    After update WARNING! Could not load config file.
    28 Posts 2 Posters 6.5k Views 2 Watching
    • U Offline
      uok825
      I use sdetweil pi0 script and i upgrade with his script. but after i update mm i got error here is my log and config file.
      Log
      0|MagicMir | [2020-07-12 23:06:47.162] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | was compiled against a different Node.js version using
      0|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
      0|MagicMir | NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
      0|MagicMir | [2020-07-12 23:06:47.332] [ERROR]  Whoops! There was an uncaught exception...
      0|MagicMir | [2020-07-12 23:06:47.340] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir |     at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
      0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
      0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
      0|MagicMir |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings/bindings.js:112:48)
      0|MagicMir |     at module.exports (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:7:31)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:15:3)
      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
      0|MagicMir | [2020-07-12 23:06:47.381] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-07-12 23:06:47.383] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-07-12 23:09:02.052] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | [2020-07-12 23:09:02.222] [ERROR]  Whoops! There was an uncaught exception...
      0|MagicMir | [2020-07-12 23:09:02.229] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | [2020-07-12 23:09:02.288] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-07-12 23:09:02.293] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
      0|MagicMir | [2020-07-12 23:06:46.926] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:46.936] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:06:47.172] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:06:47.181] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:06:47.194] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.203] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:06:47.211] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:06:47.220] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.227] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:06:47.237] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:06:47.249] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:06:47.256] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.262] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:06:47.271] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.280] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | Starting chromium browser now, have patience, it takes a minute
      0|MagicMir |
      0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
      0|MagicMir | > ./run-start.sh $1
      0|MagicMir |
      0|MagicMir | [2020-07-12 23:08:56.716] [LOG] Starting MagicMirror: v2.12.0
      0|MagicMir | [2020-07-12 23:08:56.843] [LOG] Loading config ...
      0|MagicMir | [2020-07-12 23:08:56.888] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:08:56.909] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:08:57.343] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:08:57.353] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:08:57.365] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:09:01.433] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.441] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:09:01.454] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:09:01.462] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:09:01.776] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.785] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:09:01.815] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.824] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:09:02.060] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:09:02.074] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:09:02.083] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.092] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:09:02.101] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:09:02.110] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.117] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:09:02.127] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:09:02.136] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:09:02.149] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.156] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:09:02.162] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.170] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir |
      0|MagicMir |
      0|MagicMir | [2020-07-12 23:11:30.385] [LOG] Starting MagicMirror: v2.12.0
      0|MagicMir | [2020-07-12 23:11:30.529] [LOG] Loading config ...
      0|MagicMir | [2020-07-12 23:11:30.577] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:11:30.596] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:11:31.031] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:31.041] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:11:31.052] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:11:35.076] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.085] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:11:35.095] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:11:35.105] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:11:35.423] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.431] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:11:35.461] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.471] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:35.494] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.516] [LOG] All module helpers loaded.
      0|MagicMir | [2020-07-12 23:11:36.464] [LOG] Starting server on port 8080 ...
      0|MagicMir | [2020-07-12 23:11:36.583] [LOG] Server started ...
      0|MagicMir | [2020-07-12 23:11:36.598] [LOG] Connecting socket for: updatenotification
      0|MagicMir | [2020-07-12 23:11:36.610] [LOG] Connecting socket for: calendar
      0|MagicMir | [2020-07-12 23:11:36.621] [LOG] Starting node helper for: calendar
      0|MagicMir | [2020-07-12 23:11:36.634] [LOG] Connecting socket for: newsfeed
      0|MagicMir | [2020-07-12 23:11:36.645] [LOG] Starting node helper for: newsfeed
      0|MagicMir | [2020-07-12 23:11:36.655] [LOG] Connecting socket for: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:36.663] [LOG] Starting node_helper for: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:36.694] [LOG] Sockets connected & modules started ...
      0|MagicMir | [2020-07-12 23:11:36.703] [LOG]
      0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
      0|MagicMir | [2020-07-12 23:12:53.342] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:00.472] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:13:01.012] [LOG]    Create new news fetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:02.017] [LOG]    Create new news fetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:11.411] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
      0|MagicMir | [2020-07-12 23:13:21.911] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
      0|MagicMir | [2020-07-12 23:13:22.391] [INFO]   Checking git for module: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:13:23.143] [INFO]   Checking git for module: MMM-LICE
      0|MagicMir | [2020-07-12 23:13:24.001] [LOG]    200[object Object]
      0|MagicMir | [2020-07-12 23:17:48.646] [LOG]    Use existing calendar fetcher for url: x
      0|MagicMir | [2020-07-12 23:17:48.653] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:17:49.895] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:18:15.530] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
      0|MagicMir | [2020-07-12 23:18:27.760] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
      My config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/255"], // Set [] to allow all IP addresses
      	language: "tr",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			disabled: false,
      			module: "updatenotification",
      			disabled: false,
      			position: "top_bar"
      			module: "clock",
      			disabled: false,
      			position: "top_left"
      			disabled: false,
      			header: "Takvimim Ve Ozel Gunler",
      						symbol: "calendar-plus-o",
      						url: "x"
      			module: "currentweather",
      			disabled: false,
      				locationID: "306569",
      				appid: "x"
      			module: "weatherforecast",
      			disabled: false,
      			header: "Hava Durumu",
      				appid: "x"
      			module: "newsfeed",
      			disabled: false,
      			position: "bottom_center",
      				feeds: [
      						title: "CNN Türk",
      						url: "https://www.cnnturk.com/feed/rss/turkiye/news"
      						title: "BirGun",
      						url: "https://www.birgun.net/xml/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true
      		  module: 'MMM-MyPrayerTimes',
      		  position: 'top_center',
      		  header: 'Namaz Vakitleri',
      			module: "MMM-PIR",
      				sensorPin: 24,
      				delay: 300000,
      				turnOffDisplay: true,
      				showCountdown: false,
      				callbackScripts: []
      • U Offline
        uok825
        @sdetweil waiting for your help. :)
          sdetweil @uok825
          @uok825 thanks for posting… another troublesome module
          do
          npm install electron-rebuild
          cd modules/MMM-PIR
          ~/MagicMirror/node_modules/.bin/electron-rebuild
          pm2 flush
          then restart your MM
          let me know
          U 3 Replies Last reply Reply Quote 0
          • U Offline
            uok825 @sdetweil
            @sdetweil Sure i will do, now i middle of reinstalling module. When its install i try your solution and let you know :) sorry for bad English.
              sdetweil @uok825
              @uok825 no problem… didn’t need to reinstall module
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                uok825 @sdetweil
                @sdetweil I was trying out of desperation
                • U Offline
                  uok825 @sdetweil
                  @sdetweil said in After update WARNING! Could not load config file.:
                  do
                  cd modules/MMM-PIR
                  pm2 flush
                  let me know
                  i got error but i cant share my log cause of “Post content was flagged as spam by Akismet.com” error in npm install electron-rebuild
                  • U Offline
                    uok825 @sdetweil
                    do
                    cd modules/MMM-PIR
                    pm2 flush
                    let me know
                      sdetweil @uok825
                      @uok825 sorry, dumb of me to take u down the electron path when u don’t have electron.
                      cd ~/MagicMirror/modules/MMM-PIR
                      npm rebuild
                        sdetweil @uok825
                        @uok825 any progress?
                        U 2 Replies Last reply Reply Quote 0
