    MMM-awesome-alexa
    241 Posts 43 Posters 440.5k Views 47 Watching
      PHAGE.GOV @dolanmiu
      @dolanmiu Hello, i know you probably get asked this alot, but i got the client id and client secret, but I can’t figure out what to put for the allowed return urls, or how to find/make them on the amazon dev side and on the magic mirror side
        bumrocks @sdetweil
        @sdetweil said in MMM-awesome-alexa:
        @vlatko_jordanov I am trying to set this up but my brain cannot figure out what I am supposed to put in as the return url in the AVS setup…
        edit: DOAH… read the instructions!!! lol… it is EPEXCTED to FAIL to connect… read the text from the failing url
        got that… BUT then next step fails for me…
         Enter your Authorization code (from previous step): ANMJShcLPpSKjJkKLbzj
          ◡ Getting response from Amazon...(node:2772) UnhandledPromiseRejectionWarning: StatusCodeError: 400 - {"error_description":"The request has an invalid grant parameter : code","error":"invalid_grant"}
        @sdetweil , man am I happy to see you in here…First things first, I searched within your github page for a way to make a donation to you fir your help and efforts but found nothing…Point me in the right direction to do so please! Once you do, I will gladly show some appreciation to you ;)
        Once that is done I hope you might help in the above situation. I get to this point in the Configuration Helper Tool and have no clue as to what I should enter for a Redirect uri and I never read anywhere about it supposed to fail. And then in advance I’ll ask about the next part you mention where you say the next step fails for you. Did you figure that out?
        Thank you!
        Note: I do have an echo dot device in my home and from reading numerous comments, this seems to help in some way…
        Also, when adding the recommended line to the elctron.js file is it supposed to simply look like this?
        // Start the core application if server is run on localhost
        // This starts all node helpers and starts the webserver.
        if (["localhost", "127.0.0.1", "::1", "::ffff:127.0.0.1", undefined].indexOf(config.address) > -1) {
        	core.start(function(c) {
        		config = c;
        app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
        It does not appear so…As if it is too simple…
          sdetweil @bumrocks
          @bumrocks you don’t need that line anywhere, we added it back in 2.9 as part of the base.
          as for the alexa thing, the way the process works, you use the client id/and secret, and some uri to call back to when the authorization is comnplete…
          but there is nothing running on your pi to call, so it errors out,
          BUT the url it is trying to call is right there with the code you need to copy
          SO, knowing there is nothing to call back to, just use http://localhost:1234
          then the web page will come up, you give permission, and then it tries to call http://localhost:1234 with the access code, and fails, but the code is show on the address bar line
          ps… I don’t take contributions… I do this cause I like it.
            bumrocks @sdetweil
            @sdetweil , you are a good guy. Much appreciated all that you obviously do and in areas that you don’t necessarily have to. Thank you very much 😁
            • U Offline
              uok825
              Can anyone fix this pm2 issue?
                sdetweil @uok825
                @uok825 i don’t see any info on a pm2 issue
                U 1 Reply Last reply Reply Quote 0
                • U Offline
                  uok825 @sdetweil
                  First Page
                  PM2 problems
                  For some reason, running MagicMirror on PM2 with this module doesn’t seem to work on Raspberry Pi. The mic does not pick up. If anyone has a solution or cause for this, it would be greatly appreciated. I would recommend to start the MagicMirror the traditional way of npm start.
                  I have that issue.
                    sdetweil @uok825
                    @uok825 can u show the pm2 logs during this kind of launch
                    pm2 stop  0
                    pm2 flush
                    pm2 start 0
                    do your tests
                    pm2 logs --lines=100
                    pm2 info 0
                    • U Offline
                      uok825 @sdetweil
                      0|mmstart | [2020-06-26 14:34:32.173] [LOG] Starting MagicMirror: v2.11.0
                      0|mmstart | [2020-06-26 14:34:32.272] [LOG] Loading config …
                      0|mmstart | [2020-06-26 14:34:32.332] [LOG] Loading module helpers …
                      0|mmstart | [2020-06-26 14:34:32.646] [LOG] Initializing new module helper . …
                      0|mmstart | [2020-06-26 14:34:32.666] [LOG] Module helper loaded: updatenoti fication
                      0|mmstart | [2020-06-26 14:34:32.703] [LOG] No helper found for module: hell oworld.
                      0|mmstart | [2020-06-26 14:34:32.710] [LOG] All module helpers loaded.
                      0|mmstart | [2020-06-26 14:34:33.525] [LOG] Starting server on port 8080 …
                      0|mmstart | [2020-06-26 14:34:33.667] [LOG] Server started …
                      0|mmstart | [2020-06-26 14:34:33.676] [LOG] Connecting socket for: updatenot ification
                      0|mmstart | [2020-06-26 14:34:33.684] [LOG] Sockets connected & modules star ted …
                      0|mmstart | [2020-06-26 14:34:33.691] [LOG]
                      0|mmstart | Ready to go! Please point your browser to: http://localhost:8080
                      pm20|mmstart | X.Org X Server 1.19.2
                      0|mmstart | Release Date: 2017-03-02
                      0|mmstart | X Protocol Version 11, Revision 0
                      0|mmstart | Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
                      0|mmstart | Current Operating System: Linux raspberrypi 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l
                      0|mmstart | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1440 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:C2:8B:EA vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=00dad306-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                      0|mmstart | Build Date: 18 October 2017 04:55:30PM
                      0|mmstart | xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
                      0|mmstart | Current version of pixman: 0.34.0
                      0|mmstart | Before reporting problems, check http://wiki.x.org
                      0|mmstart | to make sure that you have the latest version.
                      0|mmstart | Markers: (–) probed, (**) from config file, (==) default setting,
                      0|mmstart | (++) from command line, (!!) notice, (II) informational,
                      0|mmstart | (WW) warning,
                      0|mmstart | (EE) error, (NI) not implemented, (??) unknown.
                      0|mmstart | (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jun 26 14:34:56 2020
                      0|mmstart | (==) Using system config directory “/usr/share/X11/xorg.conf.d” 0|mmstart | Fontconfig warning: “/etc/fonts/fonts.conf”, line 100:
                      0|mmstart | unknown element “blank”
                      0|mmstart | [5863:6076:0626/143511.431135:ERROR:bus.cc(396)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
                      0|mmstart | [5863:5890:0626/143514.718350:ERROR:simple_backend_impl.cc(118)] Failed to create directory: /dev/null/Default/Cache
                      0|mmstart | [5863:5890:0626/143514.729068:ERROR:simple_backend_impl.cc(728)] Simple Cache Backend: wrong file structure on disk: 1 path: /dev/null/Default/Cache
                      0|mmstart | [5863:5882:0626/143514.730785:ERROR:cache_util.cc(140)] Unable to move cache folder /dev/null/Default/Cache to /dev/null/Default/old_Cache_000
                      0|mmstart | [5863:5882:0626/143514.731049:ERROR:disk_cache.cc(184)] Unable to create cache
                      x0|mmstart | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                      0|mmstart | [1:8:0626/143529.824588:ERROR:command_buffer_proxy_impl.cc(124)] ContextResult::kTransientFailure: Failed to send GpuChannelMsg_CreateCommandBuffer.
                        sdetweil @uok825
                        @uok825 said in MMM-awesome-alexa:
                        what is all that?
                        what device is this on? pi 0?
                        I don’t see the alexa module being loaded
                        • U Offline
                          uok825 @sdetweil
                          @sdetweil Yes pi0 and not desktop system.
                            sdetweil @uok825
                            @uok825
                            I don’t see the alexa node_helper being loaded.
                            also this config.js has the hello word sample module
                            • U Offline
                              uok825 @sdetweil
                              @sdetweil I installed new module can you wait for a moment i configure my config file and install awesome alexa. I will reply.
                                sdetweil @uok825
                                @uok825 also show output of pm2 info 0
                                • U Offline
                                  uok825 @sdetweil
                                    sdetweil @uok825
                                    @uok825 and show /home/pi/mmstart.sh please
                                    • U Offline
                                      uok825 @sdetweil
                                      mmstart
                                      #!/bin/bash
                                      node serveronly &
                                      sleep 30
                                      xinit /home/pi/chromium_start.sh
                                      chromium_start
                                      #!/bin/sh
                                      xset -dpms # disable DPMS (Energy Star) features.
                                      xset s off # disable screen saver
                                      xset s noblank # don’t blank the video device
                                      matchbox-window-manager &
                                      #midori -e Fullscreen -a http://localhost:8080
                                      chromium-browser http://localhost:8080/ --window-size=1920,1080 --start-fullscreen --kiosk --incognito --noerrdialogs --disable-translate --no-first-run --fast --fast-start --disable-infobars --disable-features=TranslateUI --disk-cache-dir=/dev/null
                                        sdetweil @uok825
                                        @uok825 such a shame you rebuilt all this yourself… if u had used my install script it would have set it all up for you…
                                        just use raspian buster full and voila…
                                        • U Offline
                                          uok825 @sdetweil
                                          @sdetweil Sorry i saw this first http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                                            sdetweil @uok825
                                            @uok825 yeh, old stuff…
                                            • 12
                                            • 13
                                            • 6 / 13
