    MMM-awesome-alexa
    241 Posts 43 Posters 461.3k Views 47 Watching
      bumrocks @sdetweil
      @sdetweil , you are a good guy. Much appreciated all that you obviously do and in areas that you don’t necessarily have to. Thank you very much 😁
      • U
        uok825
        Can anyone fix this pm2 issue?
          sdetweil @uok825
          @uok825 i don’t see any info on a pm2 issue
          U 1 Reply Last reply
          • U
            uok825 @sdetweil
            First Page
            PM2 problems
            For some reason, running MagicMirror on PM2 with this module doesn’t seem to work on Raspberry Pi. The mic does not pick up. If anyone has a solution or cause for this, it would be greatly appreciated. I would recommend to start the MagicMirror the traditional way of npm start.
            I have that issue.
              sdetweil @uok825
              @uok825 can u show the pm2 logs during this kind of launch
              pm2 stop  0
              pm2 flush
              pm2 start 0
              do your tests
              pm2 logs --lines=100
              pm2 info 0
              • U
                uok825 @sdetweil
                0|mmstart | [2020-06-26 14:34:32.173] [LOG] Starting MagicMirror: v2.11.0
                0|mmstart | [2020-06-26 14:34:32.272] [LOG] Loading config …
                0|mmstart | [2020-06-26 14:34:32.332] [LOG] Loading module helpers …
                0|mmstart | [2020-06-26 14:34:32.646] [LOG] Initializing new module helper . …
                0|mmstart | [2020-06-26 14:34:32.666] [LOG] Module helper loaded: updatenoti fication
                0|mmstart | [2020-06-26 14:34:32.703] [LOG] No helper found for module: hell oworld.
                0|mmstart | [2020-06-26 14:34:32.710] [LOG] All module helpers loaded.
                0|mmstart | [2020-06-26 14:34:33.525] [LOG] Starting server on port 8080 …
                0|mmstart | [2020-06-26 14:34:33.667] [LOG] Server started …
                0|mmstart | [2020-06-26 14:34:33.676] [LOG] Connecting socket for: updatenot ification
                0|mmstart | [2020-06-26 14:34:33.684] [LOG] Sockets connected & modules star ted …
                0|mmstart | [2020-06-26 14:34:33.691] [LOG]
                0|mmstart | Ready to go! Please point your browser to: http://localhost:8080
                pm20|mmstart | X.Org X Server 1.19.2
                0|mmstart | Release Date: 2017-03-02
                0|mmstart | X Protocol Version 11, Revision 0
                0|mmstart | Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
                0|mmstart | Current Operating System: Linux raspberrypi 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l
                0|mmstart | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1440 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:C2:8B:EA vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=00dad306-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                0|mmstart | Build Date: 18 October 2017 04:55:30PM
                0|mmstart | xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
                0|mmstart | Current version of pixman: 0.34.0
                0|mmstart | Before reporting problems, check http://wiki.x.org
                0|mmstart | to make sure that you have the latest version.
                0|mmstart | Markers: (–) probed, (**) from config file, (==) default setting,
                0|mmstart | (++) from command line, (!!) notice, (II) informational,
                0|mmstart | (WW) warning,
                0|mmstart | (EE) error, (NI) not implemented, (??) unknown.
                0|mmstart | (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jun 26 14:34:56 2020
                0|mmstart | (==) Using system config directory “/usr/share/X11/xorg.conf.d” 0|mmstart | Fontconfig warning: “/etc/fonts/fonts.conf”, line 100:
                0|mmstart | unknown element “blank”
                0|mmstart | [5863:6076:0626/143511.431135:ERROR:bus.cc(396)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
                0|mmstart | [5863:5890:0626/143514.718350:ERROR:simple_backend_impl.cc(118)] Failed to create directory: /dev/null/Default/Cache
                0|mmstart | [5863:5890:0626/143514.729068:ERROR:simple_backend_impl.cc(728)] Simple Cache Backend: wrong file structure on disk: 1 path: /dev/null/Default/Cache
                0|mmstart | [5863:5882:0626/143514.730785:ERROR:cache_util.cc(140)] Unable to move cache folder /dev/null/Default/Cache to /dev/null/Default/old_Cache_000
                0|mmstart | [5863:5882:0626/143514.731049:ERROR:disk_cache.cc(184)] Unable to create cache
                x0|mmstart | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                0|mmstart | [1:8:0626/143529.824588:ERROR:command_buffer_proxy_impl.cc(124)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
                  sdetweil @uok825
                  @uok825 said in MMM-awesome-alexa:
                  what is all that?
                  what device is this on? pi 0?
                  I don’t see the alexa module being loaded
                  • U
                    uok825 @sdetweil
                    @sdetweil Yes pi0 and not desktop system.
                      sdetweil @uok825
                      @uok825
                      I don’t see the alexa node_helper being loaded.
                      also this config.js has the hello word sample module
                      • U
                        uok825 @sdetweil
                        @sdetweil I installed new module can you wait for a moment i configure my config file and install awesome alexa. I will reply.
                          sdetweil @uok825
                          @uok825 also show output of pm2 info 0
                          • U
                            uok825 @sdetweil
                              sdetweil @uok825
                              @uok825 and show /home/pi/mmstart.sh please
                              • U
                                uok825 @sdetweil
                                mmstart
                                #!/bin/bash
                                node serveronly &
                                sleep 30
                                xinit /home/pi/chromium_start.sh
                                chromium_start
                                #!/bin/sh
                                xset -dpms # disable DPMS (Energy Star) features.
                                xset s off # disable screen saver
                                xset s noblank # don’t blank the video device
                                matchbox-window-manager &
                                #midori -e Fullscreen -a http://localhost:8080
                                chromium-browser http://localhost:8080/ --window-size=1920,1080 --start-fullscreen --kiosk --incognito --noerrdialogs --disable-translate --no-first-run --fast --fast-start --disable-infobars --disable-features=TranslateUI --disk-cache-dir=/dev/null
                                  sdetweil @uok825
                                  @uok825 such a shame you rebuilt all this yourself… if u had used my install script it would have set it all up for you…
                                  just use raspian buster full and voila…
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil Sorry i saw this first http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                                      sdetweil @uok825
                                      @uok825 yeh, old stuff…
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Can you share link your script i flash another sd card raspian and try yourse thx for the help
                                          sdetweil @uok825
                                          @uok825 all my scripts are here
                                          just copy/paste the command for install
                                          use raspian buster
                                          https://www.raspberrypi.org/downloads/raspberry-pi-os/
                                          i test on my pi0w all the time
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil okey thx the raspian is downloading
                                            • 12
                                            • 13
                                            • 6 / 13
