    MMM-Awesome-Alexa Problems
    5 Posts 3 Posters 919 Views 3 Watching
    • F Offline
      Florin01
      Hello! I’m new here and I want to integrate my Echo Dot 2 with the Awesome Alexa Module but I get 1000 mil errors after : npm install --only=pred command. I followed all the steps.
      pi@raspberrypi:~/MagicMirror/modules/MMM-awesome-alexa $ npm install
      npm WARN deprecated request@2.81.0: request has been deprecated, see https://github.com/request/request/issues/3142
      snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.21.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
      make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’
      CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
      In file included from …/swig/Node/snowboy.cc:1:
      …/…/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      …/…/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      …/swig/Node/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
      …/swig/Node/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
      } catch (std::runtime_error e) {
      In file included from …/…/nan/nan.h:54,
      …/swig/Node/snowboy.cc: At global scope:
      /home/pi/.cache/node-gyp/10.21.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
      (node::addon_register_func) (regfunc),
      /home/pi/.cache/node-gyp/10.21.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
      NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      …/swig/Node/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
      In file included from /home/pi/.cache/node-gyp/10.21.0/include/node/node.h:63,
      /home/pi/.cache/node-gyp/10.21.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase::SetWeak(P*, typename v8::WeakCallbackInfo
      ::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
      ::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
      /home/pi/.cache/node-gyp/10.21.0/include/node/node_object_wrap.h:84:78: required from here
      /home/pi/.cache/node-gyp/10.21.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
      )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
      reinterpret_cast(callback), type);
      ::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
      ::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
      …/…/nan/nan_object_wrap.h:65:61: required from here
      /home/pi/.cache/node-gyp/10.21.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
      )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
      )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
      rm: cannot remove ‘./Release/.deps/Release/obj.target/snowboy/swig/Node/snowboy.o.d.raw’: No such file or directory
      make: *** [snowboy.target.mk:109: Release/obj.target/snowboy/swig/Node/snowboy.o] Error 1
      make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’
      SOLINK_MODULE(target) Release/obj.target/snowboy.node
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.118-v7l+
      gyp ERR! command “/usr/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “build” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      gyp ERR! node -v v10.21.0
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)
      node-pre-gyp ERR! stack at ChildProcess. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.118-v7l+
      node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
      node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      node-pre-gyp ERR! node -v v10.21.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
      node-pre-gyp ERR! not ok
      /usr/bin/ld: cannot find -lcblasinfo lifecycle snowboy@1.3.1~install: Failed to exec install script
      collect2: error: ld returned 1 exit status
      make: *** [snowboy.target.mk:139: Release/obj.target/snowboy.node] Error 1
      gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! snowboy@1.3.1 install: node-pre-gyp install --fallback-to-build
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the snowboy@1.3.1 install script.
      npm ERR! /home/pi/.npm/_logs/2020-06-09T15_47_19_130Z-debug.log
        sdetweil @Florin01
        @Florin01
        some dependency is missing
        do this
        sudo apt-get install libatlas-base-dev
        then try the npm install --only=prod on awesome alexa again
        snowboy is a pain in the rear…
        • F Offline
          Florin01 @sdetweil
          @sdetweil Hey, thanks for the help but I still have the errors :(
          • bheplerB Offline
            bhepler Module Developer
            Please use the Markdown features of the forum when posting error messages and code.
            Are they the same errors? Specifically, look for /usr/bin/ld: cannot find -lcblasinfo lifecycle snowboy@1.3.1~install: Failed to exec install script and see if that error message is still coming back. If it’s a different error, copy it and let us know.
            • F Offline
              Florin01 @bhepler
              @bhepler thanks for the help but I will stick to the MMM-AlexaControl now. There are too many errors with this module :( .
