    MMM-AdminPanel get problem
    10 Posts 2 Posters 2.0k Views 2 Watching
      sdetweil @emrah_asl
      @emrah_asl localhost means from this machine, so browser running on mm machine
      • E Offline
        emrah_asl
        @emrah_asl said in MMM-AdminPanel get problem:
        When i try in over browser
        http://localhost:8080/MMM-Admin-Interface/
        Hi, I’m doing this inside my raspberry browser.
        is working for MM.
        192.168.0.29 is my rpi internal ip which means i connect via VNC server
          sdetweil @emrah_asl
          where do you do this from?
          note that the ipWhitelist addresses are not correct
          if using ipv4, its address/mask
          I usually make ipWhilelist:[],
          to allow anyone on my local network to access, until I get it the way I want
          • E Offline
            emrah_asl @sdetweil
            @sdetweil said in MMM-AdminPanel get problem:
            //where do you do this from?
            answe is, I’m writing inside raspberry 4b browser
              sdetweil @emrah_asl
              @emrah_asl hm…
              i added module and default config,
              and (my MM on port 8090 as another app is using 8080)
              http://localhost:8090/MMM-Admin-Interface/
              shows
              so I would blank out the ipWhitelist to
              ipWhitelist:[],
              • E Offline
                emrah_asl
                Hi @sdetweil
                Yeah you right again ! When I leave blanks ipWhitelist, It is works.
                Bu interesting, what should do coorect restrictons about this point.
                I’m connecting my rpi over VNC servier with 192.168.0.29 in my windows.
                  sdetweil @emrah_asl
                  @emrah_asl what is your windows pc IP address
                  ipWhitelist: [ windows_ip/32 ],
                  my windows IP is 192.168.2.106, so would be
                  ipWhitelist:[192.168.2.106/32],
                  that means, ipv4 addresses are 32 bits wide (4 chars)
                  so, allow this address windows_ip, and use all 32 bits for address matching
                  you can match the local network
                  windows_ip/24 which would be
                  any system with address starting with 192.168.0
                    @emrah_asl also, vnc vs mm. mm implements its own network security . so vnc connection has nothing to do with mm connection
