    MMM-GoogleAssistant with MMM-MotionDetector
    22 Posts 4 Posters 7.2k Views 4 Watching
      A Former User
      show me you A2D config so …
      • K
        killerjoe34
        Sorry, got to go now, we’ll continue tomorrow, thanks and bonne soirée ;)
          A Former User
          ok when you have time post it in private. i will resolve it :p
          Note: why I need your A2D config ? just because i will try with it to reproduce non working fonctionality !
            majik655 @Guest
            @Bugsounet said in MMM-GoogleAssistant with MMM-MotionDetector:
            @majik655 said in MMM-GoogleAssistant with MMM-MotionDetector:
            MMM-NEW-PIR
            I have to update this module butI really don’t use it, because all fonctionnality is on A2D
            I start to code A2D pir module to MMM-NewPir but not finish
            I will continue it and commit it to master soon
            Note:
            For GA/A2D users it’s more natural to use screen/pir sub-module of A2D because it’s lock screen on GA/A2D use and can’t turn off
            MMM-NewPir have not this fonctionality (and can’t never have it, because i don’t want to do a dual code)
            example:
            • with GA / youtube and MMM-NewPir
              defined tiner of NewPir is for example : 2 min
              duration of video +/- 4 min
              NewPir will turn off video at 2min
            • with GA / A2D / youtube and screen/pir submodule of A2D
              defined tiner of screen/pir is for example : 2 min
              A2D will turn on the monitor for duration of video (playing)
              A2D will restart the counter at the end of video
            Hey @Bugsounet
            I am not sure I follow you very well … but the reason why I needed or used NEW-PIR was because it was the only thing that did not actually turn off the monitor or go to sleep so the the monitor power saver showed.
            As far as I know NEW-PIR throws up a “black” screen or something so that the monitor never “sleeps” and when it wakes the monitor doesn’t report the input (hdmi) or show the power save on sleeping.
            New-PIR was installed first… then I figured out how to install GA… then installed A2D, and then installed facial recognition …
            It all seems to work fine the way I have it … honestly I couldn’t figure out the A2D commands and such in the beginning and do not want to reconfigure lol.
            It all works great on my end for the moment I suppose.
              A Former User
              when it want to works ! don’t touch it lol ;)
              • K
                killerjoe34
                Well I’ve been a bit optimist…
                In fact there’s a problem with MotionDetector and a TV display, after a while the tv goes in deep sleep mode and does not wake up.
                If I turn the energy saving off on the tv, it still stays on with a “no signal” message.
                I’m trying some things with CEC at the moment wich can turn on a tv monitor, I’ll let you know …
                  sdetweil @killerjoe34
                  @killerjoe34 I wrote my own sleep. module that hides everything, as my TV’s don’t support API on/off
                  K 1 Reply Last reply
                  • K
                    killerjoe34 @sdetweil
                    @sdetweil said in MMM-GoogleAssistant with MMM-MotionDetector:
                    You mean that can turn the tv off and on ? With a black screen or does it really turn the display off ?
                      A Former User
                      @killerjoe34 :
                      try with rpi4:true in screen A2D config maybe i can help
                        @killerjoe34 black screen not turn tv off
                          A Former User
                          oupss sorry
                          • K
                            killerjoe34 @Guest
                            @killerjoe34 :
                            Was this for me ? :D
                            Cause I have a RPI3 and “Screen” is not enabled in my AD config
                            • K
                              Well, could be interesting if I can’t get it working, I’ll ask you if I need a hand ;)
                                A Former User
                                euh …I thinking that you use Motion detecetor and A2D screen/Pir sub-module (with gpio) but not
                                you are using another script …
                                sorry ;)
                                Can’t help in this case sorry ;)
                                  A Former User
                                  But when the display is off, I would like to turn it on by saying the hotword (Jarvis in my case)
                                  that’s why your main request don’t work
                                  after you can listen ASSISTANT_LISTEN notification with another module for wakeup your screen (at condition that your find to wake up your screen)
                                  • K
                                    killerjoe34 @Guest
                                    @Bugsounet Thanks a lot, that will help :)
