    MMM-GoogleAssistant with MMM-MotionDetector
    22 Posts 4 Posters 7.2k Views 4 Watching
      majik655 @killerjoe34
      @killerjoe34 said in MMM-GoogleAssistant with MMM-MotionDetector:
      Hi guys :)
      Thanks to @Bugsounet, GA and AD2 both work really well for me now with Spotify !
      I installed MotionDetector wich works also well.
      But when the display is off, I would like to turn it on by saying the hotword (Jarvis in my case)
      How can I do that ?
      Re: MMM-GoogleAssistant with MMM-MotionDetector
      I personally use MMM-NEW-PIR … and don’t need to wake the screen because the motion detector sees me and wakes the screen…this is using a PIR motion sensor though… so I am unsure you exact scenario…
      But MAYBE you can look into the recipes…
      In your assistant directory you will see a directory called RECIPES .
      There are some premade recipes in there you can look over… you can also read about them in the wiki…
      one of them is called “with-MMM-pages.js”
      Open it and you will see the commands in that file that you can attach to your config file in the assistant module and it will do what the recipe tells it to…
      I do not have access to this recipe file right now but I believe you can say “SHOW ALL MODULES” and the screen might wake up? (again this depends on your setup and your motion modules)…
      You will need to add the recipe you want to use to your config file…
      This page shows you the DETAILED config and at the bottom you will see RECIPES…
      https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Configuration-Sample
      Add this to your config and put in the with-MMM-pages.js - restart Magic mirror and try out saying the commands.
      You can also create your own recipes (look in the wiki) and add your own recipe js files to your config … you can use more than one.
          recipes: [ "with-MMM-pages.js" ]
        A Former User
        @majik655 said in MMM-GoogleAssistant with MMM-MotionDetector:
        MMM-NEW-PIR
        I have to update this module butI really don’t use it, because all fonctionnality is on A2D
        I start to code A2D pir module to MMM-NewPir but not finish
        I will continue it and commit it to master soon
        Note:
        For GA/A2D users it’s more natural to use screen/pir sub-module of A2D because it’s lock screen on GA/A2D use and can’t turn off
        MMM-NewPir have not this fonctionality (and can’t never have it, because i don’t want to do a dual code)
        example:
        • with GA / youtube and MMM-NewPir
          defined tiner of NewPir is for example : 2 min
          duration of video +/- 4 min
          NewPir will turn off video at 2min
        • with GA / A2D / youtube and screen/pir submodule of A2D
          defined tiner of screen/pir is for example : 2 min
          A2D will turn on the monitor for duration of video (playing)
          A2D will restart the counter at the end of video
        M 1 Reply Last reply
        • K
          killerjoe34
          @Bugsounet said in MMM-GoogleAssistant with MMM-MotionDetector:
          Thank you, but MMM-MotionDetector works perfectly if I move around, it detects the motion and wake the screen up.
          But I don’t want to wave in front of it just to wake it up, for example when I’m in the sofa without a move ;)
          That’s it! I had a few tries and I can get it Off or On with the Reboot-Restart-Shutdown recipe by modifying it with
          vcgencmd display_power 1
          or
          vcgencmd display_power 0```
          But could it be possible to power it on just by saying the hotword jarvis ?
          Perhaps it would be complicated as it would have to check if it’s on or off first ? (ou pas)
            A Former User
            euh, it’s a native fonction
            but … if you enable detectorSleeping if will not works because it’s turn off detector on the same time of the screen
            and if detector (jarvis) is off … i will not hear you
            verify your config :)
            • K
              killerjoe34
              Ok, I will continue to move my hands then :D
                A Former User
                show me you A2D config so …
                • K
                  killerjoe34
                  Sorry, got to go now, we’ll continue tomorrow, thanks and bonne soirée ;)
                    A Former User
                    ok when you have time post it in private. i will resolve it :p
                    Note: why I need your A2D config ? just because i will try with it to reproduce non working fonctionality !
                      majik655 @Guest
                      MMM-NEW-PIR
                      Note:
                      example:
                      Hey @Bugsounet
                      I am not sure I follow you very well … but the reason why I needed or used NEW-PIR was because it was the only thing that did not actually turn off the monitor or go to sleep so the the monitor power saver showed.
                      As far as I know NEW-PIR throws up a “black” screen or something so that the monitor never “sleeps” and when it wakes the monitor doesn’t report the input (hdmi) or show the power save on sleeping.
                      New-PIR was installed first… then I figured out how to install GA… then installed A2D, and then installed facial recognition …
                      It all seems to work fine the way I have it … honestly I couldn’t figure out the A2D commands and such in the beginning and do not want to reconfigure lol.
                      It all works great on my end for the moment I suppose.
                        A Former User
                        when it want to works ! don’t touch it lol ;)
                        • K
                          killerjoe34
                          Well I’ve been a bit optimist…
                          In fact there’s a problem with MotionDetector and a TV display, after a while the tv goes in deep sleep mode and does not wake up.
                          If I turn the energy saving off on the tv, it still stays on with a “no signal” message.
                          I’m trying some things with CEC at the moment wich can turn on a tv monitor, I’ll let you know …
                            sdetweil @killerjoe34
                            @killerjoe34 I wrote my own sleep. module that hides everything, as my TV’s don’t support API on/off
                            K 1 Reply Last reply
                            • K
                              killerjoe34 @sdetweil
                              @sdetweil said in MMM-GoogleAssistant with MMM-MotionDetector:
                              You mean that can turn the tv off and on ? With a black screen or does it really turn the display off ?
                                A Former User
                                @killerjoe34 :
                                try with rpi4:true in screen A2D config maybe i can help
                                  @killerjoe34 black screen not turn tv off
                                    A Former User
                                    oupss sorry
                                    • K
                                      killerjoe34 @Guest
                                      @killerjoe34 :
                                      Was this for me ? :D
                                      Cause I have a RPI3 and “Screen” is not enabled in my AD config
                                      • K
                                        Well, could be interesting if I can’t get it working, I’ll ask you if I need a hand ;)
                                          A Former User
                                          euh …I thinking that you use Motion detecetor and A2D screen/Pir sub-module (with gpio) but not
                                          you are using another script …
                                          sorry ;)
                                          Can’t help in this case sorry ;)
                                            A Former User
                                            that’s why your main request don’t work
                                            after you can listen ASSISTANT_LISTEN notification with another module for wakeup your screen (at condition that your find to wake up your screen)
