    weather forecast and current weather modules
    Scheduled Pinned Locked Moved Unsolved General Discussion
    22 Posts 8 Posters 11.6k Views 7 Watching
      sdetweil @Guest
      @hango in your post of 'config, you put it in the global section,
      not in the little config:{} section related to each module
      this is why u are having trouble…
      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1592416623888
        A Former User @sdetweil
        S lavolp3L 2 Replies Last reply Reply Quote 0
          sdetweil @Guest
          @hango its NOT supposed to go in the global section…
              sdetweil @Guest
              @hango because it specific to ONE module, and should go in the ONE module config:{}
                  sdetweil @Guest
                  @hango ok, maybe YOU know what your getting yourself into… most users don’t…
                  follow the rules, talk about how you are SUPPOSED to do things… teach them the RIGHT way.
                  i’m here because I want to be, help users, we have enough problems with old docs written and not maintained, old code written and not maintained, we don’t need special instructions that are fragile.
                    A Former User
                    • lavolp3L
                      lavolp3 Module Developer @Guest
                      @hango this way you’ll always have problems updating the respective modules. You would have to reset all of your local changes and fill them in after an update.
                      How do you deal with that?
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        A Former User
