    MMM-SunnyPortal Solar Module
    23 Posts 7 Posters 13.2k Views 7 Watching
      probably a developer problem… don’t know the module at all
      • L
        linuxtuxie
        It seems that the sunnyportal website is very picky about which user-agent is trying to connect to their web server.
        I just changed the user-agent string on line 61 of the file node_helper.js
        from
        ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:71.0) Gecko/20100101 Firefox/71.0’,
        to
        ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0’,
        And now I am able to login again.
        I will try to work out some better code to prevent this from happening in the future.
        Can somebody else verify if this solution works?
        Regards,
        Linuxtuxie
        T 1 Reply Last reply
        • T
          TheDuDiop @linuxtuxie
          @linuxtuxie thank you will try it tomorrow
            Snake-Darkangel
            Thanks for this great module. I have a problem on the loading.
            mm-error.log
            [2020-06-22 17:30:35.669] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-06-22 17:30:35.671] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-06-22 17:30:36.721] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                at TLSSocket.emit (events.js:200:13)
                at TLSSocket._finishInit (_tls_wrap.js:792:8)
                at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
              code: 'CERT_HAS_EXPIRED'
            [2020-06-22 17:30:36.741] [ERROR]  Unable to fetch login page:  Error: certificate has expired
            [2020-06-22 17:30:36.747] [ERROR]  Unable to fetch login page:  Error: certificate has expired
            [2020-06-22 17:30:39.469] [ERROR]  TypeError: Cannot read property 'statusCode' of undefined
                at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:101:46)
                at self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                at Request.emit (events.js:200:13)
                at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:877:8)
                at ClientRequest.emit (events.js:200:13)
                at TLSSocket.socketErrorListener (_http_client.js:402:9)
                at emitErrorNT (internal/streams/destroy.js:91:8)
                at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                at processTicksAndRejections (internal/process/task_queues.js:84:9)
            So if I read correctly, I see that Buffer() is depreciate.
            But It’s also write something strange with the certificate. In the mm-out.log I see more information:
            0|mm       | [2020-06-22 17:26:43.303] [LOG]    SocketNotification START_SUNNYPORTAL received for the first time...setting updateInterval to 900000ms
            0|mm       | [2020-06-22 17:26:44.113] [LOG]    Refreshed access token because it has expired. Expired at: 17:26:43 now is: 17:26:44
            0|mm       | [2020-06-22 17:26:44.147] [LOG]    Refreshed access token because it has expired. Expired at: 18:26:44 now is: 17:26:44
            What can I do to resolve this case?
            I already try to uninstall and re-install all, with npm install or ./install_deps.sh or the 3 npm install request / flow / chart but it doesn’t works.
            Any idea?
            Thanks for your help
            L 1 Reply Last reply
            • L
              linuxtuxie @Snake-Darkangel
              @Snake-Darkangel
              Thanks to hervidero the code has been altered so that it ignores the provided SSL Certificate.
              Hervidero also made the charts a little bit better and wrote some code to make sure you can’t set an updateInterval < 15 minutes.
              This release also includes the User-Agent change suggested in the previous comment
              The latest release can be fetched here
              https://github.com/linuxtuxie/MMM-SunnyPortal
              Regards,
              Linuxtuxie
              I 1 Reply Last reply
              • I
                icemanmw @linuxtuxie
                @linuxtuxie
                Hello , i try to run the SunnyPortal module, but still no result. I´ve reinstalled the Pi severl times , down to a fresh image with no other modules, but i get only the loading view. thats all.
                Any idea what i have to do ?
                error message from PM2.log
                Login Failed, no redirect to Dashboard or UserProfile/FixedPages/HoManEnergyRedesign.aspx
                • L
                  linuxtuxie @icemanmw
                  Hi icemanmw,
                  It seems that your installation is redirecting you to the following page: /FixedPages/HoManEnergyRedesign.aspx instead of the ones we already know of (DASHBOARD_URL & USERPROFILE_URL )
                  In to code we are checking if the returned HTTP redirect matches the DASHBOARD_URL or USERPROFILE_URL
                  You could try to use the below code in the node_helper.js script to add this page
                  • Add the HOMAN_URL variable at line 21
                    var HOMAN_URL = ‘/FixedPages/HoManEnergyRedesign.aspx’;
                  • Change the code starting from line 99
                    // Hack to check for login. Should forward to dashboard.
                    if(httpResponse.headers.location && httpResponse.headers.location === DASHBOARD_URL) {
                    console.log(“SUCCESSFULLY LOGGED IN TO DASHBOARD”);
                    callback(err, jar);
                    } else if(httpResponse.headers.location && httpResponse.headers.location === USERPROFILE_URL) {
                    console.log(“SUCCESSFULLY LOGGED IN TO USERPROFILE”);
                    callback(err, jar);
                    } else if(httpResponse.headers.location && httpResponse.headers.location === HOMAN_URL) {
                    console.log(“SUCCESSFULLY LOGGED IN TO HOMAN”);
                    callback(err, jar);
                    } else {
                    console.log("Login Failed, no redirect to Dashboard, UserProfile or homan "+ httpResponse.headers.location);
                    callback(new Error(‘Login Failed, no redirect to Dashboard, UserProfile or homan’));
                  Can you let us know the results?
                  Regards,
                  Linuxtuxie
                  • I
                    icemanmw
                    Hi linuxtuxie,
                    sorry fore my late response . I was a few days in Austria.
                    Nevertheless i tried today your proposal and it looks much better. Now i see that :
                      Snake-Darkangel
                      I’ve the same issue. I try the update in the code, adding the httpResponse.headers.location in the log => it’s “undefined”
                      (and http result : 200.)
                      With the new version of the module, I’ve this log:
                      [2020-11-23 12:26:02.231] [LOG]    Login Failed, no redirect to any of the known url's /FixedPages/Dashboard.aspx, /Templates/UserProfile.aspx, /FixedPages/HoManEnergyRedesign.aspx
                      [2020-11-23 12:26:02.233] [LOG]    You are being redirected to the yet unkown url: undefined
                      In my browser I see on the homepage a pop-up for a new SMA application. Maybe that can generate another URL ? I tried to cancel it to see if it’s the problem but … nope :(
                      Still looking for a solution.
                      • L
                        linuxtuxie
                        Hi Snake-Darkangel,
                        Did you use the latest code listed at https://github.com/linuxtuxie/MMM-SunnyPortal ?
                        More specifically the piece of code listed in the file node_helper.js is important. SunnyPortal seems to be very picky when it comes to the browser which makes a connection to there website. I recently updated the user-agent to the latest Firefox version as shown below:
                        headers : {
                        // We need to simulate a Browser which the SunnyPortal accepts…here I am Using Firefox 82.0.3 (64-bit) for Windows
                        ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:82.0) Gecko/20100101 Firefox/82.0’,
                        User SkyFocusNL even used another user-agent to get things working
                        https://forum.magicmirror.builders/topic/14019/mmm-sunnyportal-not-loading/3
                        maybe you can give that solution a try and provide us some feedback ?
                        Regards,
                        Linuxtuxie
                          Snake-Darkangel @linuxtuxie
                          Hello @linuxtuxie ,
                          Thank for your help. With the last update it’s working again.
                          I probably miss an update -_-" (or forget to read other topic ^^)
                          Regards,
                            DarthVaper
                            any news about this loading problem ?
                            Regards.
