    MMM-SunnyPortal Solar Module
    23 Posts 7 Posters 13.2k Views 7 Watching
      open the developers window, f12 or ctrl-shift-i on the keyboard, select the tab labeled console and scroll up to see any errors,
      usually red text
      you can also add part of the module name to the filter field to help reduce the number of messages to look at
      sunn will be enough
      • T
        TheDuDiop
        @sdetweil said in MMM-SunnyPortal Solar Module:
        developers window
        did you mean this:
        pi@raspberrypi:~ $ cd MagicMirror
        magicmirror@2.11.0 start /home/pi/MagicMirror
        [2020-05-01 07:49:55.511] [LOG] Starting MagicMirror: v2.11.0
        [2020-05-01 07:49:55.522] [LOG] Loading config …
        [2020-05-01 07:49:55.530] [LOG] Loading module helpers …
        [2020-05-01 07:49:55.534] [LOG] No helper found for module: alert.
        [2020-05-01 07:49:55.614] [LOG] Initializing new module helper …
        [2020-05-01 07:49:55.615] [LOG] Module helper loaded: updatenotification
        [2020-05-01 07:49:55.616] [LOG] No helper found for module: clock.
        [2020-05-01 07:49:55.619] [LOG] Initializing new module helper …
        [2020-05-01 07:49:55.620] [LOG] Module helper loaded: mmm-udr
        [2020-05-01 07:49:56.243] [LOG] Initializing new module helper …
        [2020-05-01 07:49:56.244] [LOG] Module helper loaded: calendar
        [2020-05-01 07:49:56.770] [LOG] Initializing new module helper …
        [2020-05-01 07:49:56.771] [LOG] Module helper loaded: MMM-DWD-WarnWeather
        [2020-05-01 07:49:56.772] [LOG] No helper found for module: currentweather.
        [2020-05-01 07:49:56.773] [LOG] No helper found for module: weatherforecast.
        [2020-05-01 07:49:56.879] [LOG] Initializing new module helper …
        [2020-05-01 07:49:56.880] [LOG] Module helper loaded: MMM-Fuel
        [2020-05-01 07:49:57.384] [LOG] Initializing new module helper …
        [2020-05-01 07:49:57.385] [LOG] Module helper loaded: MMM-SunnyPortal
        [2020-05-01 07:49:57.385] [LOG] All module helpers loaded.
        [2020-05-01 07:49:57.574] [LOG] Starting server on port 8080 …
        [2020-05-01 07:49:57.596] [LOG] Server started …
        [2020-05-01 07:49:57.597] [LOG] Connecting socket for: updatenotification
        [2020-05-01 07:49:57.599] [LOG] Connecting socket for: mmm-udr
        [2020-05-01 07:49:57.599] [LOG] Starting node_helper
        [2020-05-01 07:49:57.600] [LOG] Connecting socket for: calendar
        [2020-05-01 07:49:57.601] [LOG] Starting node helper for: calendar
        [2020-05-01 07:49:57.602] [LOG] Connecting socket for: MMM-DWD-WarnWeather
        [2020-05-01 07:49:57.603] [LOG] MMM-DWD-WarnWeather helper started…
        [2020-05-01 07:49:57.604] [LOG] Connecting socket for: MMM-Fuel
        [2020-05-01 07:49:57.605] [LOG] Starting module helper: MMM-Fuel
        [2020-05-01 07:49:57.606] [LOG] Connecting socket for: MMM-SunnyPortal
        [2020-05-01 07:49:57.607] [LOG] Starting node helper for: MMM-SunnyPortal
        [2020-05-01 07:49:57.607] [LOG] Sockets connected & modules started …
        [2020-05-01 07:49:57.756] [LOG] Launching application.
        [2020-05-01 07:50:00.854] [LOG] Create new calendar fetcher for url: hlaalalalallalalalalalalalalaic.ics - Interval: 600000
        [2020-05-01 07:50:00.882] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
        [2020-05-01 07:50:01.996] [LOG] Cookie Value: ASP.NET_SessionId=pgoxqxmetvbxoywf5crvnphn; BIGipServerPool_P_SunnyPortal=3036981440.20480.0000
        [2020-05-01 07:50:01.998] [LOG] Fetched VIEWSTATE value: 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
        [2020-05-01 07:50:01.999] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
        [2020-05-01 07:50:02.063] [LOG] Cookie Value: ASP.NET_SessionId=ysbfmau4w0e3qicudfwhcvn2; BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
        [2020-05-01 07:50:02.064] [LOG] Fetched VIEWSTATE value: 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
        [2020-05-01 07:50:02.064] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
        [2020-05-01 07:50:02.103] [LOG] Cookie Value: ASP.NET_SessionId=urv14lugscw4gcl3uqeqr51z; BIGipServerPool_P_SunnyPortal=3070535872.20480.0000
        [2020-05-01 07:50:02.104] [LOG] Fetched VIEWSTATE value: 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
        [2020-05-01 07:50:02.105] [LOG] Fetched VIEWSTATEGENERATOR value: 4E24AF74
        [2020-05-01 07:50:02.530] [LOG] Login Failed, no redirect to Dashboard
        [2020-05-01 07:50:02.561] [LOG] Login Failed, no redirect to Dashboard
        [2020-05-01 07:50:02.580] [LOG] Login Failed, no redirect to Dashboard
        [2020-05-01 07:50:03.380] [LOG] HTTP Result: 200
        [2020-05-01 07:50:03.385] [LOG] Whoops! There was an uncaught exception…
        [2020-05-01 07:50:03.387] [ERROR] TypeError: Cannot read property ‘1’ of null
        at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:103:121)
        at Request.self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
        at Request.emit (events.js:200:13)
        at Request. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1154:10)
        at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1076:12)
        at Object.onceWrapper (events.js:288:20)
        at IncomingMessage.emit (events.js:205:15)
        at endReadableNT (_stream_readable.js:1154:12)
        at processTicksAndRejections (internal/process/task_queues.js:84:9)
        [2020-05-01 07:50:03.405] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-05-01 07:50:03.406] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-05-01 07:50:03.418] [LOG] HTTP Result: 200
        [2020-05-01 07:50:03.420] [LOG] Whoops! There was an uncaught exception…
        [2020-05-01 07:50:03.421] [ERROR] TypeError: Cannot read property ‘1’ of null
        [2020-05-01 07:50:03.428] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-05-01 07:50:03.431] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-05-01 07:50:03.440] [LOG] HTTP Result: 200
        [2020-05-01 07:50:03.441] [LOG] Whoops! There was an uncaught exception…
        [2020-05-01 07:50:03.442] [ERROR] TypeError: Cannot read property ‘1’ of null
        [2020-05-01 07:50:03.444] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-05-01 07:50:03.445] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        ^A^A
          sdetweil @TheDuDiop
          @TheDuDiop said in MMM-SunnyPortal Solar Module:
          the node_helper didn’t get the response from some service as it expected
          • T
            TheDuDiop
            thanks for your answer, what can I do that the node_helper goes again? or is this a developer problem?
              probably a developer problem… don’t know the module at all
              • L
                linuxtuxie
                It seems that the sunnyportal website is very picky about which user-agent is trying to connect to their web server.
                I just changed the user-agent string on line 61 of the file node_helper.js
                from
                ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:71.0) Gecko/20100101 Firefox/71.0’,
                to
                ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0’,
                And now I am able to login again.
                I will try to work out some better code to prevent this from happening in the future.
                Can somebody else verify if this solution works?
                Regards,
                Linuxtuxie
                T 1 Reply Last reply
                • T
                  TheDuDiop @linuxtuxie
                  @linuxtuxie thank you will try it tomorrow
                    Snake-Darkangel
                    Thanks for this great module. I have a problem on the loading.
                    mm-error.log
                    [2020-06-22 17:30:35.669] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    [2020-06-22 17:30:35.671] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    [2020-06-22 17:30:36.721] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                        at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                        at TLSSocket.emit (events.js:200:13)
                        at TLSSocket._finishInit (_tls_wrap.js:792:8)
                        at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
                      code: 'CERT_HAS_EXPIRED'
                    [2020-06-22 17:30:36.741] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                    [2020-06-22 17:30:36.747] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                    [2020-06-22 17:30:39.469] [ERROR]  TypeError: Cannot read property 'statusCode' of undefined
                        at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:101:46)
                        at self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                        at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:877:8)
                        at ClientRequest.emit (events.js:200:13)
                        at TLSSocket.socketErrorListener (_http_client.js:402:9)
                        at emitErrorNT (internal/streams/destroy.js:91:8)
                        at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                    So if I read correctly, I see that Buffer() is depreciate.
                    But It’s also write something strange with the certificate. In the mm-out.log I see more information:
                    0|mm       | [2020-06-22 17:26:43.303] [LOG]    SocketNotification START_SUNNYPORTAL received for the first time...setting updateInterval to 900000ms
                    0|mm       | [2020-06-22 17:26:44.113] [LOG]    Refreshed access token because it has expired. Expired at: 17:26:43 now is: 17:26:44
                    0|mm       | [2020-06-22 17:26:44.147] [LOG]    Refreshed access token because it has expired. Expired at: 18:26:44 now is: 17:26:44
                    What can I do to resolve this case?
                    I already try to uninstall and re-install all, with npm install or ./install_deps.sh or the 3 npm install request / flow / chart but it doesn’t works.
                    Any idea?
                    Thanks for your help
                    L 1 Reply Last reply
                    • L
                      linuxtuxie @Snake-Darkangel
                      @Snake-Darkangel
                      Thanks to hervidero the code has been altered so that it ignores the provided SSL Certificate.
                      Hervidero also made the charts a little bit better and wrote some code to make sure you can’t set an updateInterval < 15 minutes.
                      This release also includes the User-Agent change suggested in the previous comment
                      The latest release can be fetched here
                      https://github.com/linuxtuxie/MMM-SunnyPortal
                      Regards,
                      Linuxtuxie
                      I 1 Reply Last reply
                      • I
                        icemanmw @linuxtuxie
                        @linuxtuxie
                        Hello , i try to run the SunnyPortal module, but still no result. I´ve reinstalled the Pi severl times , down to a fresh image with no other modules, but i get only the loading view. thats all.
                        Any idea what i have to do ?
                        error message from PM2.log
                        Login Failed, no redirect to Dashboard or UserProfile/FixedPages/HoManEnergyRedesign.aspx
                        • L
                          linuxtuxie @icemanmw
                          Hi icemanmw,
                          It seems that your installation is redirecting you to the following page: /FixedPages/HoManEnergyRedesign.aspx instead of the ones we already know of (DASHBOARD_URL & USERPROFILE_URL )
                          In to code we are checking if the returned HTTP redirect matches the DASHBOARD_URL or USERPROFILE_URL
                          You could try to use the below code in the node_helper.js script to add this page
                          • Add the HOMAN_URL variable at line 21
                            var HOMAN_URL = ‘/FixedPages/HoManEnergyRedesign.aspx’;
                          • Change the code starting from line 99
                            // Hack to check for login. Should forward to dashboard.
                            if(httpResponse.headers.location && httpResponse.headers.location === DASHBOARD_URL) {
                            console.log(“SUCCESSFULLY LOGGED IN TO DASHBOARD”);
                            callback(err, jar);
                            } else if(httpResponse.headers.location && httpResponse.headers.location === USERPROFILE_URL) {
                            console.log(“SUCCESSFULLY LOGGED IN TO USERPROFILE”);
                            callback(err, jar);
                            } else if(httpResponse.headers.location && httpResponse.headers.location === HOMAN_URL) {
                            console.log(“SUCCESSFULLY LOGGED IN TO HOMAN”);
                            callback(err, jar);
                            } else {
                            console.log("Login Failed, no redirect to Dashboard, UserProfile or homan "+ httpResponse.headers.location);
                            callback(new Error(‘Login Failed, no redirect to Dashboard, UserProfile or homan’));
                          Can you let us know the results?
                          Regards,
                          Linuxtuxie
                          • I
                            icemanmw
                            Hi linuxtuxie,
                            sorry fore my late response . I was a few days in Austria.
                            Nevertheless i tried today your proposal and it looks much better. Now i see that :
                              Snake-Darkangel
                              I’ve the same issue. I try the update in the code, adding the httpResponse.headers.location in the log => it’s “undefined”
                              (and http result : 200.)
                              With the new version of the module, I’ve this log:
                              [2020-11-23 12:26:02.231] [LOG]    Login Failed, no redirect to any of the known url's /FixedPages/Dashboard.aspx, /Templates/UserProfile.aspx, /FixedPages/HoManEnergyRedesign.aspx
                              [2020-11-23 12:26:02.233] [LOG]    You are being redirected to the yet unkown url: undefined
                              In my browser I see on the homepage a pop-up for a new SMA application. Maybe that can generate another URL ? I tried to cancel it to see if it’s the problem but … nope :(
                              Still looking for a solution.
                              • L
                                linuxtuxie
                                Hi Snake-Darkangel,
                                Did you use the latest code listed at https://github.com/linuxtuxie/MMM-SunnyPortal ?
                                More specifically the piece of code listed in the file node_helper.js is important. SunnyPortal seems to be very picky when it comes to the browser which makes a connection to there website. I recently updated the user-agent to the latest Firefox version as shown below:
                                headers : {
                                // We need to simulate a Browser which the SunnyPortal accepts…here I am Using Firefox 82.0.3 (64-bit) for Windows
                                ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:82.0) Gecko/20100101 Firefox/82.0’,
                                User SkyFocusNL even used another user-agent to get things working
                                https://forum.magicmirror.builders/topic/14019/mmm-sunnyportal-not-loading/3
                                maybe you can give that solution a try and provide us some feedback ?
                                Regards,
                                Linuxtuxie
                                  Snake-Darkangel @linuxtuxie
                                  Hello @linuxtuxie ,
                                  Thank for your help. With the last update it’s working again.
                                  I probably miss an update -_-" (or forget to read other topic ^^)
                                  Regards,
                                    DarthVaper
                                    any news about this loading problem ?
                                    Regards.
