    updated installer script available for testing
    211 Posts 18 Posters 330.9k Views 19 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe so much fun…
      I put in a fix
      remove the MagicMirror folder and try again…
      I had not tried installer on mac since 2.10… sorry…
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil MM install was without problems thank you…
        but pm2 say error but it works…
        Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
        install and setup pm2
        Password:
        [PM2][ERROR] Init system not found
        /bin/sh: launchctl: command not found
        [PM2][ERROR] launchctl load -w /Users/patrickhahn/Library/LaunchAgents/pm2.patrickhahn.plist failed, see error above.
        [PM2] Spawning PM2 daemon with pm2_home=/Users/patrickhahn/.pm2
        [PM2] PM2 Successfully daemonized
        [PM2][WARN] Applications MagicMirror not running, starting...
        [PM2] App [MagicMirror] launched (1 instances)
        │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 0   │ MagicMirror    │ default     │ 2.11.0  │ fork    │ 4867     │ 0s     │ 0    │ online    │ 0%       │ 1.0mb    │ pat… │ enabled  │
        [PM2] Saving current process list...
        [PM2] Successfully saved in /Users/patrickhahn/.pm2/dump.pm2
        Do you want to disable the screen saver? (y/N)?y
        2020-05-22 14:37:06.275 defaults[5057:87330]
        The domain/default pair of (com.apple.screensaver, idleTime) does not exist
        bash: line 537: [: !=: unary operator expected
        \e[92mWe're ready! Run \e[1m\e[97mpm2 start MagicMirror\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
        patrickhahn@Mac-mini ~ %
          @Stoffbeuteluwe ok, on the screensaver can u show the results of this
          defaults -currentHost read com.apple.screensaver
          thanks… working on the pm2 issue
          what os level are u running on the mini?
          • StoffbeuteluweS
            version10.15.4 (19E287)
              @Stoffbeuteluwe same here
                @Stoffbeuteluwe also can u do this
                which launchctl
                and this
                also the output of this
                pm2 startup
                thanks
                  bdream
                  @sdetweil Hey Sam
                  After a longer while absense, I just took your installation script for a new installation on an Pi0.
                  It worked staright foreward :flexed_biceps:
                  You made such a great job:ok_hand:! Many thanks!
                  One short question came just up.
                  I get a message on my Mirror, that Chromium can’t get updated.
                  As I have no keybord connected I don’t know how to update and get rid of this message-window
                  cheers, bdream
                    sdetweil @bdream
                    @bdream yeh, I don’t like that message either, also no keyboard… haven’t looked at it in a while.
                      sdetweil @bdream
                      @bdream lets try this https://stackoverflow.com/questions/58993181/disable-chromium-can-not-update-chromium-window-notification
                      if it works, I’ll add it to the installer
                        @sdetweil there is a one liner commands on the last post… this looks good, and I see that the parm is added to the running chromium
                        sudo touch /etc/chromium-browser/customizations/01-disable-update-check;echo CHROMIUM_FLAGS=\"\$\{CHROMIUM_FLAGS\} --check-for-update-interval=31536000\" | sudo tee /etc/chromium-browser/customizations/01-disable-update-check
                          @bdream I’ve added this to the install and upgrade scripts. thanks for the nudge to work on this
                            bdream
                            @sdetweil you are my hero! …and faster as police allows :motorcycle:
                            I have added the statement 01-disable-update-check as mentioned. – and it works. Even “It effectively disables the update check for 1 year, until then a fix should have been distributed.” as mentioned in link text
                            cheers, bdream
                              sdetweil @bdream
                              @bdream i can see where they might want to update if its a general purpose web viewer with millions of pages a day of all kinds… in our little viewer world, its a very constrained, fairly generic set of content.
                                bdream
                                :thumbs_up: you are right, Sam!
                                cheers, bdream
                                • StoffbeuteluweS
                                  @sdetweil Hi Sam, do I have to install node and npm first and than install the script or do the script install all this?
                                  Greetings from Germany
                                    @stoffbeuteluwe script does it all
                                    StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                                    • StoffbeuteluweS
                                      @sdetweil oh thx for the fast answer ….
                                      • 10
                                      • 11
                                      • 11 / 11
