    MMM-Tado wrong units
    28 Posts 3 Posters 9.6k Views 4 Watching
      sdetweil @WouterEekhout
      @WouterEekhout ok, but… i don’t think that is what the USER wanted… their system is in metric, but they wanted your module display to be Fahrenheit, so I would use some other varname, and check to see if they specified that, and use IT over the system value…
      or because u have it as a default, if u set it to some invalid value, then check if its what you allow,
      then if invalid, use system, otherwise allow users value…
      • W
        WouterEekhout
        @sdetweil I disagree, it is unclear if the current config is not working or if he wanted a custom units setting for the app. @Stoffbeuteluwe Can you clarify if you wanted to set a different unit for the app?
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @WouterEekhout
          @WouterEekhout I am from Germany and I need metric unit but Sam helped me to fix and now it’s working for me.
          It would be cool to have the choice in module config. Metric or imperial
          Thanks to you guys
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe what is your main config.js units set to? up near address:
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @sdetweil
              @sdetweil it is metric
                @Stoffbeuteluwe so, the original code should have worked…
                • StoffbeuteluweS
                  @sdetweil without your fix it does not work in my case
                    @Stoffbeuteluwe hmm…
                    can u share the top of your config.js, before the modules:[ line
                    thanks
                    • StoffbeuteluweS
                      @sdetweil Hello, after module update same problem
                      and your fix don’t work anymore…can you help me again?
                      var config = {
                      	address: "0.0.0.0", // Address to listen on, can be:
                      	                      // - "0.0.0.0", "127.0.0.1", "::1" to listen on loopback interface
                      	                      // Default, when address config is left out, is "0.0.0.0"
                      	port: 8080,
                      	ipWhitelist: [], // Set [] to allow all IP addresses
                      	language: "de",
                      	timeFormat: 24,
                      	units: "metric",
                        @Stoffbeuteluwe ok, need an editor for this…
                        line 26 of MMM-Tado.js, leave alone
                        change all the other this.config.units to self.config.units
                        change them all, then change line 26 back to this.
                        I have opened issue 11
                        https://github.com/WouterEekhout/MMM-Tado/issues/11
                        • StoffbeuteluweS
                          @sdetweil no luck…sorry, I have changed 4x this into self
                          but I am not sure with the line 26
                           * Created by Wouter Eekhout on 06/01/2017.
                          Module.register("MMM-Tado", {
                              // Default module config.
                              defaults: {
                                  username: '',
                                  password: '',
                                  updateInterval: 300000,
                              tadoMe: {},
                              tadoHomes: [],
                              getStyles: function () {
                                  return [
                                      this.file('css/MMM-Tado.css'),
                              start: function () {
                                  if (this.config.updateInterval < this.defaults.updateInterval){
                                      this.config.updateInterval = this.defaults.updateInterval;
                                  this.config.units = self.config.units;
                                  this.sendSocketNotification('CONFIG', this.config);
                              // Override dom generator.
                              getDom: function () {
                                  let self = this;
                                  let wrapper = document.createElement("div");
                                  wrapper.className = "tado-info";
                                  this.tadoHomes.forEach(home => {
                                      let homeWrapper = document.createElement("div");
                                      homeWrapper.className = "tado-home";
                                      let logoWrapper = document.createElement("i");
                                      logoWrapper.className = "tado-icon-tado_logo tado-logo";
                                      homeWrapper.appendChild(logoWrapper);
                                      let tableWrapper = document.createElement("table");
                                      tableWrapper.className = "tado-table small";
                                      home.zones.forEach(zone => {
                                          let rowWrapper = document.createElement("tr");
                                          if (zone.type === "HOT_WATER") {
                                              let firstTableDataWrapper = document.createElement("td");
                                              firstTableDataWrapper.className = "tado-table-name";
                                              let zoneNameWrapper = document.createElement("span");
                                              zoneNameWrapper.innerText = zone.name;
                                              firstTableDataWrapper.appendChild(zoneNameWrapper);
                                              rowWrapper.appendChild(firstTableDataWrapper);
                                              let secondTableDateWrapper = document.createElement("td");
                                              secondTableDateWrapper.className = "tado-table-data";
                                              let temperatureWrapper = document.createElement("span");
                                              let temperatureIconWrapper = document.createElement("i");
                                              temperatureIconWrapper.className = "fa fa-thermometer-half";
                                              temperatureWrapper.appendChild(temperatureIconWrapper);
                                              if (zone.state.setting.temperature == null) {
                                                  var temperatureTextWrapper = document.createTextNode(zone.state.setting.power);
                                              } else {
                                                  if (self.config.units === "metric") {
                                                      var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                                                  } else {
                                                      var temperatureTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                                              temperatureWrapper.appendChild(temperatureTextWrapper);
                                              secondTableDateWrapper.appendChild(temperatureWrapper);
                                              rowWrapper.appendChild(secondTableDateWrapper);
                                          else if (zone.type === "HEATING") {
                                              //current temperature
                                              temperatureWrapper.className = "bright";
                                                  var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.celsius + "°");
                                              } else {
                                                  var temperatureTextWrapper = document.createTextNode(zone.state.sensorDataPoints.insideTemperature.fahrenheit + "°");
                                              if (zone.state.activityDataPoints.heatingPower.percentage > 0) {
                                                  //The zone is heating
                                                  let heatingWrapper = document.createElement("i");
                                                  heatingWrapper.className = "fa fa-fire bright";
                                                  temperatureWrapper.appendChild(heatingWrapper);
                                              //target temperature
                                              let temperatureTargetWrapper = document.createElement("span");
                                              temperatureTargetWrapper.className = "xsmall";
                                              let temperatureTargetIconWrapper = document.createElement("i");
                                              temperatureTargetIconWrapper.className = "fa fa-thermometer-half";
                                              temperatureTargetWrapper.appendChild(temperatureTargetIconWrapper);
                                                  var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.power);
                                              } else {
                                                      var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.celsius + "°");
                                                  } else {
                                                      var temperatureTargetTextWrapper = document.createTextNode(zone.state.setting.temperature.fahrenheit + "°");
                                              temperatureTargetWrapper.appendChild(temperatureTargetTextWrapper);
                                              secondTableDateWrapper.appendChild(temperatureTargetWrapper);
                                              let breakLine = document.createElement("br");
                                              secondTableDateWrapper.appendChild(breakLine);
                                              let humidityWrapper = document.createElement("span");
                                              let humidityIconWrapper = document.createElement("i");
                                              humidityIconWrapper.className = "fa fa-tint";
                                              humidityWrapper.appendChild(humidityIconWrapper);
                                              let humidityTextWrapper = document.createTextNode(zone.state.sensorDataPoints.humidity.percentage + "%");
                                              humidityWrapper.appendChild(humidityTextWrapper);
                                              secondTableDateWrapper.appendChild(humidityWrapper);
                                          else if (zone.type === "AIR_CONDITIONING") {
                                              } else {
                                              if (zone.state.setting.mode === "HEAT") {
                                              else if (zone.state.setting.mode === "COOL") {
                                                  //The zone is cooling
                                                  let coolingWrapper = document.createElement("i");
                                                  coolingWrapper.className = "fa fa-snowflake bright";
                                                  temperatureWrapper.appendChild(coolingWrapper);
                                              } else {
                                                  } else {
                                          } else {
                                              //don't add it
                                              return;
                                          tableWrapper.appendChild(rowWrapper);
                                      homeWrapper.appendChild(tableWrapper);
                                      wrapper.appendChild(homeWrapper);
                                  return wrapper;
                                  if (notification === 'NEW_DATA') {
                                      this.tadoMe = payload.tadoMe;
                                      this.tadoHomes = payload.tadoHomes;
                                      this.updateDom();
                            @Stoffbeuteluwe weird… i’ll be back on in about 6 hours, do you know how to use the debugger?
                            ctrl-shift-i on teh keyboard, select the sources tab, navigate the left tree to find the module and filename, click
                            shows in middle window
                            scroll down to one of the if (self.config.units lines (make sure u have that type unit in the tado data)
                            click the number on the start of the line, it should turn blue
                            hit refresh
                            the code will stop there
                            mouse over the self and a box will pop up showing what self points to, then config
                            same… units should say metric
                              @Stoffbeuteluwe said in MMM-Tado wrong units:
                              nothing… it will copy the system units to the module units info
                              • W
                                WouterEekhout
                                @Stoffbeuteluwe I’ve updated the code with the suggestions of @sdetweil . For now I put it into a separate branch. If this solutions works for you, I will push it to the master branch.
                                Execute the following:
                                git pull
                                git checkout incorrect_pointer_in_getdom
                                Will you let us know if this solved your problem?
                                • StoffbeuteluweS
                                  @WouterEekhout sorry does not work
                                  Last login: Sat Jun  6 20:48:53 on ttys000
                                  patrickhahn@Patricks-Mini ~ % cd ~/MagicMirror/modules
                                  patrickhahn@Patricks-Mini modules % git clone https://github.com/WouterEekhout/MMM-Tado
                                  Cloning into 'MMM-Tado'...
                                  remote: Enumerating objects: 47, done.
                                  remote: Counting objects: 100% (47/47), done.
                                  remote: Compressing objects: 100% (39/39), done.
                                  remote: Total 152 (delta 22), reused 23 (delta 6), pack-reused 105
                                  Receiving objects: 100% (152/152), 841.64 KiB | 973.00 KiB/s, done.
                                  Resolving deltas: 100% (50/50), done.
                                  patrickhahn@Patricks-Mini modules % cd MMM-Tado
                                  patrickhahn@Patricks-Mini MMM-Tado % npm install
                                  npm WARN deprecated simple-oauth2@2.5.2: simple-oauth2 v2 is no longer supported. Please upgrade to v3 for further support
                                  npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                                  npm WARN deprecated wreck@14.2.0: This module has moved and is now available at @hapi/wreck. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm WARN deprecated boom@7.3.0: This module has moved and is now available at @hapi/boom. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm WARN deprecated bourne@1.1.2: This module has moved and is now available at @hapi/bourne. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                                  npm notice created a lockfile as package-lock.json. You should commit this file.
                                  added 42 packages from 446 contributors and audited 42 packages in 5.628s
                                  1 package is looking for funding
                                    run `npm fund` for details
                                  found 1 low severity vulnerability
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  patrickhahn@Patricks-Mini MMM-Tado % git pull
                                  Already up to date.
                                  Branch 'incorrect_pointer_in_getdom' set up to track remote branch 'incorrect_pointer_in_getdom' from 'origin'.
                                  Switched to a new branch 'incorrect_pointer_in_getdom'
                                  • StoffbeuteluweS
                                    @sdetweil it says undefined
                                    • W
                                      WouterEekhout @Stoffbeuteluwe
                                      @Stoffbeuteluwe I’m assuming self.config.units is undefined on line 26. If that is the case then MagicMirror is having trouble reading in your global units configuration. Are you experiencing the same problem with other modules?
                                      For your information, I am from the Netherlands and I also use the metric units. I tried your configurations settings from the following and it works for me.
                                      If you just want to get the module running and forget about problem replace line 26 to the following:
                                      this.config.units = 'metric';
                                      Be sure you are on the master branch before replacing.
                                      • StoffbeuteluweS
                                        @WouterEekhout Hi my other modules work but this is not working and I don’t know why :thinking_face:
                                        I will try to change the line 26…thanks for you help
