    MMM-awesome-alexa
    241 Posts 43 Posters 391.2k Views 47 Watching
    • dolanmiuD Offline
      dolanmiu
      https://github.com/dolanmiu/MMM-awesome-alexa
      Chat on Gitter dependencies Status Build Status
      Demo GIF
      MMM-awesome-alexa
      A hands free Alexa module for the Magic Mirror, which is activated when you say ‘Alexa’.
      At the moment, this only works for MacOS and Ubuntu. Raspberry Pi has experimental support, it works when I tried it, but please try yourself and let us know on Gitter!
      Installation
      Refer to the official documentation on how to install the module: https://awesome-alexa.js.org
      Usage
      Boot up Magic Mirror and say “Alexa, what time is it?”, or “Alexa, tell me a joke” 😊.
      Note: If you are using Raspberry Pi, you most likely will experience a snowboy issue. Please go to the Troubleshoot section down below
      Features
      • Wake Word support
      • Custom Wake Word
      • Very easy set up
      • Easy config tool
      • All-in-one solution.
      • Visualisation
      Supported Wake Words
      • Alexa
      • Smart Mirror
      • Snowboy
      • Jarvis
      • Computer
      Troubleshoot
      First check if your mic works by typing in:
      rec t.wav
      If the above command doesn’t work, please fix that before continuing. Here is a link to help you (Raspberry pi)
      PM2 problems
      For some reason, running MagicMirror on PM2 with this module doesn’t seem to work on Raspberry Pi. The mic does not pick up. If anyone has a solution or cause for this, it would be greatly appreciated. I would recommend to start the MagicMirror the traditional way of npm start.
      Snowboy problems
      Make sure you followed the install steps correctly. It involves manually downloading snowboy and manually building snowboy:
      https://awesome-alexa.js.org/#/installation?id=step-2-install-module
      Follow snowboy’s official guide on how to recompile their package:
      https://github.com/Kitt-AI/snowboy#compile-a-node-addon
      Made with 💖 by Dolan
      P B 2 Replies Last reply Reply Quote 1
        psm9 @dolanmiu
        @dolanmiu
        Thanks for making this.
        I tried to go to your site to generate a config file, but I get an error from amazon.
        I entered my ClientID and Client Secret.
        What goes in the Device ID box? - Is it the Security Profile ID or the Device Type ID?
        Thanks!
        dolanmiuD 1 Reply Last reply Reply Quote 0
          pepemujica
          So what can we do with this module? Sorry, I don’t get it
          • dolanmiuD Offline
            dolanmiu @psm9
            @psm9 The website isn’t working properly right now :( So right now, you will have to do it manually. I am working on it!
            • dolanmiuD Offline
              dolanmiu @pepemujica
              @pepemujica You know Amazon Echo?
              https://www.amazon.com/Amazon-Echo-Bluetooth-Speaker-with-Alexa-Black/dp/B00X4WHP5E/ref=sr_1_1?ie=UTF8&qid=1495760076&sr=8-1&keywords=echo
              Essentially, this module turns your Magic Mirror into an “Amazon Echo” for free! Click on the link to find out more
              You just say: “Alexa, what is the time?”, and the MagicMirror will respond to you.
                pepemujica @dolanmiu
                @dolanmiu I get it.
                Now I’m stuck at the refreshtoken part, Ican’t move on
                • dolanmiuD Offline
                  @pepemujica So sorry about this
                  There will be a proper guide on how to get a refresh token soon
                  The Helper Website currently is experiencing issues
                  I will message on this thread and reply to you once its done!
                  Keep an eye out! And thanks for your interest :)
                  P 2 Replies Last reply Reply Quote 0
                    @dolanmiu That would be awesome! Hope you can fix it soon.
                    Kind regads!
                      @dolanmiu Hi @dolanmiu hope you’re finding very well!
                      could you fix the helper website?
                      Kind regards
                      • E Offline
                        ezarlive
                        Seems… doesn’t work!
                        • 24
                        • 25
                        • 1 / 25
