    updated installer script available for testing
    211 Posts 18 Posters 337.4k Views 19 Watching
      bdream
      @sdetweil Hey Sam
      After a longer while absense, I just took your installation script for a new installation on an Pi0.
      It worked staright foreward :flexed_biceps:
      You made such a great job:ok_hand:! Many thanks!
      One short question came just up.
      I get a message on my Mirror, that Chromium can’t get updated.
      As I have no keybord connected I don’t know how to update and get rid of this message-window
      cheers, bdream
      S 2 Replies Last reply
        sdetweil @bdream
        @bdream yeh, I don’t like that message either, also no keyboard… haven’t looked at it in a while.
          sdetweil @bdream
          @bdream lets try this https://stackoverflow.com/questions/58993181/disable-chromium-can-not-update-chromium-window-notification
          if it works, I’ll add it to the installer
            @sdetweil there is a one liner commands on the last post… this looks good, and I see that the parm is added to the running chromium
            sudo touch /etc/chromium-browser/customizations/01-disable-update-check;echo CHROMIUM_FLAGS=\"\$\{CHROMIUM_FLAGS\} --check-for-update-interval=31536000\" | sudo tee /etc/chromium-browser/customizations/01-disable-update-check
              @bdream I’ve added this to the install and upgrade scripts. thanks for the nudge to work on this
                bdream
                @sdetweil you are my hero! …and faster as police allows :motorcycle:
                I have added the statement 01-disable-update-check as mentioned. – and it works. Even “It effectively disables the update check for 1 year, until then a fix should have been distributed.” as mentioned in link text
                cheers, bdream
                  sdetweil @bdream
                  @bdream i can see where they might want to update if its a general purpose web viewer with millions of pages a day of all kinds… in our little viewer world, its a very constrained, fairly generic set of content.
                  StoffbeuteluweS 1 Reply Last reply
                    bdream
                    :thumbs_up: you are right, Sam!
                    cheers, bdream
                    • StoffbeuteluweS
                      Stoffbeuteluwe Project Sponsor @sdetweil
                      @sdetweil Hi Sam, do I have to install node and npm first and than install the script or do the script install all this?
                      Greetings from Germany
                        sdetweil @Stoffbeuteluwe
                        @stoffbeuteluwe script does it all
                        • StoffbeuteluweS
                          @sdetweil oh thx for the fast answer ….
                          • 10
                          • 11
                          • 11 / 11
