    updated installer script available for testing
    211 Posts 18 Posters 337.5k Views 19 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @sdetweil
      version10.15.4 (19E287)
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe same here
          @Stoffbeuteluwe also can u do this
          which launchctl
          and this
          defaults -currentHost read com.apple.screensaver
          also the output of this
          pm2 startup
          thanks
            bdream
            @sdetweil Hey Sam
            After a longer while absense, I just took your installation script for a new installation on an Pi0.
            It worked staright foreward :flexed_biceps:
            You made such a great job:ok_hand:! Many thanks!
            One short question came just up.
            I get a message on my Mirror, that Chromium can’t get updated.
            As I have no keybord connected I don’t know how to update and get rid of this message-window
            cheers, bdream
            S 2 Replies Last reply
              sdetweil @bdream
              @bdream yeh, I don’t like that message either, also no keyboard… haven’t looked at it in a while.
                sdetweil @bdream
                @bdream lets try this https://stackoverflow.com/questions/58993181/disable-chromium-can-not-update-chromium-window-notification
                if it works, I’ll add it to the installer
                  @sdetweil there is a one liner commands on the last post… this looks good, and I see that the parm is added to the running chromium
                  sudo touch /etc/chromium-browser/customizations/01-disable-update-check;echo CHROMIUM_FLAGS=\"\$\{CHROMIUM_FLAGS\} --check-for-update-interval=31536000\" | sudo tee /etc/chromium-browser/customizations/01-disable-update-check
                    @bdream I’ve added this to the install and upgrade scripts. thanks for the nudge to work on this
                      bdream
                      @sdetweil you are my hero! …and faster as police allows :motorcycle:
                      I have added the statement 01-disable-update-check as mentioned. – and it works. Even “It effectively disables the update check for 1 year, until then a fix should have been distributed.” as mentioned in link text
                      cheers, bdream
                        sdetweil @bdream
                        @bdream i can see where they might want to update if its a general purpose web viewer with millions of pages a day of all kinds… in our little viewer world, its a very constrained, fairly generic set of content.
                        StoffbeuteluweS 1 Reply Last reply
                          bdream
                          :thumbs_up: you are right, Sam!
                          cheers, bdream
                          • StoffbeuteluweS
                            @sdetweil Hi Sam, do I have to install node and npm first and than install the script or do the script install all this?
                            Greetings from Germany
                              @stoffbeuteluwe script does it all
                              • StoffbeuteluweS
                                @sdetweil oh thx for the fast answer ….
                                • 10
                                • 11
                                • 11 / 11
