    MMM-Tado wrong units
    28 Posts 3 Posters 9.7k Views 4 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe hmm…
      can u share the top of your config.js, before the modules:[ line
      thanks
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil Hello, after module update same problem
        and your fix don’t work anymore…can you help me again?
        var config = {
        	address: "0.0.0.0", // Address to listen on, can be:
        	                      // - "0.0.0.0", "127.0.0.1", "::1" to listen on loopback interface
        	                      // Default, when address config is left out, is "0.0.0.0"
        	port: 8080,
        	ipWhitelist: [], // Set [] to allow all IP addresses
        	language: "de",
        	timeFormat: 24,
        	units: "metric",
          @Stoffbeuteluwe ok, need an editor for this…
          line 26 of MMM-Tado.js, leave alone
          change all the other this.config.units to self.config.units
          change them all, then change line 26 back to this.
          I have opened issue 11
          https://github.com/WouterEekhout/MMM-Tado/issues/11
          • StoffbeuteluweS
            @sdetweil no luck…sorry, I have changed 4x this into self
            but I am not sure with the line 26
             * Created by Wouter Eekhout on 06/01/2017.
            Module.register("MMM-Tado", {
                // Default module config.
                defaults: {
                    username: '',
                    password: '',
                    updateInterval: 300000,
                tadoMe: {},
                tadoHomes: [],
                getStyles: function () {
                    return [
                        this.file('css/MMM-Tado.css'),
                start: function () {
                    if (this.config.updateInterval < this.defaults.updateInterval){
                        this.config.updateInterval = this.defaults.updateInterval;
                    this.config.units = self.config.units;
                    this.sendSocketNotification('CONFIG', this.config);
                // Override dom generator.
                getDom: function () {
                    let self = this;
                    let wrapper = document.createElement("div");
                    wrapper.className = "tado-info";
                    this.tadoHomes.forEach(home => {
                        let homeWrapper = document.createElement("div");
                        homeWrapper.className = "tado-home";
                        let logoWrapper = document.createElement("i");
                        logoWrapper.className = "tado-icon-tado_logo tado-logo";
                        homeWrapper.appendChild(logoWrapper);
                        let tableWrapper = document.createElement("table");
                        tableWrapper.className = "tado-table small";
                        home.zones.forEach(zone => {
                            let rowWrapper = document.createElement("tr");
                            if (zone.type === "HOT_WATER") {
                                let firstTableDataWrapper = document.createElement("td");
                                firstTableDataWrapper.className = "tado-table-name";
                                let zoneNameWrapper = document.createElement("span");
                                zoneNameWrapper.innerText = zone.name;
                                firstTableDataWrapper.appendChild(zoneNameWrapper);
                                rowWrapper.appendChild(firstTableDataWrapper);
                                let secondTableDateWrapper = document.createElement("td");
                                secondTableDateWrapper.className = "tado-table-data";
                                let temperatureWrapper = document.createElement("span");
                                let temperatureIconWrapper = document.createElement("i");
                                temperatureIconWrapper.className = "fa fa-thermometer-half";
                                temperatureWrapper.appendChild(temperatureIconWrapper);
                                if (zone.state.setting.temperature == null) {
                                    var temperatureTextWrapper = document.createTextNode(zone.state.setting.power);
                                } else {
                                    if (self.config.units === "metric") {
                                        var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                                    } else {
                                        var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                                temperatureWrapper.appendChild(temperatureTextWrapper);
                                secondTableDateWrapper.appendChild(temperatureWrapper);
                                rowWrapper.appendChild(secondTableDateWrapper);
                            else if (zone.type === "HEATING") {
                                //current temperature
                                temperatureWrapper.className = "bright";
                                    var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.celsius + "°");
                                } else {
                                    var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.fahrenheit + "°");
                                if (zone.state.activityDataPoints.heatingPower.percentage > 0) {
                                    //The zone is heating
                                    let heatingWrapper = document.createElement("i");
                                    heatingWrapper.className = "fa fa-fire bright";
                                    temperatureWrapper.appendChild(heatingWrapper);
                                //target temperature
                                let temperatureTargetWrapper = document.createElement("span");
                                temperatureTargetWrapper.className = "xsmall";
                                let temperatureTargetIconWrapper = document.createElement("i");
                                temperatureTargetIconWrapper.className = "fa fa-thermometer-half";
                                temperatureTargetWrapper.appendChild(temperatureTargetIconWrapper);
                                    var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.power);
                                } else {
                                        var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                                    } else {
                                        var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                                temperatureTargetWrapper.appendChild(temperatureTargetTextWrapper);
                                secondTableDateWrapper.appendChild(temperatureTargetWrapper);
                                let breakLine = document.createElement("br");
                                secondTableDateWrapper.appendChild(breakLine);
                                let humidityWrapper = document.createElement("span");
                                let humidityIconWrapper = document.createElement("i");
                                humidityIconWrapper.className = "fa fa-tint";
                                humidityWrapper.appendChild(humidityIconWrapper);
                                let humidityTextWrapper = document.createTextNode(zone.state.sensorDataPoints.humidity.percentage + "%");
                                humidityWrapper.appendChild(humidityTextWrapper);
                                secondTableDateWrapper.appendChild(humidityWrapper);
                            else if (zone.type === "AIR_CONDITIONING") {
                                } else {
                                if (zone.state.setting.mode === "HEAT") {
                                else if (zone.state.setting.mode === "COOL") {
                                    //The zone is cooling
                                    let coolingWrapper = document.createElement("i");
                                    coolingWrapper.className = "fa fa-snowflake bright";
                                    temperatureWrapper.appendChild(coolingWrapper);
                                } else {
                                    } else {
                            } else {
                                //don't add it
                                return;
                            tableWrapper.appendChild(rowWrapper);
                        homeWrapper.appendChild(tableWrapper);
                        wrapper.appendChild(homeWrapper);
                    return wrapper;
                    if (notification === 'NEW_DATA') {
                        this.tadoMe = payload.tadoMe;
                        this.tadoHomes = payload.tadoHomes;
                        this.updateDom();
            S 2 Replies Last reply
              @Stoffbeuteluwe weird… i’ll be back on in about 6 hours, do you know how to use the debugger?
              ctrl-shift-i on teh keyboard, select the sources tab, navigate the left tree to find the module and filename, click
              shows in middle window
              scroll down to one of the if (self.config.units lines (make sure u have that type unit in the tado data)
              click the number on the start of the line, it should turn blue
              hit refresh
              the code will stop there
              mouse over the self and a box will pop up showing what self points to, then config
              same… units should say metric
                @Stoffbeuteluwe said in MMM-Tado wrong units:
                nothing… it will copy the system units to the module units info
                • W
                  WouterEekhout
                  @Stoffbeuteluwe I’ve updated the code with the suggestions of @sdetweil . For now I put it into a separate branch. If this solutions works for you, I will push it to the master branch.
                  Execute the following:
                  git pull
                  git checkout incorrect_pointer_in_getdom
                  Will you let us know if this solved your problem?
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor @WouterEekhout
                    @WouterEekhout sorry does not work
                    Last login: Sat Jun  6 20:48:53 on ttys000
                    patrickhahn@Patricks-Mini ~ % cd ~/MagicMirror/modules
                    patrickhahn@Patricks-Mini modules % git clone https://github.com/WouterEekhout/MMM-Tado
                    Cloning into 'MMM-Tado'...
                    remote: Enumerating objects: 47, done.
                    remote: Counting objects: 100% (47/47), done.
                    remote: Compressing objects: 100% (39/39), done.
                    remote: Total 152 (delta 22), reused 23 (delta 6), pack-reused 105
                    Receiving objects: 100% (152/152), 841.64 KiB | 973.00 KiB/s, done.
                    Resolving deltas: 100% (50/50), done.
                    patrickhahn@Patricks-Mini modules % cd MMM-Tado
                    patrickhahn@Patricks-Mini MMM-Tado % npm install
                    npm WARN deprecated simple-oauth2@2.5.2: simple-oauth2 v2 is no longer supported. Please upgrade to v3 for further support
                    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                    npm WARN deprecated wreck@14.2.0: This module has moved and is now available at @hapi/wreck. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                    npm WARN deprecated boom@7.3.0: This module has moved and is now available at @hapi/boom. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                    npm WARN deprecated bourne@1.1.2: This module has moved and is now available at @hapi/bourne. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    added 42 packages from 446 contributors and audited 42 packages in 5.628s
                    1 package is looking for funding
                      run `npm fund` for details
                    found 1 low severity vulnerability
                      run `npm audit fix` to fix them, or `npm audit` for details
                    patrickhahn@Patricks-Mini MMM-Tado % git pull
                    Already up to date.
                    Branch 'incorrect_pointer_in_getdom' set up to track remote branch 'incorrect_pointer_in_getdom' from 'origin'.
                    Switched to a new branch 'incorrect_pointer_in_getdom'
                    • StoffbeuteluweS
                      @sdetweil it says undefined
                      W 1 Reply Last reply
                      • W
                        WouterEekhout @Stoffbeuteluwe
                        @Stoffbeuteluwe I’m assuming self.config.units is undefined on line 26. If that is the case then MagicMirror is having trouble reading in your global units configuration. Are you experiencing the same problem with other modules?
                        For your information, I am from the Netherlands and I also use the metric units. I tried your configurations settings from the following and it works for me.
                        If you just want to get the module running and forget about problem replace line 26 to the following:
                        this.config.units = 'metric';
                        Be sure you are on the master branch before replacing.
                        • StoffbeuteluweS
                          @WouterEekhout Hi my other modules work but this is not working and I don’t know why :thinking_face:
                          I will try to change the line 26…thanks for you help
