Electron failed to Install error after upgrading to 2.12.0
11 Posts 2 Posters 1.4k Views 2 Watching
    rahula74
    I am getting following error after updating to 2.12.0. appreciate any pointers on what I am doing wrong or how to fix the issue. I attempted to reinstall a couple of times.
    magicmirror@2.12.0 start /home/pi/MagicMirror
    /home/pi/MagicMirror/node_modules/electron/index.js:14
    throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
    Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
    at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
    at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
    at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! magicmirror@2.12.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.12.0 start script.
    npm ERR! /home/pi/.npm/_logs/2020-07-08T12_02_15_704Z-debug.log
    S 1 Reply Last reply Jul 8, 2020, 12:43 PM Reply Quote 0
      sdetweil @rahula74
      @rahula74 how did u upgrade? my script or manually?
      what pi are u on and what is level?
      run
      lsb_release -a
      for that is info
        rahula74
        Thanks @sdetweil
        I am on Pi 3 ( I am a novice to MM. where do I run isb_release -a for the info you requested? on the terminal?)
        I used your script to upgrade.
        S 1 Reply Last reply Jul 8, 2020, 3:41 PM Reply Quote 0
          sdetweil @rahula74
          @rahula74 issue commands in a terminal window
          can u show me the ~/MagicMirror/installers/upgrade.log
          R 1 Reply Last reply Jul 8, 2020, 7:23 PM Reply Quote 0
            rahula74 @sdetweil
            here is latest upgrade log
            Upgrade started - Wed Jul 8 14:21:46 CDT 2020
            system is Linux raspberrypi 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux
            the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
            saving custom.css
            remote name = origin
            upgrading from version 2.12.0 to 2.12.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up to date with ‘origin/master’.
            (use “git add/rm …” to update what will be committed)
            (use “git checkout – …” to discard changes in working directory)
            deleted:    package-lock.json
            Untracked files:
            (use “git add …” to include in what will be committed)
            css/save_custom.css
            run-start.sh
            no changes added to commit (use “git add” and/or “git commit -a”)
            no files different from github version
            test merge result rc=‘’ , if empty, no conflicts
            skipping merge, only test run
            downloading dumpactivemodules script
            no modules found needing npm refresh
            restoring custom.css
            removing git alias
            Upgrade ended - Wed Jul 8 14:21:51 CDT 2020
            Upgrade started - Wed Jul 8 14:22:11 CDT 2020
            user requested to apply changes
            doing test run = false
            saving custom.css
            local version 2.12.0 already same as master 2.12.0
            removing git alias
            Upgrade ended - Wed Jul 8 14:22:12 CDT 2020
            S 1 Reply Last reply Jul 8, 2020, 7:24 PM Reply Quote 0
              sdetweil @rahula74
              @rahula74 use force instead of apply if u tried it manually once
              R 1 Reply Last reply Jul 8, 2020, 7:29 PM Reply Quote 0
                rahula74 @sdetweil
                ok.will give it a try.
                Thanks!
                R 1 Reply Last reply Jul 8, 2020, 8:53 PM Reply Quote 0
                  rahula74 @rahula74
                  tried Force. following is the log. no luck though with npm start to launch MM
                  Upgrade started - Wed Jul 8 14:29:34 CDT 2020
                  user requested to force apply changes
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                  css/save_custom.css
                  run-start.sh
                  executing merge, apply specified
                  merge result rc= 0
                  Already up to date.
                  processor architecture is armv7l
                  npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                  npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                  npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                  npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/css-value failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org registry.npmjs.org:443
                  npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
                  npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                  npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                  npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                  magicmirror@2.12.0 install /home/pi/MagicMirror
                  echo "Installing vendor files …
                  " && cd vendor && npm install --loglevel=error
                  Upgrade started - Wed Jul 8 15:44:11 CDT 2020
                  saving custom.css
                  git fetch rc=0
                  On branch master
                  Untracked files:
                  css/save_custom.css
                  run-start.sh
                  merge result rc= 0
                  Already up to date.
                  added 82 packages from 57 contributors and audited 150 packages in 12.974s
                  found 8 vulnerabilities (7 low, 1 high)
                  run npm audit fix to fix them, or npm audit for details
                  magicmirror@2.12.0 postinstall /home/pi/MagicMirror
                  npm run install-fonts && echo "MagicMirror installation finished successfully!
                  magicmirror@2.12.0 install-fonts /home/pi/MagicMirror
                  echo "Installing fonts …
                  " && cd fonts && npm install --loglevel=error
                  Installing fonts …
                  added 1 package from 1 contributor and audited 1 package in 1.285s
                  found 0 vulnerabilities
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.1 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                  audited 1042 packages in 69.581s
                  11 packages are looking for funding
                  run npm fund for details
                  found 3 low severity vulnerabilities
                  npm install completed - Wed Jul 8 15:45:29 CDT 2020 on base
                  removing git alias
                  Upgrade ended - Wed Jul 8 15:45:30 CDT 2020
                  S 1 Reply Last reply Jul 9, 2020, 12:30 AM Reply Quote 0
                    sdetweil @rahula74
                    @rahula74 weird. thanks for the log.
                    can you do
                    npm install
                    npm start
                    R 1 Reply Last reply Jul 9, 2020, 1:20 PM Reply Quote 0
                      rahula74 @sdetweil
                      Thanks Sam.
                      I ended up deleting prior installation and used your script to reinstall.
                      Its up and running now.
                      Thanks again!
                      S 1 Reply Last reply Jul 9, 2020, 1:38 PM Reply Quote 0
