    grafana module for bar graphs display.
    9 Posts 5 Posters 3.0k Views 4 Watching
      doubleT Module Developer
      looking at the module, it is just an iFrame that displays a grafana graph. So there is not much anyone on here could do. I don’t know anything about graphana, but from what I’ve seen, it seems like graphana is capable of doing “horizontal graphs” (meaning bars vertically stacked and growing horizontally?).
      Seems like you’d have to look for help in the grafana community. As I said, it seems like the module here just shows whatever you have in grafana.
      Do you have a grafana ready? Or an example of an image what you have and what it should look like?
      Regards,
      Torben
      • I Offline
        iorifly @doubleT
        @doubleT
        I have the graphics ready on the graphana and everything is working.
        In fact, I am in a tireless quest to display my HA data in MM. And I found the module HA> graphana> MM. But it is abandoned.
          Ok, I cloned the module, set up a grafana and tried it out.
          The console error shows: Refused to display 'https://myname.grafana.net/login' in a frame because it set 'X-Frame-Options' to 'deny'.
          Searching for that on Google brought me to the Grafana website:
          Embedding Grafana
          If you’re embedding Grafana in a frame, iframe, embed or object on a different website it will no longer work due to a new setting that per default instructs the browser to not allow Grafana to be embedded.
          There are two topics on that: https://github.com/grafana/grafana/issues/17458, https://github.com/grafana/grafana/issues/15714
          Without any further investigation it seems like there are some settings that need to be done when you’re hosting grafana? So maybe it’s not possible to get to these settings on the free hosted versions?
          There are two other issues:
          If using the free hosted version there’s something about an API key. That might be an issue as well?
          And the module config is not asking for the entire grafana URL but wants several parts of the URL, but the actual grafana URL seems to be different to what the module is making out of these parts.
          Sorry, at the moment I can’t look any further into this, maybe someone else is interested in grafana and comes up with a solution.
          @SvenSommer?
          rubenixR 1 Reply Last reply Reply Quote 0
          • rubenixR Offline
            rubenix @doubleT
            @doubleT Im on the same boat;
            i can display the grafana playlist on every single device on same subnet (TV, mobile, PC, laptop) except the mirror (hosted on a pi). so i guess there’s something with electron cause it works on other devices as i said…
            here part of grafana.ini config file involving security.
            [security]
            allow_embedding=true
            cookie_samesite=none
            here dev console logs
            Load denied by X-Frame-Options: http://192.168.x.x:3000/playlists/play/1?kiosk does not permit framing.
            tried to show the playlist with MMM-iFrame, MMM-SmartWebdisplay & MMM-Widget with same results.
            btw: grafana hosted on another pi inside a docker container…just leave it here with hope some of the expets here can throw some suggestion.
            • Piranha1605P Offline
              Piranha1605
              maybe that will help you.
              x-frame-bypass
              • rubenixR Offline
                rubenix @Piranha1605
                @Piranha1605 Thanks tried that already, it trows:
                ‘The play method is not allowed by the user agent or the platform in the current context, possibly because the user denied permission.’
