    MMM-awesome-alexa
    241 Posts 43 Posters 410.8k Views 47 Watching
    • dolanmiuD Offline
      dolanmiu
      https://github.com/dolanmiu/MMM-awesome-alexa
      Chat on Gitter dependencies Status Build Status
      Demo GIF
      MMM-awesome-alexa
      A hands free Alexa module for the Magic Mirror, which is activated when you say ‘Alexa’.
      At the moment, this only works for MacOS and Ubuntu. Raspberry Pi has experimental support, it works when I tried it, but please try yourself and let us know on Gitter!
      Installation
      Refer to the official documentation on how to install the module: https://awesome-alexa.js.org
      Usage
      Boot up Magic Mirror and say “Alexa, what time is it?”, or “Alexa, tell me a joke” 😊.
      Note: If you are using Raspberry Pi, you most likely will experience a snowboy issue. Please go to the Troubleshoot section down below
      Features
      • Wake Word support
      • Custom Wake Word
      • Very easy set up
      • Easy config tool
      • All-in-one solution.
      • Visualisation
      Supported Wake Words
      • Alexa
      • Smart Mirror
      • Snowboy
      • Jarvis
      • Computer
      Troubleshoot
      First check if your mic works by typing in:
      rec t.wav
      If the above command doesn’t work, please fix that before continuing. Here is a link to help you (Raspberry pi)
      PM2 problems
      For some reason, running MagicMirror on PM2 with this module doesn’t seem to work on Raspberry Pi. The mic does not pick up. If anyone has a solution or cause for this, it would be greatly appreciated. I would recommend to start the MagicMirror the traditional way of npm start.
      Snowboy problems
      Make sure you followed the install steps correctly. It involves manually downloading snowboy and manually building snowboy:
      https://awesome-alexa.js.org/#/installation?id=step-2-install-module
      Follow snowboy’s official guide on how to recompile their package:
      https://github.com/Kitt-AI/snowboy#compile-a-node-addon
      Made with 💖 by Dolan
      P B 2 Replies Last reply Reply Quote 1
        psm9 @dolanmiu
        @dolanmiu
        Thanks for making this.
        I tried to go to your site to generate a config file, but I get an error from amazon.
        I entered my ClientID and Client Secret.
        What goes in the Device ID box? - Is it the Security Profile ID or the Device Type ID?
        Thanks!
        dolanmiuD 1 Reply Last reply Reply Quote 0
          pepemujica
          So what can we do with this module? Sorry, I don’t get it
          • dolanmiuD Offline
            dolanmiu @psm9
            @psm9 The website isn’t working properly right now :( So right now, you will have to do it manually. I am working on it!
            • dolanmiuD Offline
              dolanmiu @pepemujica
              @pepemujica You know Amazon Echo?
              https://www.amazon.com/Amazon-Echo-Bluetooth-Speaker-with-Alexa-Black/dp/B00X4WHP5E/ref=sr_1_1?ie=UTF8&qid=1495760076&sr=8-1&keywords=echo
              Essentially, this module turns your Magic Mirror into an “Amazon Echo” for free! Click on the link to find out more
              You just say: “Alexa, what is the time?”, and the MagicMirror will respond to you.
                pepemujica @dolanmiu
                @dolanmiu I get it.
                Now I’m stuck at the refreshtoken part, Ican’t move on
                • dolanmiuD Offline
                  @pepemujica So sorry about this
                  There will be a proper guide on how to get a refresh token soon
                  The Helper Website currently is experiencing issues
                  I will message on this thread and reply to you once its done!
                  Keep an eye out! And thanks for your interest :)
                  P 2 Replies Last reply Reply Quote 0
                    @dolanmiu That would be awesome! Hope you can fix it soon.
                    Kind regads!
                      @dolanmiu Hi @dolanmiu hope you’re finding very well!
                      could you fix the helper website?
                      Kind regards
                      • E Offline
                        ezarlive
                        Seems… doesn’t work!
                        • E Offline
                          ezarlive
                          It works!
                            jnstnr @ezarlive
                            @ezarlive how did you get it to work? I’ve been trying and trying to get this to work nothing works :/
                            • dolanmiuD Offline
                              @pepemujica For me, the helper website works
                              Where do you live? I live in the UK, and it just works for me, perhaps Amazon has location blocking?
                              • dolanmiuD Offline
                                dolanmiu @jnstnr
                                @jnstnr Can you post on the issues section of the Repo? Tell me the exact error, you can find the error by running:
                                npm start dev
                                  mc_landin @dolanmiu
                                  @dolanmiu I have a similar issue: https://forum.magicmirror.builders/topic/4227/mmm-awesome-alexa-black-screen-installation-error
                                    mydiva
                                    I have tried to install this module, but it didn’t work. If I disable this module in config everything works fine. If i start with this module i get a black screen. In dev mode, i get an error DevTools was disconnected from the page …
                                    Do someone knows whats going wrong? I followed the instruction during the installation.
                                    • F Offline
                                      Fonfon
                                      this module is only in english ?
                                      • X Offline
                                        xchribiza
                                        Please help!
                                        I am trying to install this module and I am stuck at the refreshtoken thing…
                                        I always get error from amazon .
                                        Please any ideas ?
                                        • ArzegA Offline
                                          Arzeg
                                          Hello Guys,
                                          i stuck … i tried the last days to configure the module right but i dont understand the step with auth_token.sh from the site How to get AVS Token.
                                          I got at the previous step the code for the second script “auth_token.sh” changed the client id, client secret and the code to my options all fine.
                                          When i will execute the script nothing happens or what should i do with the script?
                                          CLIENT_ID="amzn1.application-oa2-client.7efb5005320644ba9..."
                                          CLIENT_SECRET="a14de78ce1096593718..."
                                          CODE="ANXsEuOxBhQDk..."
                                          GRANT_TYPE="authorization_code"
                                          REDIRECT_URI="https://localhost:9745/authresponse"
                                          curl -X POST --data "grant_type=${GRANT_TYPE}&code=${CODE}&client_id=${CLIENT_ID}&client_secret=${CLIENT_SECRET}&redirect_uri=${REDIRECT_URI}" https://api.amazon.com/auth/o2/token
                                          my auth_token.sh script
                                          greets Arzeg
                                          • U Offline
                                            uzumon
                                            Hello i need help.
                                            How to get refresh token?
                                            Now without refresh token in config i have problem with run module:
                                             2017-08-24 10:49 +02:00: Whoops! There was an uncaught exception...
                                            0|mm       | 2017-08-24 10:49 +02:00: { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.6-linux-arm/snowboy.node'
                                            0|mm       |     at Module._resolveFilename (module.js:470:15)
                                            0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                            0|mm       |     at Function.Module._load (module.js:418:25)
                                            0|mm       |     at Module.require (module.js:498:17)
                                            0|mm       |     at require (internal/module.js:20:19)
                                            0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
                                            0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
                                            0|mm       |     at Module._compile (module.js:571:32)
                                            0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                                            0|mm       |     at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
                                            Someone can help? Please.
                                            Edit: for error with snowboy. I fixed it by:
                                            npm run electron-rebuild
                                            • 12
                                            • 13
                                            • 1 / 13
