    MMM-awesome-alexa
    241 Posts 43 Posters 423.8k Views 47 Watching
    • E Offline
      ezarlive
      Seems… doesn’t work!
      • E Offline
        ezarlive
        It works!
          jnstnr @ezarlive
          @ezarlive how did you get it to work? I’ve been trying and trying to get this to work nothing works :/
          dolanmiuD 1 Reply Last reply Reply Quote 0
          • dolanmiuD Offline
            dolanmiu @pepemujica
            @pepemujica For me, the helper website works
            Where do you live? I live in the UK, and it just works for me, perhaps Amazon has location blocking?
            • dolanmiuD Offline
              dolanmiu @jnstnr
              @jnstnr Can you post on the issues section of the Repo? Tell me the exact error, you can find the error by running:
              npm start dev
                mc_landin @dolanmiu
                @dolanmiu I have a similar issue: https://forum.magicmirror.builders/topic/4227/mmm-awesome-alexa-black-screen-installation-error
                  mydiva
                  I have tried to install this module, but it didn’t work. If I disable this module in config everything works fine. If i start with this module i get a black screen. In dev mode, i get an error DevTools was disconnected from the page …
                  Do someone knows whats going wrong? I followed the instruction during the installation.
                  • F Offline
                    Fonfon
                    this module is only in english ?
                    • X Offline
                      xchribiza
                      Please help!
                      I am trying to install this module and I am stuck at the refreshtoken thing…
                      I always get error from amazon .
                      Please any ideas ?
                      • ArzegA Offline
                        Arzeg
                        Hello Guys,
                        i stuck … i tried the last days to configure the module right but i dont understand the step with auth_token.sh from the site How to get AVS Token.
                        I got at the previous step the code for the second script “auth_token.sh” changed the client id, client secret and the code to my options all fine.
                        When i will execute the script nothing happens or what should i do with the script?
                        CLIENT_ID="amzn1.application-oa2-client.7efb5005320644ba9..."
                        CLIENT_SECRET="a14de78ce1096593718..."
                        CODE="ANXsEuOxBhQDk..."
                        GRANT_TYPE="authorization_code"
                        REDIRECT_URI="https://localhost:9745/authresponse"
                        curl -X POST --data "grant_type=${GRANT_TYPE}&code=${CODE}&client_id=${CLIENT_ID}&client_secret=${CLIENT_SECRET}&redirect_uri=${REDIRECT_URI}" https://api.amazon.com/auth/o2/token
                        my auth_token.sh script
                        greets Arzeg
                        • U Offline
                          uzumon
                          Hello i need help.
                          How to get refresh token?
                          Now without refresh token in config i have problem with run module:
                           2017-08-24 10:49 +02:00: Whoops! There was an uncaught exception...
                          0|mm       | 2017-08-24 10:49 +02:00: { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.6-linux-arm/snowboy.node'
                          0|mm       |     at Module._resolveFilename (module.js:470:15)
                          0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                          0|mm       |     at Function.Module._load (module.js:418:25)
                          0|mm       |     at Module.require (module.js:498:17)
                          0|mm       |     at require (internal/module.js:20:19)
                          0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
                          0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
                          0|mm       |     at Module._compile (module.js:571:32)
                          0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                          0|mm       |     at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
                          Someone can help? Please.
                          Edit: for error with snowboy. I fixed it by:
                          npm run electron-rebuild
                          • cowboysdudeC Offline
                            I guess he’s given up on getting this working correctly…
                            Trust me this thing is a bloody nightmare…
                              Well I have figured this out…it’s VERY simple.
                              IF You need the sh files to generate your info please go to my fork of this module…I’ve included them.
                              https://github.com/cowboysdude/MMM-awesome-alexa
                              • G Offline
                                g_nandagpl
                                Thanks for this module. It works.
                                If we have visualization, it would be better.
                                dolanmiuD G 2 Replies Last reply Reply Quote 0
                                • dolanmiuD Offline
                                  dolanmiu @g_nandagpl
                                  @g_nandagpl Thank you for the feedback, glad you got this working
                                  As for visualization, it turned out really laggy on Raspberry Pi, so I postponed it
                                  I might re-visit this feature, maybe figure out a way to speed it up if there is enough interest
                                    cowboysdude Module Developer @dolanmiu
                                    @dolanmiu OH there’s interest. I"m using a real computer to run mine so not an issue :)
                                      jnstnr @cowboysdude
                                      @cowboysdude thanks for the scripts! I’m trying to run auth_code.sh but I get the following errors, and no code to put in auth_code2.sh:
                                      Can’t locate URI/Escape.pm in @INC (you may need to install the URI::Escape module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .).
                                      BEGIN failed–compilation aborted.
                                      /usr/bin/xdg-open: 1: eval: www-browser: not found
                                      /usr/bin/xdg-open: 1: eval: links2: not found
                                      /usr/bin/xdg-open: 1: eval: elinks: not found
                                      /usr/bin/xdg-open: 1: eval: links: not found
                                      /usr/bin/xdg-open: 1: eval: lynx: not found
                                      /usr/bin/xdg-open: 1: eval: w3m: not found
                                      xdg-open: no method available for opening ‘https://www.amazon.com/ap/oa?client_id=[removed my client id]&scope=&scope_data=&response_type=code&redirect_uri=’
                                      Any ideas what could be wrong?
                                        cowboysdude Module Developer @jnstnr
                                        @jnstnr Yes I may have an idea…
                                        open up both sh files and using your keyboard replace all the double quotes … for some reason they do not copy well. I did that and it ran great! :)
                                          jnstnr @cowboysdude
                                          @cowboysdude just got home and tried it, replaced all " with ’
                                          And now I get another error:
                                          pi@raspberrypi:~ $ bash auth_code.sh
                                          auth_code.sh: line 10: syntax error near unexpected token (' auth_code.sh: line 10: perl -MURI::Escape -ne ‘chomp;print uri_escape($_),’\n’‘’
                                          Pretty sure there’s a simple fix for line 10, but haven’t figured it out yet!
                                          J S M H 4 Replies Last reply Reply Quote 0
                                            jnstnr @jnstnr
                                            Scratch that, finally managed to get a refresh token! Added it to the config and getting a black screen now though :/
                                            • 12
                                            • 13
                                            • 1 / 13
