    MMM-MyCommute not showing up.
    31 Posts 4 Posters 15.5k Views 4 Watching
    • buzzkcB
      buzzkc
      @Doogain
      Your config entry should look more like the one in the Readme.md page of the module (https://github.com/jclarke0000/MMM-MyCommute)
      Also, be sure you followed all of the installation notes in the readme.
        module: 'MMM-MyCommute',
        position: 'top_left',
          apikey: 'API_KEY_FROM_GOOGLE',
          origin: '65 Front St W, Toronto, ON M5J 1E6',
          startTime: '00:00',
          endTime: '23:59',
          hideDays: [0,6],
          destinations: [
              destination: '14 Duncan St Toronto, ON M5H 3G8',
              label: 'Air Canada Centre',
              mode: 'walking',
              color: '#82E5AA'
              destination: '317 Dundas St W, Toronto, ON M5T 1G4',
              label: 'Art Gallery of Ontario',
              mode: 'transit'
              destination: '55 Mill St, Toronto, ON M5A 3C4',
              label: 'Distillery District',
              mode: 'bicycling'
              destination: '6301 Silver Dart Dr, Mississauga, ON L5P 1B2',
              label: 'Pearson Airport',
              avoid: 'tolls'
      Darren
      My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        sdetweil @Doogain
        @Doogain u modified the module source. Please remove yours, and customize the config.js
          Doogain
          I reverted the module source, I messed up bigtime on that. The modules show up in MM now, and that is so great! Thanks a lot!
          It does give a me a error instead of commute time tho, I think thats a either a API or adress error.
          Which API do I have to select from google? It gives me several choices.
          • buzzkcB
            buzzkc
            I believe it’s the Maps Javascript API>>Directions API
            Darren
            D 1 Reply Last reply
              Doogain @buzzkc
              @buzzkc said in MMM-MyCommute not showing up.:
              Hmm still getting a error where it should say commute time.
              It says:
              MMM-MyCommute: You must enable Billing on the Google Cloud Project at https://console.cloud.google.com/project/_/billing/enable Learn more at https://developers.google.com/maps/gmp-get-started
              I already have that enabled tho.
                Doogain
                I figured it out. I had to enable all the following
                1.) Maps Javascript API
                2.) Directions API
                3.) Geocoding API.
                Marking as solved, thanks for all the help :-)
                  sdetweil @Doogain
                    spoonek
                    Sorry to bump an old post, seemed like a better idea vs creating a new one…
                    I’m having the same issue. I’m using MagicMirror 2.12. The MMM-MyCommute module shows “Error” in red for my destination. I have an api key. The api key is active. I’ve added the Directions API, Geocoding API and Maps JavaScript API to my Google Cloud Platform account. I’ve tried both apikey and apiKey. I did read on the Google site that the request needs to be something like “key_api” but can’t find that verbiage again to validate. Not sure what else I can do at this point. Any tips? Many thanks!!
                    code:
                    	header: 'Commute Times',
                    		apiKey: '**********************************',
                    		origin: '**my home address**',
                    		startTime: '00:00',
                    		endTime: '23:59',
                    		destinations: [
                    				destination: '6000 N Terminal Pkwy, Atlanta, GA 30320',
                    				label: 'Airport'
                      sdetweil @spoonek
                      @spoonek apikey, all lower case, read the module doc
                      open the developers window ctrl-shift-i, then select the console tab and scroll up see any errors. u can also filter messages by module, by placing part of the module name in the filter field ‘comm’ for example
                        spoonek @sdetweil
                        @sdetweil said in MMM-MyCommute not showing up.:
                        @spoonek apikey, all lower case, read the doc
                        Thanks. There is conflicting info on github. One MyCommute says use apikey. The other fork says to now use apiKey. I tried both, same result…“Error”.
                        I’ll check out the dev window. I’m a n00b so learning as I go. Appreciate the suggestion!
                        [edit]. …aaaaaand I’m on a MAC. :man_facepalming_light_skin_tone:
                        S 2 Replies Last reply
                          sdetweil @spoonek
                          @spoonek the same result means the problem is probably in the key. Google requires a credit card to back their accounts, altho they give generous credits against usage for a while
                            spoonek @sdetweil
                            @sdetweil Yep, I added a card and activated the account last night. Was hoping it would sync up overnight but same issue this morning.
                              sdetweil @spoonek
                              @spoonek use the menu to get the dev window open. or start with
                              npm start dev
                              if u normally use pm2, do pm2 stop 0
                              before the npm start
                                sdetweil @spoonek
                                @spoonek no sync time. it’s immediate.
                                  spoonek @sdetweil
                                  npm start dev
                                  OK, that is awesome! Thanks for the tip! So maybe I need to generate a new api key and use that?
                                  [2020-08-20 09:07:14.680] [LOG] MMM-MyCommute: You must use an API key to authenticate each request to Google Maps Platform APIs. For additional information, please refer to http://g.co/dev/maps-no-account
                                    sdetweil @spoonek
                                    @spoonek u didn’t list the maps api I the list of services above
                                      spoonek @sdetweil
                                      @sdetweil thanks. I don’t see it…
                                        sdetweil @spoonek
                                        @spoonek from the link on the module doc
                                        Maps JavaScript API
                                        from the image u posted,
                                        2nd row, second box from left
                                          spoonek @sdetweil
                                          @spoonek from the link on the moduledoc
                                          Maps JavaScript API
                                          Yep, got that one already. :(
                                            sdetweil @spoonek
                                            @spoonek so, then, passing the key is a problem,
                                            so it might be the item name in config. u can specify both,
                                            and u got the right string for the API key from Google.
                                            which GitHub module are u using?
                                            from the module folder do,
                                            git remote -v
