    Help with updateDom()
    11 Posts 5 Posters 3.5k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @CreepinJesus
      @CreepinJesus said in Help with updateDom():
      I think (may be wrong) the config is read only inside the module,
      that’s not true. The config values can be manipulated.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      lavolp3L 1 Reply Last reply Reply Quote 1
      • lavolp3L Offline
        lavolp3 Module Developer @UjwalReddy267
        @UjwalReddy267
        I would do this:
        the count variable out of defaults and into this. Then count it up in getdom.
        Module.register("MMM-Test",{
                        default: {loc: ["modules/MMM-Test/test1.jpg","modules/MMM-Test/test.jpg"]},
                        count: 0,
        		start : function(){
        				setInterval(function() {this.updateDom()}, 1000);
        		getDom : function (){
                                var wrapper = document.createElement('div')
        			wrapper.id = 'FULL'
        			var img = document.createElement('div')
        			var i = this.count
                                img.style.backgroundImage = 'url(' + this.config.loc[i] + ')'
        			img.id = 'photo'
                		var blr = document.createElement('div')
        			blr.id = 'backgrnd'
        			blr.style.backgroundImage = 'url(' + this.config.loc[i] + ')'
        			wrapper.appendChild(blr)
        			wrapper.appendChild(img)
        			this.count = (this.count + 1) % 2
                                return wrapper
        		getStyles : function (){
        			return ['MMM-Test.css']
        • lavolp3L Offline
          lavolp3 Module Developer @lavolp3
          @lavolp3 are you sure the image url is correct?
          I would always for debugging purposes print that out once.
          console.log('url(' + this.config.loc[i] + ')');
          console.log(this.count)
          Or check the dev console for errors not finding the pictures.
            sdetweil @UjwalReddy267
            @UjwalReddy267 your pointer ‘this’ is wrong inside the timer handle
            you need to do
            var self=this
            and in the handler use self instead
            setInterval(function() {self.updateDom()
            lavolp3L U 3 Replies Last reply Reply Quote 0
            • lavolp3L Offline
              @lavolp3 NOw I have the error, I think!
              the thisin the interval might refer to another this and not to the original module-this
              So you need to do the following in start:
              start : function(){
                                              var self = this;
              				setInterval(function() {self.updateDom()}, 1000);
              • lavolp3L Offline
                @sdetweil You were faster sam!
                • U Offline
                  UjwalReddy267 @sdetweil
                  • U Offline
                    @sdetweil said in Help with updateDom():
                    you need to do
                    var self=this
                    Yes, that was the error, thank you it works now.
                      A Former User
                      better use this …
                      start : function(){
                        setInterval( () => {this.updateDom()}, 1000);
