    MMM GoogleAssistant mv client_secret_XXX.json credentials.json
    11 Posts 2 Posters 4.0k Views 2 Watching
      sdetweil @wirdman
      @wirdman is it in this google assistant folder or still in Downloads?
      cd ~/MagicMirror/modules/MMM-GoogleAssistant
      ls *.json -laF
      and
      cd ~/Downloads
      ls *.json -laF
      • W Offline
        wirdman
        nothing in download
        pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ ls *.json -laF
        -rw-r--r-- 1 pi pi   546 jui 13 21:29 credentials.json
        -rw-r--r-- 1 pi pi   132 jui 13 20:06 deviceInstance.sample.json
        -rw-r--r-- 1 pi pi  1610 jui 13 20:06 package.json
        -rw-r--r-- 1 pi pi 79267 jui 13 20:49 package-lock.json
          sdetweil @wirdman
          @wirdman said in MMM GoogleAssistant mv client_secret_XXX.json credentials.json:
          credentials.json
          already in assistant folder
          • W Offline
            wirdman
            but after
            pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ node auth_and_test.js
            /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/components/auth.js:27
              const oauthClient = new OAuth2(key.client_id, key.client_secret, key.redirect_uris[0]);
            TypeError: Cannot read property 'client_id' of undefined
                at new Auth (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/components/auth.js:27:38)
                at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/google-assistant/index.js:21:16)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/auth_and_test.js:60:19)
                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                at startup (internal/bootstrap/node.js:283:19)
              did u download the correct credentials?
              I would go recheck that step of the instructions… it worked for me when I did it
              • W Offline
                wirdman
                honestly i think this is in my credentials :
                {"web":{"client_id":"109652145873-5nkqrfro300pe1pi6r5gd0v9sutdolmm.apps.googleusercontent.com","project_id":"smart-mirrorr-b3d55","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"hYgsFML7eyHnsy7HClmmUSzR","redirect_uris":["https://smart-mirrorr-b3d55.firebaseapp.com/__/auth/handler"],"javascript_origins":["http://localhost","http://localhost:5000","https://smart-mirrorr-b3d55.firebaseapp.com"]}}
                • W Offline
                  wirdman
                  • W Offline
                    wirdman
                    Hey thanks you this step is done
                    but know im lost when i write the line
                    i got this error
                    thank you again for your help
