    After update WARNING! Could not load config file.
    28 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @uok825
      @uok825 any progress?
      U 2 Replies Last reply
      • U
        uok825 @sdetweil
        pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm rebuild
        > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
        > node-gyp rebuild
        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epol        l/build'
         CXX(target) Release/obj.target/epoll/src/epoll.o
         SOLINK_MODULE(target) Release/obj.target/epoll.node
         COPY Release/epoll.node
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll        /build'
        child_process@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/child_proc        ess
        electron-rebuild@1.11.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/electr        on-rebuild
        colors@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/colors
        debug@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/debug
        ms@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ms
        detect-libc@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/detect-libc
        fs-extra@8.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-extra
        graceful-fs@4.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/graceful-fs
        jsonfile@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsonfile
        universalify@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/universalif        y
        node-abi@2.18.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-abi
        semver@5.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/semver
        node-gyp@6.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-gyp
        env-paths@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/env-paths
        glob@7.1.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/glob
        fs.realpath@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs.realpath
        inflight@1.0.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inflight
        once@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/once
        wrappy@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrappy
        inherits@2.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inherits
        minimatch@3.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimatch
        brace-expansion@1.1.11 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/brace-e        xpansion
        balanced-match@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/balanced-        match
        concat-map@0.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/concat-map
        path-is-absolute@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-is        -absolute
        mkdirp@0.5.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mkdirp
        minimist@1.2.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimist
        nopt@4.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nopt
        abbrev@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/abbrev
        osenv@0.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/osenv
        os-homedir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-homedir
        os-tmpdir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-tmpdir
        npmlog@4.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/npmlog
        are-we-there-yet@1.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/are-we-        there-yet
        delegates@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delegates
        readable-stream@2.3.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/readable        -stream
        core-util-is@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/core-util-i        s
        isarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isarray
        process-nextick-args@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/pro        cess-nextick-args
        safe-buffer@5.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safe-buffer
        string_decoder@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string_de        coder
        util-deprecate@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/util-depr        ecate
        console-control-strings@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        console-control-strings
        gauge@2.7.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/gauge
        aproba@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aproba
        has-unicode@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-unicode
        object-assign@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/object-ass        ign
        signal-exit@3.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/signal-exit
        string-width@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string-widt        h
        code-point-at@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/code-point        -at
        is-fullwidth-code-point@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        is-fullwidth-code-point
        number-is-nan@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/number-is-        nan
        strip-ansi@3.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/strip-ansi
        ansi-regex@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-regex
        wide-align@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wide-align
        set-blocking@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/set-blockin        g
        request@2.88.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/request
        aws-sign2@0.7.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws-sign2
        aws4@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws4
        caseless@0.12.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/caseless
        combined-stream@1.0.8 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/combined        -stream
        delayed-stream@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delayed-s        tream
        extend@3.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extend
        forever-agent@0.6.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/forever-ag        ent
        form-data@2.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/form-data
        asynckit@0.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asynckit
        mime-types@2.1.27 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-types
        mime-db@1.44.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-db
        har-validator@5.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-valida        tor
        ajv@6.12.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ajv
        fast-deep-equal@3.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fast-dee        p-equal
        fast-json-stable-stringify@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modul        es/fast-json-stable-stringify
        json-schema-traverse@0.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jso        n-schema-traverse
        uri-js@4.2.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uri-js
        punycode@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/punycode
        har-schema@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-schema
        http-signature@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/http-sign        ature
        assert-plus@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/assert-plus
        jsprim@1.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsprim
        extsprintf@1.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extsprintf
        json-schema@0.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json-schema
        verror@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/verror
        sshpk@1.16.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/sshpk
        asn1@0.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asn1
        safer-buffer@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safer-buffe        r
        bcrypt-pbkdf@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bcrypt-pbkd        f
        tweetnacl@0.14.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tweetnacl
        dashdash@1.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/dashdash
        ecc-jsbn@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ecc-jsbn
        jsbn@0.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsbn
        getpass@0.1.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/getpass
        is-typedarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/is-typedar        ray
        isstream@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isstream
        json-stringify-safe@5.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json        -stringify-safe
        oauth-sign@0.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/oauth-sign
        performance-now@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/performa        nce-now
        qs@6.5.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/qs
        tough-cookie@2.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tough-cooki        e
        psl@1.8.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/psl
        tunnel-agent@0.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tunnel-agen        t
        uuid@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uuid
        rimraf@2.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rimraf
        tar@4.4.13 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tar
        chownr@1.1.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chownr
        fs-minipass@1.2.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-minipass
        minipass@2.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minipass
        yallist@3.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yallist
        minizlib@1.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minizlib
        which@1.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which
        isexe@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isexe
        ora@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora
        chalk@2.4.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chalk
        ansi-styles@3.2.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-styles
        color-convert@1.9.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-conv        ert
        color-name@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-name
        escape-string-regexp@1.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/esc        ape-string-regexp
        supports-color@5.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/supports-        color
        has-flag@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-flag
        cli-cursor@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-cursor
        restore-cursor@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/restore-c        ursor
        onetime@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onetime
        mimic-fn@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mimic-fn
        cli-spinners@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-spinner        s
        log-symbols@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/log-symbols
        strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/strip-ansi
        ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/ansi-regex
        wcwidth@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wcwidth
        defaults@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/defaults
        clone@1.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/clone
        spawn-rx@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx
        debug@2.6.9 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modu        les/debug
        ms@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modules        /ms
        lodash.assign@4.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/lodash.ass        ign
        rxjs@6.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rxjs
        tslib@1.13.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tslib
        yargs@14.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs
        cliui@5.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui
        string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_        modules/string-width
        emoji-regex@7.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/emoji-regex
        is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        cliui/node_modules/is-fullwidth-code-point
        strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/strip-ansi
        ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/ansi-regex
        wrap-ansi@5.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi
        string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/n        ode_modules/string-width
        is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        wrap-ansi/node_modules/is-fullwidth-code-point
        strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/strip-ansi
        ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/ansi-regex
        decamelize@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/decamelize
        find-up@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/find-up
        locate-path@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/locate-path
        p-locate@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-locate
        p-limit@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-limit
        p-try@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-try
        path-exists@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-exists
        get-caller-file@2.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/get-call        er-file
        require-directory@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/requir        e-directory
        require-main-filename@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/re        quire-main-filename
        string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_        modules/string-width
        is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        yargs/node_modules/is-fullwidth-code-point
        strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/strip-ansi
        ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/ansi-regex
        which-module@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which-modul        e
        y18n@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/y18n
        yargs-parser@15.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs-pars        er
        camelcase@5.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/camelcase
        onoff@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff
        epoll@2.0.10 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
        bindings@1.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings
        file-uri-to-path@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/file-ur        i-to-path
        nan@2.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nan
        • U
          uok825 @sdetweil
          0|MagicMir | [2020-07-13 18:04:01.849] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:11:18)
          0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
          0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
          0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
          0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
          0|MagicMir |     at loadModule (/home/pi/MagicMirror/js/app.js:124:17)
          0|MagicMir |     at loadNextModule (/home/pi/MagicMirror/js/app.js:158:5)
          0|MagicMir | [2020-07-13 18:04:02.059] [ERROR]  Whoops! There was an uncaught exception...
          0|MagicMir | [2020-07-13 18:04:02.071] [ERROR]  ReferenceError: NodeHelper is not defined
          0|MagicMir | [2020-07-13 18:04:02.143] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | [2020-07-13 18:04:02.145] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          Same
            sdetweil @uok825
            @uok825 what a mess.
            so. now I think u need to erase module folder and then reinstall module. the two back recovery mechanisms don’t work
            • U
              uok825 @sdetweil
              @sdetweil ok
              • U
                uok825 @sdetweil
                @sdetweil Not working
                  sdetweil @uok825
                  @uok825 man what a pain,
                  ok, delete the module folder (MMM-PIR) and then reclone and npm install
                  U 1 Reply Last reply
                  • U
                    uok825 @sdetweil
                    @sdetweil I already did and my relay is not working i was pissed of so much.
                    i need to unbuilt my mirror :(
                    and my weather forecast shows 2 day
                      sdetweil @uok825
                      @uok825 2 days, bug, switch to develop branch
                      git fetch origin develop:develop
                      git checkout develop
                      then restart MM
                      • U
                        uok825 @sdetweil
                          sdetweil @uok825
                          @uok825
                          do
                          # remove tracked file, un-needed
                          rm package-lock.json
                          # save the package.json changes
                          git stash
                          # switch to the other branch
                          # restore the package.json file
                          git stash pop
                          restart mm
                          • U
                            uok825 @sdetweil
                            @sdetweil in mm folder right?
                              sdetweil @uok825
                              @uok825 yes
                              • U
                                uok825 @sdetweil
                                  sdetweil @uok825
                                  @uok825 yeh, always something…
                                  execute the two git commands
                                  in the script I do this
                                   git config --global user.name "upgrade_script"
                                   git config --global user.email "script@upgrade.com"
                                  then resume the prior commands at git stash
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil i did restarting mm.
                                      sdetweil @uok825
                                      @uok825 and after all that weather should show more than 2 days
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil said in After update WARNING! Could not load config file.:
                                        t
                                        yep its is working thx
                                          sdetweil @uok825
                                          @uok825 awesome, thanks for hanging in there with me…
