampi
        @lampi why do you think an api key is required?
        • L Offline
          lampi @sdetweil
          @sdetweil cause i have to change the config file and the guide says so
            sdetweil @lampi
            @lampi from the api/readme
            Providing an API key is recommended; however, remains optional.
            its for apps connecting to mirror… force THEM to have the api key…
            additionally
            If you ran the installer.sh script when you installed the module, a non-canoical UUID is generated for you to use; you can use this unique code,
            or use any string you wish.
            so, YOU make up the key string
            L 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer
              the API key is for security - you don’t need it if you’re not needing that extra layer of security for remote control.
              • L Offline
                lampi @sdetweil
                @sdetweil thank you! It worked :) I just had to delet the config line
                • L Offline
                  lampi @sdetweil
                  hi sry me again. It worked for maybe three hours and now it says just loading… can you help me with this issue too?
                  Lukas
