    MMM-Todoist
    23 Posts 4 Posters 10.1k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
        bdream
        @Stoffbeuteluwe good question as I had same in my mind.
        I added in custom.css
         .MMM-Todoist {
        	width:450px;
         .MMM-Todoist .small {
        	font-size: 13px;
        	line-height: 15px;
        .MMM-Todoist .priority{
        	width: 0px;
        	border-right: 0px;
        A test without success was also with
        .MMM-Todoist .spacerCell {
            width: 0px;
        I assume it’s about any with .divTable or .divTableCell but don’t know how to handle and I gave up :face_with_cold_sweat:
        May you find a solution :crossed_fingers:
        cheers, bdream
          the fastest way to learn what css needs to/can be changed, is to. open the developers window, select the elements tab and navigate the Dom to the element u want to modify.
          it’s css class tree is shown on the bottom of the dev window. nearer the element on the right.
          the individual classes are shown on the right, nearer to element on the top.
          one can add/edit/remove css entries to change the displayed behavior.
          once u figure out what u need (styles) and where (what element) it’s easy to create a custom css entry that looks like that
            bdream
            oh Sam! what you are explaining here (…select the elements tab and navigate the Dom…), sound all Greek to me :man_zombie:
            How to do it via ssh?
            cheers, bdream
              sdetweil @bdream
              @bdream cannot. must do. on mirror app
                bdream
                sounds that the blocking point.
                lets see if I get an keyboard connectet. That will be the right way?
                cheers, bdream
                  bdream
                  @sdetweil Sam, can you please guide me a bit.
                  Just connected the keyboard but as estimated after short thinking there is nothing I can do while MM is running … but I guess I need it running.
                  cheers, bdream
                    sdetweil @bdream
                    @bdream
                    before starting examine the ~/MagicMirror/index.html file, this is the layout of the page, and all content is inserted into these positions (position: of module definition in config.js)
                    hit keyboard keys, ctrl, shift and letter i.
                    dev window. opens on right side of screen
                    select the tab labeled elements
                    expand the tree to locate the module content. (module position is important)
                    look at time value,
                    then select the time value in dom tree
                    notice the class list, bottom of the screen circled, and the individual classes are shown on the right, top is closest to the element, bottom is closest to t main.css
                    u can edit the top right, and add element styles.
                      bdream
                      should “hit keyboard keys, ctrl, shift and letter i” be possible while my MM is running?
                      Doesn’t work…
                      cheers, bdream
                      S 1 Reply Last reply Reply Quote -1
                        sdetweil @bdream
                        @bdream must be while mm is running
                        you can do it on a remote browser too (forgot that) using chrome
                        Windows PC to pi server
                          @bdream all 3 keys at once
                            bdream
                            such an awesome tool MagicMirror is.
                            Every time I’m in contact with this forum I learn new nice things.
                            Can’t see how to fix this the empty space mentioned by @Stoffbeuteluwe
                            cheers, bdream
                              sdetweil @bdream
                              @bdream keep expanding, you have the whole module content selected there, get to the little part that needs to move
                                bdream
                                I see what you mean.
                                It’s tricky as I use MMM-Carousel and every time I click to expand it switch back.
                                Have commented out MMM-Carousel and see that
                                Don’t know how to get the red round marked off
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream expand the other divTableRows
                                    sdetweil @bdream
                                    @bdream said in MMM-Todoist:
                                    yes, sometimes you have to just use the one module to be able to explore effectively
                                      bdream
                                      @sdetweil don’t know what exactly I’m looking for :face_with_monocle:
                                      I assume 1 (marked in red 1) is exactly the space I want to get rid off.
                                      And ! seems to me related to 2 (marked in red 2) , what in english is [space]
                                      Could it be I have to do any in custom.css regarding the both lines with spacecells in it?
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream remember the whole point of this exercise was to find the element and figure out how to hide it.
                                        but I don’t see a spacerCell class defined anywhere. you should move the left edge of the dev window further left, to get the class display vertical… (like in my previous images)
                                        u can define a spacerCell class in custom.css and then be able to edit it here, but maybe this would be enough
                                        display: none;
                                          bdream
                                          @sdetweil Thanks Sam! Idea was good but not the right point.
                                          I will work a bit on it and deep dive but first look shows there will nothing I can use to work with custom.css
                                          cheers, bdream
                                            cbrooker
                                            Hi All,
                                            I just saw this thread and think I can offer some assistance. I wrote and maintain the MMM-Todoist module.
                                            That space that you’re seeing is where the Todo Priority would be displayed if you set a priority.
                                            Like this (the red bar):
                                            If you have no need for that and want to remove the space the quickest “hack” you can do is:
                                            1. Open /modules/MMM-Todoist/MMM-Todoist.js
                                            2. Comment out these 2 lines:
                                            divRow.appendChild(this.addPriorityIndicatorCell(item));
                                            divRow.appendChild(this.addColumnSpacerCell());
                                            Line 592 and 593.
                                            1. Save and reload MagicMirror.
                                            2. Do a local commit (git commit -a)
                                            That will remove the space however, every time you update module you might have to deal with a merge conflict.
                                            More advanced:
                                            You could also fork the repo, clone the new repo into your modules folder make, the changes, commit, push. You could then pull the upstream changes when you wanted to update.
