    MMM-AdminPanel get problem
    10 Posts 2 Posters 2.5k Views 2 Watching
    • E
      emrah_asl
      Hello, I applied all steps and follow ipWhiteList rules.
      https://github.com/ItayXD/MMM-Admin-Interface![alt text](![image url](![image url](image url)))
      When i try in over browser
      http://localhost:8080/MMM-Admin-Interface/
      It says with white screen
      Cannot GET /MMM-Admin-Interface/
      1- git clone projects
      2- adding module in config js
      module: “MMM-Admin-Interface”
      3- My internal Ip is 192.168.0.29
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.0.29” , “::ffff:192.168.0.29”], // Set [] to allow all IP addresses bla bla
      Thanks for helping me, what is the point here?
        sdetweil @emrah_asl
        @emrah_asl does
        http://pi_address:8080
        from your pc open the mm?
        assuming 192.168.0.29 is your PC address?
          sdetweil @emrah_asl
          @emrah_asl localhost means from this machine, so browser running on mm machine
          • E
            emrah_asl
            @emrah_asl said in MMM-AdminPanel get problem:
            Hi, I’m doing this inside my raspberry browser.
            is working for MM.
            192.168.0.29 is my rpi internal ip which means i connect via VNC server
              sdetweil @emrah_asl
              where do you do this from?
              note that the ipWhitelist addresses are not correct
              if using ipv4, its address/mask
              I usually make ipWhilelist:[],
              to allow anyone on my local network to access, until I get it the way I want
              • E
                emrah_asl @sdetweil
                @sdetweil said in MMM-AdminPanel get problem:
                //where do you do this from?
                answe is, I’m writing inside raspberry 4b browser
                  sdetweil @emrah_asl
                  @emrah_asl hm…
                  i added module and default config,
                  and (my MM on port 8090 as another app is using 8080)
                  http://localhost:8090/MMM-Admin-Interface/
                  shows
                  so I would blank out the ipWhitelist to
                  ipWhitelist:[],
                  • E
                    emrah_asl
                    Hi @sdetweil
                    Yeah you right again ! When I leave blanks ipWhitelist, It is works.
                    Bu interesting, what should do coorect restrictons about this point.
                    I’m connecting my rpi over VNC servier with 192.168.0.29 in my windows.
                      sdetweil @emrah_asl
                      @emrah_asl what is your windows pc IP address
                      ipWhitelist: [ windows_ip/32 ],
                      my windows IP is 192.168.2.106, so would be
                      ipWhitelist:[192.168.2.106/32],
                      that means, ipv4 addresses are 32 bits wide (4 chars)
                      so, allow this address windows_ip, and use all 32 bits for address matching
                      you can match the local network
                      windows_ip/24 which would be
                      any system with address starting with 192.168.0
                        @emrah_asl also, vnc vs mm. mm implements its own network security . so vnc connection has nothing to do with mm connection
