    After update WARNING! Could not load config file.
    28 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @uok825
      @uok825 thanks for posting… another troublesome module
      0|MagicMir | [2020-07-12 23:06:47.162] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build/Release/epoll.node'
      0|MagicMir | was compiled against a different Node.js version using
      0|MagicMir | NODE_MODULE_VERSION 73. This version of Node.js requires
      0|MagicMir | NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
      do
      npm install electron-rebuild
      cd modules/MMM-PIR
      ~/MagicMirror/node_modules/.bin/electron-rebuild
      pm2 flush
      then restart your MM
      let me know
      U 3 Replies Last reply
      • U
        uok825 @sdetweil
        @sdetweil Sure i will do, now i middle of reinstalling module. When its install i try your solution and let you know :) sorry for bad English.
          sdetweil @uok825
          @uok825 no problem… didn’t need to reinstall module
          U 1 Reply Last reply
          • U
            uok825 @sdetweil
            @sdetweil I was trying out of desperation
            • U
              uok825 @sdetweil
              @sdetweil said in After update WARNING! Could not load config file.:
              do
              cd modules/MMM-PIR
              pm2 flush
              let me know
              i got error but i cant share my log cause of “Post content was flagged as spam by Akismet.com” error in npm install electron-rebuild
              • U
                uok825 @sdetweil
                do
                cd modules/MMM-PIR
                pm2 flush
                let me know
                S 2 Replies Last reply
                  sdetweil @uok825
                  @uok825 sorry, dumb of me to take u down the electron path when u don’t have electron.
                  cd ~/MagicMirror/modules/MMM-PIR
                  npm rebuild
                    sdetweil @uok825
                    @uok825 any progress?
                    U 2 Replies Last reply
                    • U
                      uok825 @sdetweil
                      pi@raspberrypi:~/MagicMirror/modules/MMM-PIR $ npm rebuild
                      > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                      > node-gyp rebuild
                      make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epol        l/build'
                       CXX(target) Release/obj.target/epoll/src/epoll.o
                       SOLINK_MODULE(target) Release/obj.target/epoll.node
                       COPY Release/epoll.node
                      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll        /build'
                      child_process@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/child_proc        ess
                      electron-rebuild@1.11.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/electr        on-rebuild
                      colors@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/colors
                      debug@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/debug
                      ms@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ms
                      detect-libc@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/detect-libc
                      fs-extra@8.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-extra
                      graceful-fs@4.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/graceful-fs
                      jsonfile@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsonfile
                      universalify@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/universalif        y
                      node-abi@2.18.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-abi
                      semver@5.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/semver
                      node-gyp@6.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/node-gyp
                      env-paths@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/env-paths
                      glob@7.1.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/glob
                      fs.realpath@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs.realpath
                      inflight@1.0.6 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inflight
                      once@1.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/once
                      wrappy@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrappy
                      inherits@2.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/inherits
                      minimatch@3.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimatch
                      brace-expansion@1.1.11 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/brace-e        xpansion
                      balanced-match@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/balanced-        match
                      concat-map@0.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/concat-map
                      path-is-absolute@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-is        -absolute
                      mkdirp@0.5.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mkdirp
                      minimist@1.2.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minimist
                      nopt@4.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nopt
                      abbrev@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/abbrev
                      osenv@0.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/osenv
                      os-homedir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-homedir
                      os-tmpdir@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/os-tmpdir
                      npmlog@4.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/npmlog
                      are-we-there-yet@1.1.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/are-we-        there-yet
                      delegates@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delegates
                      readable-stream@2.3.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/readable        -stream
                      core-util-is@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/core-util-i        s
                      isarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isarray
                      process-nextick-args@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/pro        cess-nextick-args
                      safe-buffer@5.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safe-buffer
                      string_decoder@1.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string_de        coder
                      util-deprecate@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/util-depr        ecate
                      console-control-strings@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        console-control-strings
                      gauge@2.7.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/gauge
                      aproba@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aproba
                      has-unicode@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-unicode
                      object-assign@4.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/object-ass        ign
                      signal-exit@3.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/signal-exit
                      string-width@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/string-widt        h
                      code-point-at@1.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/code-point        -at
                      is-fullwidth-code-point@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        is-fullwidth-code-point
                      number-is-nan@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/number-is-        nan
                      strip-ansi@3.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/strip-ansi
                      ansi-regex@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-regex
                      wide-align@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wide-align
                      set-blocking@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/set-blockin        g
                      request@2.88.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/request
                      aws-sign2@0.7.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws-sign2
                      aws4@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/aws4
                      caseless@0.12.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/caseless
                      combined-stream@1.0.8 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/combined        -stream
                      delayed-stream@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/delayed-s        tream
                      extend@3.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extend
                      forever-agent@0.6.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/forever-ag        ent
                      form-data@2.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/form-data
                      asynckit@0.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asynckit
                      mime-types@2.1.27 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-types
                      mime-db@1.44.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mime-db
                      har-validator@5.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-valida        tor
                      ajv@6.12.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ajv
                      fast-deep-equal@3.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fast-dee        p-equal
                      fast-json-stable-stringify@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modul        es/fast-json-stable-stringify
                      json-schema-traverse@0.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jso        n-schema-traverse
                      uri-js@4.2.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uri-js
                      punycode@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/punycode
                      har-schema@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/har-schema
                      http-signature@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/http-sign        ature
                      assert-plus@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/assert-plus
                      jsprim@1.4.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsprim
                      extsprintf@1.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/extsprintf
                      json-schema@0.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json-schema
                      verror@1.10.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/verror
                      sshpk@1.16.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/sshpk
                      asn1@0.2.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/asn1
                      safer-buffer@2.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/safer-buffe        r
                      bcrypt-pbkdf@1.0.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bcrypt-pbkd        f
                      tweetnacl@0.14.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tweetnacl
                      dashdash@1.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/dashdash
                      ecc-jsbn@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ecc-jsbn
                      jsbn@0.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/jsbn
                      getpass@0.1.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/getpass
                      is-typedarray@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/is-typedar        ray
                      isstream@0.1.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isstream
                      json-stringify-safe@5.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/json        -stringify-safe
                      oauth-sign@0.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/oauth-sign
                      performance-now@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/performa        nce-now
                      qs@6.5.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/qs
                      tough-cookie@2.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tough-cooki        e
                      psl@1.8.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/psl
                      tunnel-agent@0.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tunnel-agen        t
                      uuid@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/uuid
                      rimraf@2.7.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rimraf
                      tar@4.4.13 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tar
                      chownr@1.1.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chownr
                      fs-minipass@1.2.7 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/fs-minipass
                      minipass@2.9.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minipass
                      yallist@3.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yallist
                      minizlib@1.3.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/minizlib
                      which@1.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which
                      isexe@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/isexe
                      ora@3.4.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora
                      chalk@2.4.2 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/chalk
                      ansi-styles@3.2.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ansi-styles
                      color-convert@1.9.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-conv        ert
                      color-name@1.1.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/color-name
                      escape-string-regexp@1.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/esc        ape-string-regexp
                      supports-color@5.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/supports-        color
                      has-flag@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/has-flag
                      cli-cursor@2.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-cursor
                      restore-cursor@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/restore-c        ursor
                      onetime@2.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onetime
                      mimic-fn@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/mimic-fn
                      cli-spinners@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cli-spinner        s
                      log-symbols@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/log-symbols
                      strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/strip-ansi
                      ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/ora/node_modu        les/ansi-regex
                      wcwidth@1.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wcwidth
                      defaults@1.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/defaults
                      clone@1.0.4 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/clone
                      spawn-rx@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx
                      debug@2.6.9 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modu        les/debug
                      ms@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/spawn-rx/node_modules        /ms
                      lodash.assign@4.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/lodash.ass        ign
                      rxjs@6.6.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/rxjs
                      tslib@1.13.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/tslib
                      yargs@14.2.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs
                      cliui@5.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui
                      string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_        modules/string-width
                      emoji-regex@7.0.3 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/emoji-regex
                      is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        cliui/node_modules/is-fullwidth-code-point
                      strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/strip-ansi
                      ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/cliui/node_mo        dules/ansi-regex
                      wrap-ansi@5.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi
                      string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/n        ode_modules/string-width
                      is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        wrap-ansi/node_modules/is-fullwidth-code-point
                      strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/strip-ansi
                      ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/wrap-ansi/nod        e_modules/ansi-regex
                      decamelize@1.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/decamelize
                      find-up@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/find-up
                      locate-path@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/locate-path
                      p-locate@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-locate
                      p-limit@2.3.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-limit
                      p-try@2.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/p-try
                      path-exists@3.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/path-exists
                      get-caller-file@2.0.5 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/get-call        er-file
                      require-directory@2.1.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/requir        e-directory
                      require-main-filename@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/re        quire-main-filename
                      string-width@3.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_        modules/string-width
                      is-fullwidth-code-point@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/        yargs/node_modules/is-fullwidth-code-point
                      strip-ansi@5.2.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/strip-ansi
                      ansi-regex@4.1.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs/node_mo        dules/ansi-regex
                      which-module@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/which-modul        e
                      y18n@4.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/y18n
                      yargs-parser@15.0.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/yargs-pars        er
                      camelcase@5.3.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/camelcase
                      onoff@2.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff
                      epoll@2.0.10 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                      bindings@1.5.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/bindings
                      file-uri-to-path@1.0.0 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/file-ur        i-to-path
                      nan@2.14.1 /home/pi/MagicMirror/modules/MMM-PIR/node_modules/nan
                      • U
                        uok825 @sdetweil
                        0|MagicMir | [2020-07-13 18:04:01.849] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: NodeHelper is not defined
                        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR/node_helper.js:11:18)
                        0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
                        0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
                        0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
                        0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
                        0|MagicMir |     at loadModule (/home/pi/MagicMirror/js/app.js:124:17)
                        0|MagicMir |     at loadNextModule (/home/pi/MagicMirror/js/app.js:158:5)
                        0|MagicMir | [2020-07-13 18:04:02.059] [ERROR]  Whoops! There was an uncaught exception...
                        0|MagicMir | [2020-07-13 18:04:02.071] [ERROR]  ReferenceError: NodeHelper is not defined
                        0|MagicMir | [2020-07-13 18:04:02.143] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [2020-07-13 18:04:02.145] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        Same
                          sdetweil @uok825
                          @uok825 what a mess.
                          so. now I think u need to erase module folder and then reinstall module. the two back recovery mechanisms don’t work
                          • U
                            uok825 @sdetweil
                            @sdetweil ok
                            • U
                              uok825 @sdetweil
                              @sdetweil Not working
                                sdetweil @uok825
                                @uok825 man what a pain,
                                ok, delete the module folder (MMM-PIR) and then reclone and npm install
                                • U
                                  uok825 @sdetweil
                                  @sdetweil I already did and my relay is not working i was pissed of so much.
                                  i need to unbuilt my mirror :(
                                  and my weather forecast shows 2 day
                                    sdetweil @uok825
                                    @uok825 2 days, bug, switch to develop branch
                                    git fetch origin develop:develop
                                    git checkout develop
                                    then restart MM
                                    • U
                                      uok825 @sdetweil
                                        sdetweil @uok825
                                        @uok825
                                        do
                                        # remove tracked file, un-needed
                                        rm package-lock.json
                                        # save the package.json changes
                                        git stash
                                        # switch to the other branch
                                        # restore the package.json file
                                        git stash pop
                                        restart mm
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil in mm folder right?
                                            sdetweil @uok825
                                            @uok825 yes
