MMM-AdminPanel get problem
10 Posts 2 Posters 1.1k Views 2 Watching
  • E Offline
    emrah_asl
    Hello, I applied all steps and follow ipWhiteList rules.
    https://github.com/ItayXD/MMM-Admin-Interface![alt text](![image url](![image url](image url)))
    When i try in over browser
    http://localhost:8080/MMM-Admin-Interface/
    It says with white screen
    Cannot GET /MMM-Admin-Interface/
    1- git clone projects
    2- adding module in config js
    module: “MMM-Admin-Interface”
    3- My internal Ip is 192.168.0.29
    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.0.29” , “::ffff:192.168.0.29”], // Set [] to allow all IP addresses bla bla
    Thanks for helping me, what is the point here?
    S 2 Replies Last reply Aug 9, 2020, 12:39 PM Reply Quote 0
      sdetweil @emrah_asl
      @emrah_asl does
      http://pi_address:8080
      from your pc open the mm?
      assuming 192.168.0.29 is your PC address?
        sdetweil @emrah_asl
        @emrah_asl localhost means from this machine, so browser running on mm machine
        • E Offline
          emrah_asl
          @emrah_asl said in MMM-AdminPanel get problem:
          Hi, I’m doing this inside my raspberry browser.
          is working for MM.
          192.168.0.29 is my rpi internal ip which means i connect via VNC server
          S 1 Reply Last reply Aug 9, 2020, 1:06 PM Reply Quote 0
            sdetweil @emrah_asl
            where do you do this from?
            note that the ipWhitelist addresses are not correct
            if using ipv4, its address/mask
            I usually make ipWhilelist:[],
            to allow anyone on my local network to access, until I get it the way I want
            E 1 Reply Last reply Aug 9, 2020, 1:08 PM Reply Quote 0
            • E Offline
              emrah_asl @sdetweil
              @sdetweil said in MMM-AdminPanel get problem:
              //where do you do this from?
              answe is, I’m writing inside raspberry 4b browser
              S 1 Reply Last reply Aug 9, 2020, 1:15 PM Reply Quote 0
                sdetweil @emrah_asl
                @emrah_asl hm…
                i added module and default config,
                and (my MM on port 8090 as another app is using 8080)
                http://localhost:8090/MMM-Admin-Interface/
                shows
                so I would blank out the ipWhitelist to
                ipWhitelist:[],
                • E Offline
                  emrah_asl
                  Hi @sdetweil
                  Yeah you right again ! When I leave blanks ipWhitelist, It is works.
                  Bu interesting, what should do coorect restrictons about this point.
                  I’m connecting my rpi over VNC servier with 192.168.0.29 in my windows.
                  S 1 Reply Last reply Aug 9, 2020, 1:28 PM Reply Quote 0
                    sdetweil @emrah_asl
                    @emrah_asl what is your windows pc IP address
                    ipWhitelist: [ windows_ip/32 ],
                    my windows IP is 192.168.2.106, so would be
                    ipWhitelist:[192.168.2.106/32],
                    that means, ipv4 addresses are 32 bits wide (4 chars)
                    so, allow this address windows_ip, and use all 32 bits for address matching
                    you can match the local network
                    windows_ip/24 which would be
                    any system with address starting with 192.168.0
                    S 1 Reply Last reply Aug 10, 2020, 1:57 PM Reply Quote 0
                      @emrah_asl also, vnc vs mm. mm implements its own network security . so vnc connection has nothing to do with mm connection
