    MMM-awesome-alexa
    241 Posts 43 Posters 438.6k Views 47 Watching
    • dolanmiuD Offline
      dolanmiu @pepemujica
      @pepemujica So sorry about this
      There will be a proper guide on how to get a refresh token soon
      The Helper Website currently is experiencing issues
      I will message on this thread and reply to you once its done!
      Keep an eye out! And thanks for your interest :)
      P 2 Replies Last reply Reply Quote 0
        pepemujica @dolanmiu
        @dolanmiu That would be awesome! Hope you can fix it soon.
        Kind regads!
        dolanmiuD 1 Reply Last reply Reply Quote 0
          @dolanmiu Hi @dolanmiu hope you’re finding very well!
          could you fix the helper website?
          Kind regards
          • E Offline
            ezarlive
            Seems… doesn’t work!
            • E Offline
              ezarlive
              It works!
                jnstnr @ezarlive
                @ezarlive how did you get it to work? I’ve been trying and trying to get this to work nothing works :/
                • dolanmiuD Offline
                  @pepemujica For me, the helper website works
                  Where do you live? I live in the UK, and it just works for me, perhaps Amazon has location blocking?
                  • dolanmiuD Offline
                    dolanmiu @jnstnr
                    @jnstnr Can you post on the issues section of the Repo? Tell me the exact error, you can find the error by running:
                    npm start dev
                      mc_landin @dolanmiu
                      @dolanmiu I have a similar issue: https://forum.magicmirror.builders/topic/4227/mmm-awesome-alexa-black-screen-installation-error
                        mydiva
                        I have tried to install this module, but it didn’t work. If I disable this module in config everything works fine. If i start with this module i get a black screen. In dev mode, i get an error DevTools was disconnected from the page …
                        Do someone knows whats going wrong? I followed the instruction during the installation.
                        • F Offline
                          Fonfon
                          this module is only in english ?
                          • X Offline
                            xchribiza
                            Please help!
                            I am trying to install this module and I am stuck at the refreshtoken thing…
                            I always get error from amazon .
                            Please any ideas ?
                            • ArzegA Offline
                              Arzeg
                              Hello Guys,
                              i stuck … i tried the last days to configure the module right but i dont understand the step with auth_token.sh from the site How to get AVS Token.
                              I got at the previous step the code for the second script “auth_token.sh” changed the client id, client secret and the code to my options all fine.
                              When i will execute the script nothing happens or what should i do with the script?
                              CLIENT_ID="amzn1.application-oa2-client.7efb5005320644ba9..."
                              CLIENT_SECRET="a14de78ce1096593718..."
                              CODE="ANXsEuOxBhQDk..."
                              GRANT_TYPE="authorization_code"
                              REDIRECT_URI="https://localhost:9745/authresponse"
                              curl -X POST --data "grant_type=${GRANT_TYPE}&code=${CODE}&client_id=${CLIENT_ID}&client_secret=${CLIENT_SECRET}&redirect_uri=${REDIRECT_URI}" https://api.amazon.com/auth/o2/token
                              my auth_token.sh script
                              greets Arzeg
                              • U Offline
                                uzumon
                                Hello i need help.
                                How to get refresh token?
                                Now without refresh token in config i have problem with run module:
                                 2017-08-24 10:49 +02:00: Whoops! There was an uncaught exception...
                                0|mm       | 2017-08-24 10:49 +02:00: { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.6-linux-arm/snowboy.node'
                                0|mm       |     at Module._resolveFilename (module.js:470:15)
                                0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                0|mm       |     at Function.Module._load (module.js:418:25)
                                0|mm       |     at Module.require (module.js:498:17)
                                0|mm       |     at require (internal/module.js:20:19)
                                0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
                                0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
                                0|mm       |     at Module._compile (module.js:571:32)
                                0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                                0|mm       |     at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
                                Someone can help? Please.
                                Edit: for error with snowboy. I fixed it by:
                                npm run electron-rebuild
                                • cowboysdudeC Offline
                                  I guess he’s given up on getting this working correctly…
                                  Trust me this thing is a bloody nightmare…
                                    Well I have figured this out…it’s VERY simple.
                                    IF You need the sh files to generate your info please go to my fork of this module…I’ve included them.
                                    https://github.com/cowboysdude/MMM-awesome-alexa
                                    • G Offline
                                      g_nandagpl
                                      Thanks for this module. It works.
                                      If we have visualization, it would be better.
                                      dolanmiuD G 2 Replies Last reply Reply Quote 0
                                      • dolanmiuD Offline
                                        dolanmiu @g_nandagpl
                                        @g_nandagpl Thank you for the feedback, glad you got this working
                                        As for visualization, it turned out really laggy on Raspberry Pi, so I postponed it
                                        I might re-visit this feature, maybe figure out a way to speed it up if there is enough interest
                                          cowboysdude Module Developer @dolanmiu
                                          @dolanmiu OH there’s interest. I"m using a real computer to run mine so not an issue :)
                                            jnstnr @cowboysdude
                                            @cowboysdude thanks for the scripts! I’m trying to run auth_code.sh but I get the following errors, and no code to put in auth_code2.sh:
                                            Can’t locate URI/Escape.pm in @INC (you may need to install the URI::Escape module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .).
                                            BEGIN failed–compilation aborted.
                                            /usr/bin/xdg-open: 1: eval: www-browser: not found
                                            /usr/bin/xdg-open: 1: eval: links2: not found
                                            /usr/bin/xdg-open: 1: eval: elinks: not found
                                            /usr/bin/xdg-open: 1: eval: links: not found
                                            /usr/bin/xdg-open: 1: eval: lynx: not found
                                            /usr/bin/xdg-open: 1: eval: w3m: not found
                                            xdg-open: no method available for opening ‘https://www.amazon.com/ap/oa?client_id=[removed my client id]&scope=&scope_data=&response_type=code&redirect_uri=’
                                            Any ideas what could be wrong?
                                            • 12
                                            • 13
                                            • 1 / 13
