Error Installing Dependecies
installing dependecieserrorproblem
4 Posts 2 Posters 6.7k Views 2 Watching
  • F Offline
    ferra1980
    Hi all,
    I’m trying to install MagicMirror2 on a Pi2 but using the Automatic Installer, everythings goes well until the process reach the step “Installing dependencies”. I get this error:
    Installing dependencies ...
    npm WARN prefer global coffee-script@1.10.0 should be installed with -g
    npm WARN prefer global colorguard@1.2.0 should be installed with -g
    > electron-prebuilt@1.1.0 postinstall /root/MagicMirror/node_modules/electron-prebuilt
    > node install.js
    module.js:440
        throw err;
    Error: Cannot find module '/root/MagicMirror/node_modules/electron-prebuilt/install.js'
        at Function.Module._resolveFilename (module.js:438:15)
        at Function.Module._load (module.js:386:25)
        at Function.Module.runMain (module.js:575:10)
        at startup (node.js:160:18)
        at node.js:445:3...
    npm ERR! Linux 4.4.9-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
    npm ERR! node v6.1.0
    npm ERR! npm  v3.8.6
    npm ERR! code ELIFECYCLE
    npm ERR! electron-prebuilt@1.1.0 postinstall: `node install.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the electron-prebuilt@1.1.0 postinstall script 'node install.js'.
    npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
    npm ERR! not with npm itself.
    npm ERR!     node install.js
    npm ERR!     npm bugs electron-prebuilt
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls electron-prebuilt
    npm ERR!     /root/MagicMirror/npm-debug.log
    Unable to install dependencies!
    root@raspberrypi:~# npm install
    Someone can help me?
    Note from admin: Please use Markdown on your code snippets so they are easier to read!
      MichMich Admin
      What OS are you running? What Node version are you running (if the installer didn’t update)?
      • F Offline
        ferra1980
        Hi Mich,
        thanks for your help!
        I’m running the last version of Raspbian Jessie, Version: May 2016, Release date: 2016-05-10, Kernel version: 4.4, and the update of Node was a success (It’s the first step of the automatic intallation, right?)
          MichMich Admin
          Interesting. Could you give https://github.com/electron/electron-quick-start a try to see if that one works?
