    Help with updateDom()
    11 Posts 5 Posters 4.3k Views 5 Watching
    • U Offline
      UjwalReddy267
      This module is supposed to show a slideshow of the two images that are given in the variablle loc. But, I am not able to update the Dom. It does not change the image. The setInterval function does not seem to be working.
      Module.register("MMM-Test",{
                      default: {loc: ["modules/MMM-Test/test1.jpg","modules/MMM-Test/test.jpg"], count:0},
      		start : function(){
      				setInterval(function() {this.updateDom()}, 1000);
      		getDom : function (){
                              var wrapper = document.createElement('div')
      			wrapper.id = 'FULL'
      			var img = document.createElement('div')
      			var i = this.config.count
                              img.style.backgroundImage = 'url(' + this.config.loc[i] + ')'
      			img.id = 'photo'
              		var blr = document.createElement('div')
      			blr.id = 'backgrnd'
      			blr.style.backgroundImage = 'url(' + this.config.loc[i] + ')'
      			wrapper.appendChild(blr)
      			wrapper.appendChild(img)
      			this.config.count = (this.config.count + 1) % 2
                              return wrapper
      		getStyles : function (){
      			return ['MMM-Test.css']
      lavolp3L S 2 Replies Last reply Reply Quote 0
        CreepinJesus
        • lavolp3L Offline
          lavolp3 Module Developer @CreepinJesus
          @CreepinJesus said in Help with updateDom():
          I think (may be wrong) the config is read only inside the module,
          that’s not true. The config values can be manipulated.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          lavolp3L 1 Reply Last reply Reply Quote 1
          • lavolp3L Offline
            lavolp3 Module Developer @UjwalReddy267
            @UjwalReddy267
            I would do this:
            the count variable out of defaults and into this. Then count it up in getdom.
                            default: {loc: ["modules/MMM-Test/test1.jpg","modules/MMM-Test/test.jpg"]},
                            count: 0,
            		start : function(){
            			wrapper.id = 'FULL'
            			var i = this.count
            			img.id = 'photo'
            			blr.id = 'backgrnd'
            			this.count = (this.count + 1) % 2
                                    return wrapper
            • lavolp3L Offline
              lavolp3 Module Developer @lavolp3
              @lavolp3 are you sure the image url is correct?
              I would always for debugging purposes print that out once.
              console.log('url(' + this.config.loc[i] + ')');
              console.log(this.count)
              Or check the dev console for errors not finding the pictures.
                sdetweil @UjwalReddy267
                @UjwalReddy267 your pointer ‘this’ is wrong inside the timer handle
                you need to do
                var self=this
                and in the handler use self instead
                setInterval(function() {self.updateDom()
                lavolp3L U 3 Replies Last reply Reply Quote 0
                • lavolp3L Offline
                  @lavolp3 NOw I have the error, I think!
                  the thisin the interval might refer to another this and not to the original module-this
                  So you need to do the following in start:
                  start : function(){
                                                  var self = this;
                  				setInterval(function() {self.updateDom()}, 1000);
                  • lavolp3L Offline
                    @sdetweil You were faster sam!
                    • U Offline
                      UjwalReddy267 @sdetweil
                      • U Offline
                        @sdetweil said in Help with updateDom():
                        you need to do
                        var self=this
                        Yes, that was the error, thank you it works now.
                          A Former User
                          better use this …
                          start : function(){
                            setInterval( () => {this.updateDom()}, 1000);
