    Electron failed to Install error after upgrading to 2.12.0
    11 Posts 2 Posters 1.7k Views 2 Watching
      rahula74 @sdetweil
      here is latest upgrade log
      Upgrade started - Wed Jul 8 14:21:46 CDT 2020
      system is Linux raspberrypi 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
      saving custom.css
      remote name = origin
      upgrading from version 2.12.0 to 2.12.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with ‘origin/master’.
      (use “git add/rm …” to update what will be committed)
      (use “git checkout – …” to discard changes in working directory)
      deleted:    package-lock.json
      Untracked files:
      (use “git add …” to include in what will be committed)
      css/save_custom.css
      run-start.sh
      no changes added to commit (use “git add” and/or “git commit -a”)
      no files different from github version
      test merge result rc=‘’ , if empty, no conflicts
      skipping merge, only test run
      downloading dumpactivemodules script
      no modules found needing npm refresh
      restoring custom.css
      removing git alias
      Upgrade ended - Wed Jul 8 14:21:51 CDT 2020
      Upgrade started - Wed Jul 8 14:22:11 CDT 2020
      user requested to apply changes
      doing test run = false
      saving custom.css
      local version 2.12.0 already same as master 2.12.0
      removing git alias
      Upgrade ended - Wed Jul 8 14:22:12 CDT 2020
        sdetweil @rahula74
        @rahula74 use force instead of apply if u tried it manually once
          rahula74 @sdetweil
          ok.will give it a try.
          Thanks!
            rahula74 @rahula74
            tried Force. following is the log. no luck though with npm start to launch MM
            Upgrade started - Wed Jul 8 14:29:34 CDT 2020
            user requested to force apply changes
            saving custom.css
            git fetch rc=0
            On branch master
            Untracked files:
            css/save_custom.css
            run-start.sh
            executing merge, apply specified
            merge result rc= 0
            Already up to date.
            processor architecture is armv7l
            npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
            npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
            npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
            npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/css-value failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
            npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
            npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
            npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
            npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
            magicmirror@2.12.0 install /home/pi/MagicMirror
            echo "Installing vendor files …
            " && cd vendor && npm install --loglevel=error
            Upgrade started - Wed Jul 8 15:44:11 CDT 2020
            saving custom.css
            git fetch rc=0
            On branch master
            Untracked files:
            css/save_custom.css
            run-start.sh
            merge result rc= 0
            Already up to date.
            added 82 packages from 57 contributors and audited 150 packages in 12.974s
            found 8 vulnerabilities (7 low, 1 high)
            run npm audit fix to fix them, or npm audit for details
            magicmirror@2.12.0 postinstall /home/pi/MagicMirror
            npm run install-fonts && echo "MagicMirror installation finished successfully!
            magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
            echo "Installing fonts …
            " && cd fonts && npm install --loglevel=error
            Installing fonts …
            added 1 package from 1 contributor and audited 1 package in 1.285s
            found 0 vulnerabilities
            npm notice created a lockfile as package-lock.json. You should commit this file.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
            audited 1042 packages in 69.581s
            11 packages are looking for funding
            run npm fund for details
            found 3 low severity vulnerabilities
            npm install completed - Wed Jul 8 15:45:29 CDT 2020 on base
            removing git alias
            Upgrade ended - Wed Jul 8 15:45:30 CDT 2020
              sdetweil @rahula74
              @rahula74 weird. thanks for the log.
              can you do
              npm install
              npm start
                rahula74 @sdetweil
                Thanks Sam.
                I ended up deleting prior installation and used your script to reinstall.
                Its up and running now.
                Thanks again!
                  sdetweil @rahula74
                  @rahula74 ok, thx.
