    After update WARNING! Could not load config file.
    28 Posts 2 Posters 6.8k Views 2 Watching
    • U Offline
      uok825
      I use sdetweil pi0 script and i upgrade with his script. but after i update mm i got error here is my log and config file.
      Log
      0|MagicMir | [2020-07-12 23:06:47.162] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | was compiled against a different Node.js version using
      0|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
      0|MagicMir | NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      0|MagicMir | the module (for instance, using `npm rebuild` or `npm install`).
      0|MagicMir | [2020-07-12 23:06:47.332] [ERROR]  Whoops! There was an uncaught exception...
      0|MagicMir | [2020-07-12 23:06:47.340] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir |     at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
      0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
      0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
      0|MagicMir |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings/bindings.js:112:48)
      0|MagicMir |     at module.exports (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:7:31)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/epoll.js:15:3)
      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
      0|MagicMir | [2020-07-12 23:06:47.381] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-07-12 23:06:47.383] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2020-07-12 23:09:02.052] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | [2020-07-12 23:09:02.222] [ERROR]  Whoops! There was an uncaught exception...
      0|MagicMir | [2020-07-12 23:09:02.229] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | [2020-07-12 23:09:02.288] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [2020-07-12 23:09:02.293] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
      0|MagicMir | [2020-07-12 23:06:46.926] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:46.936] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:06:47.172] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:06:47.181] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:06:47.194] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.203] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:06:47.211] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:06:47.220] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.227] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:06:47.237] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:06:47.249] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:06:47.256] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.262] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:06:47.271] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:06:47.280] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | Starting chromium browser now, have patience, it takes a minute
      0|MagicMir |
      0|MagicMir | > magicmirror@2.12.0 start /home/pi/MagicMirror
      0|MagicMir | > ./run-start.sh $1
      0|MagicMir |
      0|MagicMir | [2020-07-12 23:08:56.716] [LOG] Starting MagicMirror: v2.12.0
      0|MagicMir | [2020-07-12 23:08:56.843] [LOG] Loading config ...
      0|MagicMir | [2020-07-12 23:08:56.888] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:08:56.909] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:08:57.343] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:08:57.353] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:08:57.365] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:09:01.433] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.441] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:09:01.454] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:09:01.462] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:09:01.776] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.785] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:09:01.815] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:01.824] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:09:02.060] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:09:02.074] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:09:02.083] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.092] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:09:02.101] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:09:02.110] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.117] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:09:02.127] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:09:02.136] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:09:02.149] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.156] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:09:02.162] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:09:02.170] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir |
      0|MagicMir |
      0|MagicMir | [2020-07-12 23:11:30.385] [LOG] Starting MagicMirror: v2.12.0
      0|MagicMir | [2020-07-12 23:11:30.529] [LOG] Loading config ...
      0|MagicMir | [2020-07-12 23:11:30.577] [LOG] Loading module helpers ...
      0|MagicMir | [2020-07-12 23:11:30.596] [LOG] No helper found for module: alert.
      0|MagicMir | [2020-07-12 23:11:31.031] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:31.041] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [2020-07-12 23:11:31.052] [LOG] No helper found for module: clock.
      0|MagicMir | [2020-07-12 23:11:35.076] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.085] [LOG] Module helper loaded: calendar
      0|MagicMir | [2020-07-12 23:11:35.095] [LOG] No helper found for module: currentweather.
      0|MagicMir | [2020-07-12 23:11:35.105] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [2020-07-12 23:11:35.423] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.431] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [2020-07-12 23:11:35.461] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.471] [LOG] Module helper loaded: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:35.494] [LOG] Initializing new module helper ...
      0|MagicMir | [2020-07-12 23:11:35.516] [LOG] All module helpers loaded.
      0|MagicMir | [2020-07-12 23:11:36.464] [LOG] Starting server on port 8080 ...
      0|MagicMir | [2020-07-12 23:11:36.583] [LOG] Server started ...
      0|MagicMir | [2020-07-12 23:11:36.598] [LOG] Connecting socket for: updatenotification
      0|MagicMir | [2020-07-12 23:11:36.610] [LOG] Connecting socket for: calendar
      0|MagicMir | [2020-07-12 23:11:36.621] [LOG] Starting node helper for: calendar
      0|MagicMir | [2020-07-12 23:11:36.634] [LOG] Connecting socket for: newsfeed
      0|MagicMir | [2020-07-12 23:11:36.645] [LOG] Starting node helper for: newsfeed
      0|MagicMir | [2020-07-12 23:11:36.655] [LOG] Connecting socket for: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:36.663] [LOG] Starting node_helper for: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:11:36.694] [LOG] Sockets connected & modules started ...
      0|MagicMir | [2020-07-12 23:11:36.703] [LOG]
      0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
      0|MagicMir | [2020-07-12 23:12:53.342] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:00.472] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:13:01.012] [LOG]    Create new news fetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:02.017] [LOG]    Create new news fetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
      0|MagicMir | [2020-07-12 23:13:11.411] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
      0|MagicMir | [2020-07-12 23:13:21.911] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
      0|MagicMir | [2020-07-12 23:13:22.391] [INFO]   Checking git for module: MMM-MyPrayerTimes
      0|MagicMir | [2020-07-12 23:13:23.143] [INFO]   Checking git for module: MMM-LICE
      0|MagicMir | [2020-07-12 23:13:24.001] [LOG]    200[object Object]
      0|MagicMir | [2020-07-12 23:17:48.646] [LOG]    Use existing calendar fetcher for url: x
      0|MagicMir | [2020-07-12 23:17:48.653] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:17:49.895] [INFO]   Calendar-Fetcher: Broadcasting 19 events.
      0|MagicMir | [2020-07-12 23:18:15.530] [INFO]   Newsfeed-Fetcher: Broadcasting 35 items.
      0|MagicMir | [2020-07-12 23:18:27.760] [INFO]   Newsfeed-Fetcher: Broadcasting 200 items.
      My config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/255"], // Set [] to allow all IP addresses
      	language: "tr",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			disabled: false,
      			module: "updatenotification",
      			disabled: false,
      			position: "top_bar"
      			module: "clock",
      			disabled: false,
      			position: "top_left"
      			disabled: false,
      			header: "Takvimim Ve Ozel Gunler",
      						symbol: "calendar-plus-o",
      						url: "x"
      			module: "currentweather",
      			disabled: false,
      				locationID: "306569",
      				appid: "x"
      			module: "weatherforecast",
      			disabled: false,
      			header: "Hava Durumu",
      				appid: "x"
      			module: "newsfeed",
      			disabled: false,
      			position: "bottom_center",
      				feeds: [
      						title: "CNN Türk",
      						url: "https://www.cnnturk.com/feed/rss/turkiye/news"
      						title: "BirGun",
      						url: "https://www.birgun.net/xml/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true
      		  module: 'MMM-MyPrayerTimes',
      		  position: 'top_center',
      		  header: 'Namaz Vakitleri',
      			module: "MMM-PIR",
      				sensorPin: 24,
      				delay: 300000,
      				turnOffDisplay: true,
      				showCountdown: false,
      				callbackScripts: []
      • U Offline
        uok825
        @sdetweil waiting for your help. :)
          sdetweil @uok825
          @uok825 thanks for posting… another troublesome module
          do
          npm install electron-rebuild
          cd modules/MMM-PIR
          ~/MagicMirror/node_modules/.bin/electron-rebuild
          pm2 flush
          then restart your MM
          let me know
          U 3 Replies Last reply Reply Quote 0
          • U Offline
            uok825 @sdetweil
            @sdetweil Sure i will do, now i middle of reinstalling module. When its install i try your solution and let you know :) sorry for bad English.
              sdetweil @uok825
              @uok825 no problem… didn’t need to reinstall module
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                uok825 @sdetweil
                @sdetweil I was trying out of desperation
                • U Offline
                  uok825 @sdetweil
                  @sdetweil said in After update WARNING! Could not load config file.:
                  do
                  cd modules/MMM-PIR
                  pm2 flush
                  let me know
                  i got error but i cant share my log cause of “Post content was flagged as spam by Akismet.com” error in npm install electron-rebuild
                  • U Offline
                    uok825 @sdetweil
                    do
                    cd modules/MMM-PIR
                    pm2 flush
                    let me know
                      sdetweil @uok825
                      @uok825 sorry, dumb of me to take u down the electron path when u don’t have electron.
                      cd ~/MagicMirror/modules/MMM-PIR
                      npm rebuild
                        sdetweil @uok825
                        @uok825 any progress?
                        U 2 Replies Last reply Reply Quote 0
                        • U Offline
                          uok825 @sdetweil
                          pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm rebuild
                          > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                          > node-gyp rebuild
                          make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epol        l/build'
                           CXX(target) Release/obj.target/epoll/src/epoll.o
                           SOLINK_MODULE(target) Release/obj.target/epoll.node
                           COPY Release/epoll.node
                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll        /build'
                          child_process@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/child_proc        ess
                          electron-rebuild@1.11.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/electr        on-rebuild
                          colors@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/colors
                          debug@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/debug
                          ms@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ms
                          detect-libc@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/detect-libc
                          fs-extra@8.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-extra
                          graceful-fs@4.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/graceful-fs
                          jsonfile@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsonfile
                          universalify@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/universalif        y
                          node-abi@2.18.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-abi
                          semver@5.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/semver
                          node-gyp@6.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-gyp
                          env-paths@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/env-paths
                          glob@7.1.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/glob
                          fs.realpath@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs.realpath
                          inflight@1.0.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inflight
                          once@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/once
                          wrappy@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrappy
                          inherits@2.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inherits
                          minimatch@3.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimatch
                          brace-expansion@1.1.11 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/brace-e        xpansion
                          balanced-match@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/balanced-        match
                          concat-map@0.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/concat-map
                          path-is-absolute@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-is        -absolute
                          mkdirp@0.5.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mkdirp
                          minimist@1.2.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimist
                          nopt@4.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nopt
                          abbrev@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/abbrev
                          osenv@0.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/osenv
                          os-homedir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-homedir
                          os-tmpdir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-tmpdir
                          npmlog@4.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/npmlog
                          are-we-there-yet@1.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/are-we-        there-yet
                          delegates@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delegates
                          readable-stream@2.3.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/readable        -stream
                          core-util-is@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/core-util-i        s
                          isarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isarray
                          process-nextick-args@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/pro        cess-nextick-args
                          safe-buffer@5.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safe-buffer
                          string_decoder@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string_de        coder
                          util-deprecate@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/util-depr        ecate
                          console-control-strings@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        console-control-strings
                          gauge@2.7.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/gauge
                          aproba@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aproba
                          has-unicode@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-unicode
                          object-assign@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/object-ass        ign
                          signal-exit@3.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/signal-exit
                          string-width@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string-widt        h
                          code-point-at@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/code-point        -at
                          is-fullwidth-code-point@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        is-fullwidth-code-point
                          number-is-nan@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/number-is-        nan
                          strip-ansi@3.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/strip-ansi
                          ansi-regex@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-regex
                          wide-align@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wide-align
                          set-blocking@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/set-blockin        g
                          request@2.88.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/request
                          aws-sign2@0.7.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws-sign2
                          aws4@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws4
                          caseless@0.12.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/caseless
                          combined-stream@1.0.8 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/combined        -stream
                          delayed-stream@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delayed-s        tream
                          extend@3.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extend
                          forever-agent@0.6.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/forever-ag        ent
                          form-data@2.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/form-data
                          asynckit@0.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asynckit
                          mime-types@2.1.27 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-types
                          mime-db@1.44.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-db
                          har-validator@5.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-valida        tor
                          ajv@6.12.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ajv
                          fast-deep-equal@3.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fast-dee        p-equal
                          fast-json-stable-stringify@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modul        es/fast-json-stable-stringify
                          json-schema-traverse@0.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jso        n-schema-traverse
                          uri-js@4.2.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uri-js
                          punycode@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/punycode
                          har-schema@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-schema
                          http-signature@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/http-sign        ature
                          assert-plus@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/assert-plus
                          jsprim@1.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsprim
                          extsprintf@1.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extsprintf
                          json-schema@0.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json-schema
                          verror@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/verror
                          sshpk@1.16.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/sshpk
                          asn1@0.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asn1
                          safer-buffer@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safer-buffe        r
                          bcrypt-pbkdf@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bcrypt-pbkd        f
                          tweetnacl@0.14.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tweetnacl
                          dashdash@1.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/dashdash
                          ecc-jsbn@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ecc-jsbn
                          jsbn@0.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsbn
                          getpass@0.1.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/getpass
                          is-typedarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/is-typedar        ray
                          isstream@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isstream
                          json-stringify-safe@5.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json        -stringify-safe
                          oauth-sign@0.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/oauth-sign
                          performance-now@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/performa        nce-now
                          qs@6.5.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/qs
                          tough-cookie@2.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tough-cooki        e
                          psl@1.8.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/psl
                          tunnel-agent@0.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tunnel-agen        t
                          uuid@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uuid
                          rimraf@2.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rimraf
                          tar@4.4.13 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tar
                          chownr@1.1.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chownr
                          fs-minipass@1.2.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-minipass
                          minipass@2.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minipass
                          yallist@3.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yallist
                          minizlib@1.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minizlib
                          which@1.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which
                          isexe@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isexe
                          ora@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora
                          chalk@2.4.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chalk
                          ansi-styles@3.2.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-styles
                          color-convert@1.9.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-conv        ert
                          color-name@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-name
                          escape-string-regexp@1.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/esc        ape-string-regexp
                          supports-color@5.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/supports-        color
                          has-flag@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-flag
                          cli-cursor@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-cursor
                          restore-cursor@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/restore-c        ursor
                          onetime@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onetime
                          mimic-fn@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mimic-fn
                          cli-spinners@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-spinner        s
                          log-symbols@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/log-symbols
                          strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/strip-ansi
                          ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/ansi-regex
                          wcwidth@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wcwidth
                          defaults@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/defaults
                          clone@1.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/clone
                          spawn-rx@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx
                          debug@2.6.9 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modu        les/debug
                          ms@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modules        /ms
                          lodash.assign@4.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/lodash.ass        ign
                          rxjs@6.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rxjs
                          tslib@1.13.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tslib
                          yargs@14.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs
                          cliui@5.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui
                          string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_        modules/string-width
                          emoji-regex@7.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/emoji-regex
                          is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        cliui/node_modules/is-fullwidth-code-point
                          strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/strip-ansi
                          ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/ansi-regex
                          wrap-ansi@5.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi
                          string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/n        ode_modules/string-width
                          is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        wrap-ansi/node_modules/is-fullwidth-code-point
                          strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/strip-ansi
                          ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/ansi-regex
                          decamelize@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/decamelize
                          find-up@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/find-up
                          locate-path@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/locate-path
                          p-locate@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-locate
                          p-limit@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-limit
                          p-try@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-try
                          path-exists@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-exists
                          get-caller-file@2.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/get-call        er-file
                          require-directory@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/requir        e-directory
                          require-main-filename@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/re        quire-main-filename
                          string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_        modules/string-width
                          is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        yargs/node_modules/is-fullwidth-code-point
                          strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/strip-ansi
                          ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/ansi-regex
                          which-module@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which-modul        e
                          y18n@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/y18n
                          yargs-parser@15.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs-pars        er
                          camelcase@5.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/camelcase
                          onoff@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff
                          epoll@2.0.10 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                          bindings@1.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings
                          file-uri-to-path@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/file-ur        i-to-path
                          nan@2.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nan
                          • U Offline
                            uok825 @sdetweil
                            0|MagicMir | [2020-07-13 18:04:01.849] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                            0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:11:18)
                            0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                            0|MagicMir |     at loadModule (/home/pi/MagicMirror/js/app.js:124:17)
                            0|MagicMir |     at loadNextModule (/home/pi/MagicMirror/js/app.js:158:5)
                            0|MagicMir | [2020-07-13 18:04:02.059] [ERROR]  Whoops! There was an uncaught exception...
                            0|MagicMir | [2020-07-13 18:04:02.071] [ERROR]  ReferenceError: NodeHelper is not defined
                            0|MagicMir | [2020-07-13 18:04:02.143] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMir | [2020-07-13 18:04:02.145] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            Same
                              sdetweil @uok825
                              @uok825 what a mess.
                              so. now I think u need to erase module folder and then reinstall module. the two back recovery mechanisms don’t work
                              • U Offline
                                uok825 @sdetweil
                                @sdetweil ok
                                • U Offline
                                  uok825 @sdetweil
                                  @sdetweil Not working
                                    sdetweil @uok825
                                    @uok825 man what a pain,
                                    ok, delete the module folder (MMM-PIR) and then reclone and npm install
                                    • U Offline
                                      uok825 @sdetweil
                                      @sdetweil I already did and my relay is not working i was pissed of so much.
                                      i need to unbuilt my mirror :(
                                      and my weather forecast shows 2 day
                                        sdetweil @uok825
                                        @uok825 2 days, bug, switch to develop branch
                                        git fetch origin develop:develop
                                        git checkout develop
                                        then restart MM
                                        • U Offline
                                          uok825 @sdetweil
                                            sdetweil @uok825
                                            @uok825
                                            do
                                            # remove tracked file, un-needed
                                            rm package-lock.json
                                            # save the package.json changes
                                            git stash
                                            # switch to the other branch
                                            # restore the package.json file
                                            git stash pop
                                            restart mm
                                            U 1 Reply Last reply Reply Quote 1
