    MMM-SunnyPortal Solar Module
    23 Posts 7 Posters 13.0k Views 7 Watching
      sdetweil @TheDuDiop
      @TheDuDiop said in MMM-SunnyPortal Solar Module:
      [2020-05-01 07:50:03.380] [LOG] HTTP Result: 200
      [2020-05-01 07:50:03.385] [LOG] Whoops! There was an uncaught exception…
      [2020-05-01 07:50:03.387] [ERROR] TypeError: Cannot read property ‘1’ of null
      at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:103:121)
      the node_helper didn’t get the response from some service as it expected
      • T Offline
        TheDuDiop
        thanks for your answer, what can I do that the node_helper goes again? or is this a developer problem?
          probably a developer problem… don’t know the module at all
          • L Offline
            linuxtuxie
            It seems that the sunnyportal website is very picky about which user-agent is trying to connect to their web server.
            I just changed the user-agent string on line 61 of the file node_helper.js
            from
            ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:71.0) Gecko/20100101 Firefox/71.0’,
            to
            ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0’,
            And now I am able to login again.
            I will try to work out some better code to prevent this from happening in the future.
            Can somebody else verify if this solution works?
            Regards,
            Linuxtuxie
            • T Offline
              TheDuDiop @linuxtuxie
              @linuxtuxie thank you will try it tomorrow
                Snake-Darkangel
                Thanks for this great module. I have a problem on the loading.
                mm-error.log
                [2020-06-22 17:30:35.669] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                [2020-06-22 17:30:35.671] [ERROR]  (node:2694) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                [2020-06-22 17:30:36.721] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                    at TLSSocket.onConnectSecure (_tls_wrap.js:1317:34)
                    at TLSSocket.emit (events.js:200:13)
                    at TLSSocket._finishInit (_tls_wrap.js:792:8)
                    at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:606:12) {
                  code: 'CERT_HAS_EXPIRED'
                [2020-06-22 17:30:36.741] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                [2020-06-22 17:30:36.747] [ERROR]  Unable to fetch login page:  Error: certificate has expired
                [2020-06-22 17:30:39.469] [ERROR]  TypeError: Cannot read property 'statusCode' of undefined
                    at Request._callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:101:46)
                    at self.callback (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                    at Request.emit (events.js:200:13)
                    at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:877:8)
                    at ClientRequest.emit (events.js:200:13)
                    at TLSSocket.socketErrorListener (_http_client.js:402:9)
                    at emitErrorNT (internal/streams/destroy.js:91:8)
                    at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                    at processTicksAndRejections (internal/process/task_queues.js:84:9)
                So if I read correctly, I see that Buffer() is depreciate.
                But It’s also write something strange with the certificate. In the mm-out.log I see more information:
                0|mm       | [2020-06-22 17:26:43.303] [LOG]    SocketNotification START_SUNNYPORTAL received for the first time...setting updateInterval to 900000ms
                0|mm       | [2020-06-22 17:26:44.113] [LOG]    Refreshed access token because it has expired. Expired at: 17:26:43 now is: 17:26:44
                0|mm       | [2020-06-22 17:26:44.147] [LOG]    Refreshed access token because it has expired. Expired at: 18:26:44 now is: 17:26:44
                What can I do to resolve this case?
                I already try to uninstall and re-install all, with npm install or ./install_deps.sh or the 3 npm install request / flow / chart but it doesn’t works.
                Any idea?
                Thanks for your help
                • L Offline
                  linuxtuxie @Snake-Darkangel
                  @Snake-Darkangel
                  Thanks to hervidero the code has been altered so that it ignores the provided SSL Certificate.
                  Hervidero also made the charts a little bit better and wrote some code to make sure you can’t set an updateInterval < 15 minutes.
                  This release also includes the User-Agent change suggested in the previous comment
                  The latest release can be fetched here
                  https://github.com/linuxtuxie/MMM-SunnyPortal
                  Regards,
                  Linuxtuxie
                  • I Offline
                    icemanmw @linuxtuxie
                    @linuxtuxie
                    Hello , i try to run the SunnyPortal module, but still no result. I´ve reinstalled the Pi severl times , down to a fresh image with no other modules, but i get only the loading view. thats all.
                    Any idea what i have to do ?
                    error message from PM2.log
                    Login Failed, no redirect to Dashboard or UserProfile/FixedPages/HoManEnergyRedesign.aspx
                    • L Offline
                      linuxtuxie @icemanmw
                      Hi icemanmw,
                      It seems that your installation is redirecting you to the following page: /FixedPages/HoManEnergyRedesign.aspx instead of the ones we already know of (DASHBOARD_URL & USERPROFILE_URL )
                      In to code we are checking if the returned HTTP redirect matches the DASHBOARD_URL or USERPROFILE_URL
                      You could try to use the below code in the node_helper.js script to add this page
                      • Add the HOMAN_URL variable at line 21
                        var HOMAN_URL = ‘/FixedPages/HoManEnergyRedesign.aspx’;
                      • Change the code starting from line 99
                        // Hack to check for login. Should forward to dashboard.
                        if(httpResponse.headers.location && httpResponse.headers.location === DASHBOARD_URL) {
                        console.log(“SUCCESSFULLY LOGGED IN TO DASHBOARD”);
                        callback(err, jar);
                        } else if(httpResponse.headers.location && httpResponse.headers.location === USERPROFILE_URL) {
                        console.log(“SUCCESSFULLY LOGGED IN TO USERPROFILE”);
                        callback(err, jar);
                        } else if(httpResponse.headers.location && httpResponse.headers.location === HOMAN_URL) {
                        console.log(“SUCCESSFULLY LOGGED IN TO HOMAN”);
                        callback(err, jar);
                        } else {
                        console.log("Login Failed, no redirect to Dashboard, UserProfile or homan "+ httpResponse.headers.location);
                        callback(new Error(‘Login Failed, no redirect to Dashboard, UserProfile or homan’));
                      Can you let us know the results?
                      Regards,
                      Linuxtuxie
                      • I Offline
                        icemanmw
                        Hi linuxtuxie,
                        sorry fore my late response . I was a few days in Austria.
                        Nevertheless i tried today your proposal and it looks much better. Now i see that :
                          Snake-Darkangel
                          I’ve the same issue. I try the update in the code, adding the httpResponse.headers.location in the log => it’s “undefined”
                          (and http result : 200.)
                          With the new version of the module, I’ve this log:
                          [2020-11-23 12:26:02.231] [LOG]    Login Failed, no redirect to any of the known url's /FixedPages/Dashboard.aspx, /Templates/UserProfile.aspx, /FixedPages/HoManEnergyRedesign.aspx
                          [2020-11-23 12:26:02.233] [LOG]    You are being redirected to the yet unkown url: undefined
                          In my browser I see on the homepage a pop-up for a new SMA application. Maybe that can generate another URL ? I tried to cancel it to see if it’s the problem but … nope :(
                          Still looking for a solution.
                          • L Offline
                            linuxtuxie
                            Hi Snake-Darkangel,
                            Did you use the latest code listed at https://github.com/linuxtuxie/MMM-SunnyPortal ?
                            More specifically the piece of code listed in the file node_helper.js is important. SunnyPortal seems to be very picky when it comes to the browser which makes a connection to there website. I recently updated the user-agent to the latest Firefox version as shown below:
                            headers : {
                            // We need to simulate a Browser which the SunnyPortal accepts…here I am Using Firefox 82.0.3 (64-bit) for Windows
                            ‘User-Agent’: ‘Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:82.0) Gecko/20100101 Firefox/82.0’,
                            User SkyFocusNL even used another user-agent to get things working
                            https://forum.magicmirror.builders/topic/14019/mmm-sunnyportal-not-loading/3
                            maybe you can give that solution a try and provide us some feedback ?
                            Regards,
                            Linuxtuxie
                              Snake-Darkangel @linuxtuxie
                              Hello @linuxtuxie ,
                              Thank for your help. With the last update it’s working again.
                              I probably miss an update -_-" (or forget to read other topic ^^)
                              Regards,
                                DarthVaper
                                any news about this loading problem ?
                                Regards.
