    Electron failed to Install error after upgrading to 2.12.0
    11 Posts 2 Posters 3.1k Views 2 Watching
      rahula74
      I am getting following error after updating to 2.12.0. appreciate any pointers on what I am doing wrong or how to fix the issue. I attempted to reinstall a couple of times.
      magicmirror@2.12.0 start /home/pi/MagicMirror
      /home/pi/MagicMirror/node_modules/electron/index.js:14
      throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
      at Module.require (internal/modules/cjs/loader.js:692:17)
      at require (internal/modules/cjs/helpers.js:25:18)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 start script.
      npm ERR! /home/pi/.npm/_logs/2020-07-08T12_02_15_704Z-debug.log
        sdetweil @rahula74
        @rahula74 how did u upgrade? my script or manually?
        what pi are u on and what is level?
        run
        lsb_release -a
        for that is info
          rahula74
          Thanks @sdetweil
          I am on Pi 3 ( I am a novice to MM. where do I run isb_release -a for the info you requested? on the terminal?)
          I used your script to upgrade.
            sdetweil @rahula74
            @rahula74 issue commands in a terminal window
            can u show me the ~/MagicMirror/installers/upgrade.log
            R 1 Reply Last reply
              rahula74 @sdetweil
              here is latest upgrade log
              Upgrade started - Wed Jul 8 14:21:46 CDT 2020
              system is Linux raspberrypi 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              saving custom.css
              remote name = origin
              upgrading from version 2.12.0 to 2.12.0
              fetching latest revisions
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is up to date with ‘origin/master’.
              (use “git add/rm …” to update what will be committed)
              (use “git checkout – …” to discard changes in working directory)
              deleted:    package-lock.json
              Untracked files:
              (use “git add …” to include in what will be committed)
              css/save_custom.css
              run-start.sh
              no changes added to commit (use “git add” and/or “git commit -a”)
              no files different from github version
              test merge result rc=‘’ , if empty, no conflicts
              skipping merge, only test run
              downloading dumpactivemodules script
              no modules found needing npm refresh
              restoring custom.css
              removing git alias
              Upgrade ended - Wed Jul 8 14:21:51 CDT 2020
              Upgrade started - Wed Jul 8 14:22:11 CDT 2020
              user requested to apply changes
              doing test run = false
              saving custom.css
              local version 2.12.0 already same as master 2.12.0
              removing git alias
              Upgrade ended - Wed Jul 8 14:22:12 CDT 2020
                sdetweil @rahula74
                @rahula74 use force instead of apply if u tried it manually once
                  rahula74 @sdetweil
                  ok.will give it a try.
                  Thanks!
                    rahula74 @rahula74
                    tried Force. following is the log. no luck though with npm start to launch MM
                    Upgrade started - Wed Jul 8 14:29:34 CDT 2020
                    user requested to force apply changes
                    saving custom.css
                    git fetch rc=0
                    On branch master
                    Untracked files:
                    css/save_custom.css
                    run-start.sh
                    executing merge, apply specified
                    merge result rc= 0
                    Already up to date.
                    processor architecture is armv7l
                    npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                    npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                    npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/css-value failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
                    npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                    npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                    magicmirror@2.12.0 install /home/pi/MagicMirror
                    echo "Installing vendor files …
                    " && cd vendor && npm install --loglevel=error
                    Upgrade started - Wed Jul 8 15:44:11 CDT 2020
                    saving custom.css
                    git fetch rc=0
                    On branch master
                    Untracked files:
                    css/save_custom.css
                    run-start.sh
                    merge result rc= 0
                    Already up to date.
                    added 82 packages from 57 contributors and audited 150 packages in 12.974s
                    found 8 vulnerabilities (7 low, 1 high)
                    run npm audit fix to fix them, or npm audit for details
                    magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                    npm run install-fonts && echo "MagicMirror installation finished successfully!
                    magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                    echo "Installing fonts …
                    " && cd fonts && npm install --loglevel=error
                    Installing fonts …
                    added 1 package from 1 contributor and audited 1 package in 1.285s
                    found 0 vulnerabilities
                    npm notice created a lockfile as package-lock.json. You should commit this file.
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                    audited 1042 packages in 69.581s
                    11 packages are looking for funding
                    run npm fund for details
                    found 3 low severity vulnerabilities
                    npm install completed - Wed Jul 8 15:45:29 CDT 2020 on base
                    removing git alias
                    Upgrade ended - Wed Jul 8 15:45:30 CDT 2020
                      sdetweil @rahula74
                      @rahula74 weird. thanks for the log.
                      can you do
                      npm install
                      npm start
                        rahula74 @sdetweil
                        Thanks Sam.
                        I ended up deleting prior installation and used your script to reinstall.
                        Its up and running now.
                        Thanks again!
                          sdetweil @rahula74
                          @rahula74 ok, thx.
