    Electron failed to Install error after upgrading to 2.12.0
    11 Posts 2 Posters 1.7k Views 2 Watching
      sdetweil @rahula74
      @rahula74 issue commands in a terminal window
      can u show me the ~/MagicMirror/installers/upgrade.log
        rahula74 @sdetweil
        here is latest upgrade log
        Upgrade started - Wed Jul 8 14:21:46 CDT 2020
        system is Linux raspberrypi 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
        saving custom.css
        remote name = origin
        upgrading from version 2.12.0 to 2.12.0
        fetching latest revisions
        git fetch rc=0
        current branch = master
        On branch master
        Your branch is up to date with ‘origin/master’.
        (use “git add/rm …” to update what will be committed)
        (use “git checkout – …” to discard changes in working directory)
        deleted:    package-lock.json
        Untracked files:
        (use “git add …” to include in what will be committed)
        css/save_custom.css
        run-start.sh
        no changes added to commit (use “git add” and/or “git commit -a”)
        no files different from github version
        test merge result rc=‘’ , if empty, no conflicts
        skipping merge, only test run
        downloading dumpactivemodules script
        no modules found needing npm refresh
        restoring custom.css
        removing git alias
        Upgrade ended - Wed Jul 8 14:21:51 CDT 2020
        Upgrade started - Wed Jul 8 14:22:11 CDT 2020
        user requested to apply changes
        doing test run = false
        saving custom.css
        local version 2.12.0 already same as master 2.12.0
        removing git alias
        Upgrade ended - Wed Jul 8 14:22:12 CDT 2020
          sdetweil @rahula74
          @rahula74 use force instead of apply if u tried it manually once
            rahula74 @sdetweil
            ok.will give it a try.
            Thanks!
              rahula74 @rahula74
              tried Force. following is the log. no luck though with npm start to launch MM
              Upgrade started - Wed Jul 8 14:29:34 CDT 2020
              user requested to force apply changes
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              css/save_custom.css
              run-start.sh
              executing merge, apply specified
              merge result rc= 0
              Already up to date.
              processor architecture is armv7l
              npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
              npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
              npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
              npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/css-value failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
              npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
              npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
              npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
              npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
              magicmirror@2.12.0 install /home/pi/MagicMirror
              echo "Installing vendor files …
              " && cd vendor && npm install --loglevel=error
              Upgrade started - Wed Jul 8 15:44:11 CDT 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              css/save_custom.css
              run-start.sh
              merge result rc= 0
              Already up to date.
              added 82 packages from 57 contributors and audited 150 packages in 12.974s
              found 8 vulnerabilities (7 low, 1 high)
              run npm audit fix to fix them, or npm audit for details
              magicmirror@2.12.0 postinstall /home/pi/MagicMirror
              npm run install-fonts && echo "MagicMirror installation finished successfully!
              magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
              echo "Installing fonts …
              " && cd fonts && npm install --loglevel=error
              Installing fonts …
              added 1 package from 1 contributor and audited 1 package in 1.285s
              found 0 vulnerabilities
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
              audited 1042 packages in 69.581s
              11 packages are looking for funding
              run npm fund for details
              found 3 low severity vulnerabilities
              npm install completed - Wed Jul 8 15:45:29 CDT 2020 on base
              removing git alias
              Upgrade ended - Wed Jul 8 15:45:30 CDT 2020
                sdetweil @rahula74
                @rahula74 weird. thanks for the log.
                can you do
                npm install
                npm start
                  rahula74 @sdetweil
                  Thanks Sam.
                  I ended up deleting prior installation and used your script to reinstall.
                  Its up and running now.
                  Thanks again!
                    sdetweil @rahula74
                    @rahula74 ok, thx.
